Technical Pesky steering box leaks due to heat
Discussion in 'Traditional Customs' started by 51cambridge, Jan 18, 2015.
  1. HVSpeed
    HVSpeed
    Use Penrite Steering Lube or an equivalent. Gear oil won't stop leaking, till it's all on the floor .
  2. 51cambridge
    51cambridge
    Ok drilled a vent in filler cap. Seems to relieve some heat. Have some fluid comming out of it when hot. ****ed all oil out. Added a few pumps of grease, Topped off with stp oil treatment. Haven't had to add since I did this. Thanks everyone!
  3. indyjps
    indyjps
  4. 51cambridge
    51cambridge
    Good idea, so far no leaks
