Projects 49 Pontiac springs
Discussion in 'Traditional Customs' started by 49Chief308, Apr 5, 2015.
  1. 49Chief308
    49Chief308
    Hello all, I am starting on my first project. A 1949 Pontiac 2dr Fastback. I am having trouble finding much info on what works and what doesn't. I find a lot of info on 49-54 Chevys, not so much for Pontiacs. My rear p***enger leaf spring is broken and am trying to find out if the Chevy rear springs are the same dimension? I am going to be lowering the car, and would rather just buy the Jamco lowering springs for the Chevy cars instead of having to have custom springs built for the Pontiac. Does anyone know if the Chevy springs are the same, or where I can buy springs for the Pontiac? I am not opposed to using blocks with a stock spring either. I found a set on California Pontiac Restoration, but don't really want to spend that kind of money for stock springs. My other thought was to find out if any later model vehicles might have the same spring rate/dimensions as the Pontiac and just get a set from my local junkyard. Thanks in advance.
  2. Slick50
    Slick50
    Eaton Springs has all the original specs for your Poncho. They also offer lowered springs front and rear. Not the cheapest maybe, but great folks to deal with, prompt service. All the right parts that fit.
    www.eatondetroitspring.com
  3. Fat47
    Fat47
    You can have springs made for your specific vehicle. St. Louis Spring Co. will do it and you may have a spring company closer to you in one of the bigger cities in Nebraska.
  4. BuiltFerComfort
    BuiltFerComfort
    And check out Jamco reviews before ordering.
    tb33anda3rd likes this.
  5. oldskool2949
    oldskool2949
    from maryland
    I have 55 chevy springs and rear in my 49 poncho
  6. mr.chevrolet
    mr.chevrolet
    measure up some S10 rears. the springs and hangers just might work out.
  7. 49Chief308
    49Chief308
    So are the 55 chevy springs same spec? length, center pin etc?
  8. kennyg1931
    kennyg1931
    I would go with the Eaton spring Co. Tell them how low you want your car to set and they will put the right arch in the springs , they are very good to work with and really good people ! good luck : Kenny G
  9. The Pontiac ch***is is entirely different from 49-54 Chevy and nothing interchanges. I can't say on 55-57 Chevy but it may work; 49-57 Pontiac use more or less the same ch***is, and the '57 Pontiac rear swaps into 55-57 Chevy cars fairly easy (said to be a bolt-in).
    An S10 4x4 rear may fit the car but has a different bolt pattern, so you'd have different wheels front to rear.
  10. oldskool2949
    oldskool2949
    from maryland
    I bought the car as a abandoned project with no rear. Another member on here had a 55 chevy rear and springs laying around so I used them to make a roller to get it home. They bolted right up and track width and all looks pretty good. [​IMG] [​IMG]
