Technical Carb Spacer Material
Discussion in 'The Hokey Ass Message Board' started by trades707, Apr 9, 2015.
  1. trades707
    trades707
    from Oregon
    One of my brainy ideas is to put a two barrel GM throttle body injector on an aluminum manifold where a three mounting hole Stromberg is supposed to be. GM has three holes, but of course they don't line up. So I was thinking of obtaining a 3/4 to 1 inch aluminum plate and drilling holes for the throttle bores, three recessed holes to bolt the plate to the carb mount pad, and tap three holes to mount the GM body. Then someone suggested plastic or wood. Wood would be easier to work with and it shouldn't be too hot on the manifold (no heat riser). Anyone think wood might be a problem?
    Thanks
    Abe
  2. draggin'GTO
    draggin'GTO
    You're making a thick carb adapter, not a spacer.
    I would use aluminum.
    If it were simply a spacer hardwood would be fine.
  3. johnny bondo
    johnny bondo
    from illinois
    im confused do you need something to block the heat? use phenolic spacer material
  4. stimpy
    stimpy
    we used hardwood all the time ( ash or maple ) . after your done machining it , seal the throttle bore areas with gasoline proof epoxy and also make sure your heat riser works properly otherwise you can smoke it .
  5. bobss396
    bobss396
    I like to use phenolic myself. Machines easily and is a poor conductor of heat. Depending on how much strength you need and possible thin sections, you may be better off with aluminum.
  6. 325w
    325w
    Use a good grade of alumnium. Had a throttle body adapter that was cast. It would allow the gasket to blow. Took the adapter to work and one of the tooling guys made me one from some stock. It lasted.
  7. Andy
    Andy
    I have used long strand fibergl*** filled bondo(kitty hair). I make a form for the outside and put it on a flat sheet. Another flat sheet is pushed down on the mess before it hardens. Use masking tape or mold release so it comes apart.
  8. saltflats
    saltflats
    from Missouri
    If you are going to use the TBI injection I don't think heat is going to be a problem.
  9. BobWright
    BobWright
    from Poconos PA
    Has anyone tried using Pyrolytic graphite? It is a insulator in the z direction and a conductor in the x and y direction. So it would insulate between the carb and the manifold. There might be some benefit in the conducting ... maybe putting heat in or pulling hest out. Any thoughts?
  10. Timbofor
    Timbofor
    Most everyone seems to be missing the fact that he wants to drill and tap the adapter to bolt the throttle body to. It's a fine thread metric bolt. If he wanted to use something other than aluminum he would have to add an insert to the back side further complicating the thing. I personally would use aluminum. It's easy to machine, threads won't pull pull out unless you get stupid with it and it works well.
  11. Wood will work OK, be sure to seal it up really well. In my time I have even made carb adapters out of cardboard, lack of money and late at night were probably my excuse on that one. Didn't work as well as other materials but it worked to get me where I was going at the time.
    Anyway wood will work, not as well perhaps as other options but it will work OK.
