Projects Recreating the jesse lopez coupe
Discussion in 'Traditional Customs' started by jivin jer, Aug 18, 2012.
  1. Gotgas
    Gotgas
    from DFW USA
    I'll see you there, Jerry. Be nice to meet up with you at a small show and introduce myself.
  2. jivin jer
    jivin jer
    001 (4).JPG Been here before.
  3. justafordguy
    justafordguy
    from saginaw
  4. jivin jer
    jivin jer
    Well...I ain't got much, Chris went hog hunting Friday, and when I was there Thursday I got a pic of the seat. I'll check in tomorrow and see how he's doin'. I do need to get that thing back.
    grifcarnut likes this.
  5. jivin jer
    jivin jer
    002.JPG The side panels need to conform to the headliner better.
  6. Ratatouille
    Ratatouille
    from France
    I wish you well on that mission. It's not easy to have a nice result in one shot. Congratulation for your wonderfull car.
  7. jivin jer
    jivin jer
    001 (3).JPG 001 (3).JPG 002 (2).JPG 003 (3).JPG Heeeeey!, things are lookin' up. Maybe this weekend.
  8. RICH B
    RICH B
    Looking good. What's changing on the door panels?
  9. jivin jer
    jivin jer
    The original door panels had carpet on that lower area. Chris missed it and so did I when I picked it up. Dang these details!
  10. jivin jer
    jivin jer
    010 (2).JPG 012.JPG Good news/bad news. The trimmer is done, it looks veeeeerrrry nice. I can see out the windshield for the first time. I couldn't pick it up tonight, he won't be open tomorrow, so I have to wait for Monday.
    Did I ever tell you about the spotlight handle's?
    jocktherock and Peanut 1959 like this.
  11. eric54chevy
    eric54chevy
    from TEXAS!
    Spotlight handles! can't wait to try some of these techniques on my 41...great job on everything Jer
  12. BLUDICE
    BLUDICE
    O boy this should be fun!
  13. drdave
    drdave
    You can't leave us hanging now! I need to make a set for my Merc, but I'd like to see how you ended up with handles from blocks. ;)
  14. jivin jer
    jivin jer
    PA230159-vi[1].jpg This is the only pic (that I know of) that really shows what the handle's look like, thanks to Rik Hoving.
  15. rob-redm
    rob-redm
    very nice Jer ! darn , was hoping to see the finished interior... my hats off to you !
  16. jivin jer
    jivin jer
    002.JPG 001 (3).JPG 001 (3).JPG Unfortunately I haven't ***embled the (in the ruff) pics for this like the knobs, but we will press on, and I'm sure you'll get it.
    This shows what we have to deal with regarding the various components to this part of the project.
  17. jivin jer
    jivin jer
    007 (2).JPG A hole must be drilled thru the block, excess material needs to be removed. I ruff out the pear shape on my bench grinder, then use my hand held grinder with a cut down 40 grit disc, and finish up with finer and finer grades of paper on my da.
  18. hotrod54chevy
    hotrod54chevy
    from Ohio
  19. jivin jer
    jivin jer
    003 (6).JPG 004 (2).JPG 007 (3).JPG Sorry for not getting all the final steps, but here they are.
    Eric H, MUNDSTER, Olson and 2 others like this.
  20. Torchie
    Torchie
    Handles look great Jer.
    Can't wait to see those Appletons mounted.
    Torchie
  21. rob-redm
    rob-redm
  22. drdave
    drdave
    Jerry, did you make the end of the hole at the small end square to engage the shaft or just a round hole all the way through? If you did it square, how did you do it?
  23. jivin jer
    jivin jer
    002 (3).JPG The problem is solved by a tool that every well equipped machine shop has in their tool box these days, a "square" drill bit. An ingenious device that was invented during WWII to streamline some critical operations on the machines that helped produce tracked vehicles.
    Ok, I couldn't resist making contact with a well placed softball that was just hanging there. Thanks Doc. I could have used that square portion of the spotlight mechanics for the twist/turn motion that aims the spotlight itself. It would mean that if I drilled a shallow enough hole that would leave room for that heated up part to seat itself as I screwed everything together it would give me the leverage that I would need. I chose not to. Since the spotlights are mainly ornamental I can postion that part by hand outside the vehicle.
    Baby's back.
    drdave, Spanky65 and Eric H like this.
  24. greybeard360
    greybeard360
    Square drill bits..... they do exist.... :rolleyes:
    Peanut 1959 and loudbang like this.
  25. jivin jer
    jivin jer
    001 (9).JPG 001 (3).JPG 002.JPG 002.JPG Everybody remembers these? Well, they look best when they're installed.
    daddio211, Eric H, drdave and 3 others like this.
  26. Ratatouille
    Ratatouille
    from France
    Great, now you can cruise hanging your arm out the window ;)
  27. BLUDICE
    BLUDICE
    Those were the "painted chrome" pieces correct? Whats your opinion of the results??
  28. jivin jer
    jivin jer
    343.JPG 343.JPG 344.JPG 345.JPG It was better to have Don redo these than make new ones. They still need to be handled with kids gloves.
    Well I need to keep this from getting too boring. With an advanced case of CRS getting everything together requires patience and a plan b always at the ready. With two weeks before "the big shew" everything is looking good. I have a new seal in the vent hole, and cleaned up the part that you rarely ever see.
  29. drdave
    drdave
    That makes sense and is much easier than making a square hole. I was following all along with you about the square drill bit (having seen the ones for wood posted above) amazed that the corners of those wood bits cut into the plastic. LOL
  30. rob-redm
    rob-redm
    thanks for sharing Jer, looking great sir !
