Technical clutch problem
Discussion in 'Traditional Hot Rods' started by donga, Apr 12, 2015.
  1. donga
    donga
    ford 4os 3 speed. when looking through inspection cover pedal slightly depressed throw out hub rotates then no clutch wondering weather bearing slightly seized or need stronger return spring
  2. timwhit
    timwhit
    Is the clutch engaging and disengaging? Tim
  3. donga
    donga
    yes clutch engages and gear select ok
  4. krylon32
    krylon32
    from Nebraska
    I would think that if the TO brg hub is rotating it is not being secured into the fork indicating that the internal return spring is either not hooked or broken?
  5. donga
    donga
    have replaced spring
  6. 48-760
    48-760
    from OH
    The throw out bearing hub has flats on the side and rest between the two fingers of the throw out fork and can rotate if it did rotate the small return spring would be ripped off. With the pedal at rest and back against it's rubber bumper there should be about 1-1/4" of free play (adjustable) at the pedal pad before the bearing touches the fingers of the pressure plate and the bearing starts to rotate on the stationary hub.
