What makes your hot rod different?
Discussion in 'The Hokey Ass Message Board' started by 30FordNerd, Nov 29, 2012.
  1. JimSibley
    JimSibley
    Because it's a chevy and the Orange motor actually matches the car. ImageUploadedByH.A.M.B.1428391486.274114.jpg
    kiwijeff likes this.
  2. JimSibley
    JimSibley
    Because it's frame, frontend, steering arms, grill, and push bumper are all polished steel with clear powder oat, because I'm to poor for chrome. ImageUploadedByH.A.M.B.1428391663.436984.jpg
    wingnutz likes this.
  3. Martin Harris
    Martin Harris
    What makes my hot rod different?
    A Triumph frame, a rear mounted Austin mini engine, a home made body, taillights made from '38 Chevy headlight pods with '64 Falcon lenses, Guide headlamp shells with more '64 Falcon inserts adapted to take sealed beams, Mack AC styled snout. That's all I can think of for now:D
  4. Moby
    Moby
    Different? Model A with
    chopped 36 International grill
    37 Plymouth headlights
    S curve pitman arm
    55-59 Chevy pickup mirrors upside down
    belt-line bead on homemade hood ending on the grill shell
  5. xpletiv
    xpletiv
    from chiburbs
    ^Different, and I really like it!
  6. LOU WELLS
    LOU WELLS
    from IDAHO
  7. Binger
    Binger
    from wyoming
    My Coupe project is running a banger and '30 chevy knee action shocks. A shocks.jpg
  8. JimSibley
    JimSibley
    Any pics? Sounds wild!
  9. indcontrols
    indcontrols
    How about a rambler sedan delivery blown g***er - there has to be something different there...[​IMG] [​IMG]
    clem, blowby, Hotrodmyk and 2 others like this.
  10. fleetside66
    fleetside66
    A 91 year old Federal-Knight truck gas tank.
  11. It's not chopped.
    Stretched and widened 3 inches
    blowby likes this.
  12. It's getting closer to rolling.
  13. There's been three Es*** mentioned so far in this thread, and they were a Hudson product, I have a 28 and 29 Hudson, not Es***. They are slightly larger than the Es***, and so far, I'm the first since this thread began, to have late twenties Hudson's.
    Guess that makes em different.:cool:
    37hotrod likes this.
  14. gwhite
    gwhite
    SUPER MODERATOR
    Ditto. Nothing different or unique here...just an old Ford with an obsolete motor, antiquated brakes, and belly-****on styling. I'm just painting by numbers.
    Ford Mike and Hitchhiker like this.
  15. KFC
    KFC
    from UK
    It's built out of parts you'd struggle to give away
  16. 50desotocoupe
    50desotocoupe
    from Denver
    blowby and kiwijeff like this.
  17. 4thhorseman
    4thhorseman
    from SW Desert
    Mine is regularly street driven, is non traditional but 60's inspired and legitimately runs low 9's. Makes the new hi-po cars look stupid off a street light.
    loudbang, deto, blowby and 2 others like this.
  18. 37hotrod
    37hotrod
    Mine's different because it is a Chevy...with a SBC motor...that was originally built and installed in a Ford...then transplanted into the Chevy.
  19. Dave Mc
    Dave Mc
    loudbang, JB_roadrage and kiwijeff like this.
  20. raymay
    raymay
    It is because I seem to always like something on my builds to be different in a one of a kind sort of way while still retaining some of the stock look.
    scan0003.jpg IMG_3057.JPG nomad44.JPG del18.jpg 10-14-2013_008.JPG IMG_2024.JPG
  21. HOTRODPRIMER
    HOTRODPRIMER
    My name is on the ***le for the second time,I bought it from the original owner,drove it,sold it and bought it back,second and forth owner. HRP
  22. 37 Dodge, only one GM part, 74 Corvette gas cap!
  23. Maverick Daddy
    Maverick Daddy
    Right now, mines different because its O.T. :(
  24. POLYFRIED 35
    POLYFRIED 35
    It is!! Sold it! :(
  25. JimSibley
    JimSibley
    Oh! I know how you feel. It was a sad day when that thing left.[emoji22]
  26. Here goes. '40 Ford deluxe coupe. All home built, with the following;
    '39 rear fenders with the tail lights turned up-side down. Orange with dark Gold and Tangerine Metal Flake.
    '65 426 Chrysler Marine short block, ported heads, '63 Max Wedge intake and '64 Max Wedge carbs.
    Stahl up-sweep dragster headers. Turned up-side down and modified to make fender-wells.
    Mufflers out of '67 Corvette side pipes. Mounted under the running boards.
    '65 Imperial push ****on trans. With '64 New Yorker ****ons in a home made floor mount.
    '67 GTX rear axle. Mounted on '68 Dodge pick-up front leaf springs.
    Stock front axle (drilled and plated), buggy spring and wish bone. With a home made wish bone mount.
    '63 Dodge brake pedal and bracket. Converted to mount a Mustang master cylinder, all under the dash.
    '68 Nova steering box on a home made bracket. '67 Corvair steering column, modified.
    C-J Jeep 4 inch dropped pitman arm.
    '66 Fury throttle pedal ***y. Modified with the cable shortened.
    Main hoop of the roll bar made out of a Police paddy wagon divider.
    All this and more is why I call the thing "Alphabet Soup". Gene.
  27. Racer29
    Racer29
    Non SBC power plant. It's running a 472 Caddy.
  28. GeezersP15
    GeezersP15
    from N.E. PA
    This makes my 48 Plymouth kinda different. The car had to be rewired, and I really like electrical work, especially panel work, so here's what I ended up with. It gets a lot of comments at car shows.:D 003.JPG
    Model T1 and patmanta like this.
  29. indcontrols
    indcontrols
    I'm a wire nut too - do very similar work, that is clean as hell !! Well done. !
    GeezersP15 likes this.
  30. 2NDCHANCE
    2NDCHANCE
    I went a different direction with my 1930 Chevy. 30-PASS-SIDE.jpg 3-=FRONT.jpg
