Projects 54 210 2 door build
Discussion in 'The Hokey Ass Message Board' started by BIG REDD, Dec 10, 2011.
  1. BIG REDD
    BIG REDD
    from upstate NY
    couple small updates.
    front grille and lights are on. I went with some hella lights as opposed to the standard sealed beam, its a little bit of a cleaner lens and is considerably brighter.
    and the seats are completed ( the fronts dont have the lower side trim or the tracks yet)
    and the rears.
    T-DeWitt and little red 50 like this.
  2. Rynos63
    Rynos63
    Man that looks good...
  3. T-DeWitt
    T-DeWitt
    I like it, top notch stuff.
  4. BIG REDD
    BIG REDD
    from upstate NY
    some minor updates.
    Decided to pull the headers and clean them up and polish them.
    Im very happy with the result, and cant wait to see them turn a nice gold.
    replaced the worm clamps with gates powergrips.
    installed my rear view camera
    bodyworked and painted the rearview mirror mount
  5. Rokkern
    Rokkern
    from Norway
    Just finished reading the 10 pages ! Bad*** work, inspirational project, love the engine/trans combo and you actually made that ****ty looking engine look quite good ! It`ll be a great driver once finished I`m sure ! Looks killer !!
    Thanks for keeping at it and posting, even the none approved HAMB stuff ;)
  6. partslinger
    partslinger
    That by far is the best profile ever for a 54 chevy. Nothing else will do looks great
  7. partslinger
    partslinger
    ls looks bad *** too!
  8. BIG REDD
    BIG REDD
    from upstate NY
    Thanks. Even though it is a modern motor I tried to make it look as simple and cl***y as possible.
  9. BIG REDD
    BIG REDD
    from upstate NY
    small update, I brought the car out to Tucci Engineering in Marcy NY so the rest of the gl*** can be cut and installed. While its out there I will be going out periodically to ****on up some small ends such as A/C lines, Steering stops, Air filters and some small stuff.
    I also fabricated a panel to hold the ignition, the headlight switch, and the cruise control ****ons.
    which is almost invisible once the extra key is removed.
  10. banditomerc
    banditomerc
  11. banditomerc
    banditomerc
    Did you cut down a new laminated rear gl***?...or are you using lexan?
  12. BIG REDD
    BIG REDD
    from upstate NY
    Car is still out at Tucci Engineering, not too happy with the pace of things but I was told itll be done by the end of the month. I did get some stuff done, Not pictured but I did get the door openers installed, made a mount for the OBD2 port, finished up the taillight wiring.
    I also got the front garnish moldings chopped down and fit.
  13. YJ4000
    YJ4000
    I may have said this before. I really like the way this car is turning out!
    Ryan.
  14. BIG REDD
    BIG REDD
    from upstate NY
    SO the car is tuned and back home. It made 400hp and 385ftlbs to the tires through a fairly big converter and an auto. I put some miles on the car and its scary fast. Ill be doing a bunch to get it ready for the Adirondack nationals this weekend.
  15. The37Kid
    The37Kid
    NICE! That car sure has the look. Bob
  16. BIG REDD
    BIG REDD
    from upstate NY
    So a nice little update, Ive been thrashing to get the car done and ready for SEMA. I managed to get it "done" haha.
    first off one of the local shows I went to about a month ago I ran into a guy with a bone stock unrestored 54 chevy. Funny to look at it next to this car.
    Then the transmission started slipping, well $2200 later I now have a new one that is rated for the proper power.
    and the new one
    after the mechanical was addressed it was time to do some cosmetic. I had painted the car back in February however never sanded and buffed it. I did this because I knew the car was gonna be shifted around a bit from the gl*** shop to the upholstery shop ext ext. Sure enough by the time I had got the car back the hood and one of the fenders had gotten scratched and needed to be repainted. so once that was done I finally took the time to make the paint perfect.
    3000 grit
    5000 grit
    and the result
    Next up is the license plate, its kind of a unique plate in that it belonged to a New York Senator, So in addition to the plate I also got a br*** senator parking p*** that would have been displayed on the dash. So as far a a license plate frame I looked and looked for something that would be fitting. Ultimately I came up short so I had an idea to continue the mid 50s politician theme, the " I like Ike" campaign that Eisenhower ran in 1952. So I drew up a design for a frame that I would think would be period. I then had my friend Nick 3D print it.
    I then painted it to look like a 60 year old cast metal frame.
    next up was the interior. I had the seats done back earlier in the year but dropped the car off to get the headliner, door panels and carpet done. I drew out the design and had the guy make it. However I did have to do the rear garnish moldings due to the chop.
    and the final result.
    I did move into a new house which finally has a 2 car garage so I can have both of my cars under 1 roof, and on top of that the car gets shipped off to Las Vegas tomorrow for the SEMA show, so stay tuned for that!
  17. YJ4000
    YJ4000
    Very nice work. Have fun at SEMA.
    Ryan.
  18. Johnny C.
    Johnny C.
    Nice car and great build. Like the style of it.
  19. BIG REDD
    BIG REDD
    from upstate NY
    so some pictures from sema.
    one final touch prior to it leaving, functional rear view camera thats on all the time.
    loaded up in the trailer.
    unloaded
    cruising the strip a little.
    went out of town to get some proper pictures of the car.
    https://scontent-lga3-1.**.fbcdn.net/hphotos-xfp1/v/t1.0-9/12240108_10156070778950478_7829519065213001274_n.jpg?oh=6a381273e5e990360ba94bc006623689&
    oe=56E47022
    some taken with a proper camera.
    now for the actual show.
    set up day.
    the sponsors booth
    all set up
    battle of the builders reception, did win anything but once I saw some of the other cars i was competing against (including chip foose and bobby alloway cars) I couldnt be mad. The car who placed were all 500k plus builds built by huge shops.
    Caught David Freiburger checking out the car and chatted with him for about 10 minutes. Super cool guy and loved the car.
    later that day the car popped up their instagram.
    https://www.instagram.com/p/9mm64YJZGF/
    sema rollout
    sema ignited
    and thats a wrap
