Technical where's the VIn number?
Discussion in 'The Hokey Ass Message Board' started by bubblesbacon, Apr 9, 2015.
  1. bubblesbacon
    bubblesbacon
    from wisconsin
    I picked up a 1940 Chevrolet pickup 3/4 ton, it has been dis***embled down to the rolling frame and cab and fenders, etc. most of the parts have been sanded and primed, frame has only one small rust hole. In taking it apart all tags and stuff were removed, we guess. My question is where on a 1940 Chevy truck is the veh. ID number? We have researched several site and have found different answers. It is not on the cowl under the p***. side of the cab, can not seem to find it on the frame? any suggestions? In Wisconsin need to have it ***led right, they are kinda picky, it does have a ***le now. Just looking for a number on the vehicle.. any help would be appreciated.
  2. On the motor, they didn't have a "vin" number and most of them were registered by the number on the engine which should be on a pad near the distributer.
    volvobrynk likes this.
  3. bubblesbacon
    bubblesbacon
    from wisconsin
    didn't come with an engine
  4. Well its going to have one isn't it? :D
    There should be some numbers on the frame probably over the rear axle or under the cab that you can use.
  5. bubblesbacon
    bubblesbacon
    from wisconsin
    it already has a ***le that has numbers, just trying to find the matching ones one the vehicle.
  6. If its an original ***le they were on the motor.
  7. squirrel
    Look on the cowl, p***enger side, for the two holes for the screws that used to hold it on. Or was it on the floor, near the p***enger side seat? 39 was on the cowl, 41 was on the floor, I don't know where 40 was.
    Anyways, the tag was held on with two screws, and it might be lost. Some states used the engine number for ***le/registration, others used the vehicle serial number (VIN).
  8. 1940 engine numbers run 2697268 through 3665902
    the numbers are located on the pad at the rear of the distributor.
    NOTE: All truck engines have a "K" prefix. Example: K*2759129
    Vehicle Identification Numbers (VIN)
    The body plate is located on the firewall under the p***enger side of the hood. The number on the plate is the Vehicle Identification Number (VIN) of the truck.
  9. 29moonshine
    29moonshine
    there should be a plate on the fire wall held on with screws kc=1/2 ton , kd ke=3/4 ton kf= 1 ton
  10. rusty1
    rusty1
    on the part of the outside cowl area that the rearmost hood side panel covers, p***enger side
