Technical *** April 2015 Banger meet - no fooling!!!***
Discussion in 'Traditional Hot Rods' started by Jiminy, Apr 1, 2015.
  1. Jiminy
    Jiminy
    Here is the banger link list .
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Flat Ernie maintains the monthly link list. Every month is listed:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    Post #105 of link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=6
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://www.centuryperformance.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    http://www.scribd.com/doc/22469332/The-High-Speed-Internal-Combustion-Engine-Ricardo-1931
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
  2. RussTee
    RussTee
    Thanks Jim always look forward to the banger meet to keep in touch with the tech other than the more general banger page on facebook.
  3. nosdan
    nosdan
    Question for the group: Added a 6:1 head, Mallory dizzy, burns single df w/ 97. Runs out pretty good but it has some hesitation at lower rpm, I'm ***uming I may need to try small jets to compensate? Any other recommendations... Runs like a top at higher rpm. Thanks. Here's a pic of intake/carb, before dizzy and head. Thanks!
  4. slackcat
    slackcat
    Thanks for the photo. Been thinking of switching to a downdraft this summer, will have to research it more.
  5. I'd start with a 43 jet and up one spot from standard on the power valve. Say a 64 or 65?
  6. Crazydaddyo
    Crazydaddyo
    Thanks for the link.
  7. nosdan
    nosdan
    Thanks hotrodfil.
  8. modelAsteve
    modelAsteve
  9. Yeah, well worth doing a plug check before changing jets. A couple of runs down the road, one at speed and the other at your hesitant lower rpm point, killing the motor and coasting to a halt will tell you something.
  10. nosdan
    nosdan
    Good point!
  11. orangeamcs
    orangeamcs
    What is the best way to install a model b engine and transmission in an A? I eventually want to use a 32 k member, but for now I was thinking of getting parts from clings for mounting the pedals and wishbone. I am ***uming I can use the stock front mount from my A motor? This leaves me with the rear motor mounts. The rear float a motor kit from berts model a is no longer available. Anyone have a place I can get that kit for rear mounts from or a suggestion on what else to use? I am ***uming Ill need a v8 clam shell also? Hopefully I am on the correct path with this. Trying to source all the parts before I take my car apart. Thanks
  12. nosdan
    nosdan
    The intake has two bungs that are all the way through the wall for linkage and accessory. So I re-installed the screws coating them with silicone and that seems to have made a huge difference in response at low rpm. I'll run it some more and see what the plugs are telling me. Thanks guys!
  13. Anyone have a banger Mallory distributor to part with?
  14. Freemoe
    Freemoe
    from Fowler, CA
    Anyone know what type of water pump this is, trying to see if I can rebuild it? Tried to compare it to stock water pump but they seem different. Don't want to buy a leakless if I don't have to. The water pump doesn't leak but does squeal. The generator has been eliminated as a cause since it was changed out to an alternator and the water pump has already been greased.
  15. ebtm3
    ebtm3
    That's a old after market pump, one of the early ''leakless'' variety. Squealing is something inside that is running dry, perhaps the seal has finally on it's way to dying. Good pump when they worked, I always looked for them on junk engines. Take it apart and look it over. No parts--unless you make them, or or harvest from another pump of the same make---available.
    Bottom line is go with modern leakless.
    Herb K
  16. Freemoe
    Freemoe
    from Fowler, CA
    That's the exact info I needed. Thank you!
  17. Snyders makes a nice one that's leak less and greaseless with a modern seal. I run one of these. After having rebuilt two cherry housings and have them only last a few 100 miles. I wish I would have just bought the Snyders pump to begin with.
  18. Bluto
    Bluto
    Happy April
    BCCHOPIT, Cris and Jiminy like this.
  19. kiwikid
    kiwikid
    hi guys, pretty new to this banger stuff , looking to make an intake , will use a single 97 what size runners would ou use , an one got some pics they would care to share thanks in advance
    skryla likes this.
  20. Leon Sandcastle
    Leon Sandcastle
    What year and make of banger?
  21. kiwikid
    kiwikid
    Hi just a 30 model a looking to make a single carb intake
  22. kiwikid
    kiwikid
    anyone ...... keen to see pics of homemade intakes and know what size pipe you used cheers
  24. I finally added hubcaps. I had a friend detail the Ford Ovals for me.
    That's my son's car seat. My Coupe doesn't have high back seats.
  25. denis4x4
    denis4x4
    from Colorado
  26. I blasted the Ford green off the cylinder head and gave it a couple of coats of yellow. It is now an official Winfield yellow head. :cool:
  27. waxhead
    waxhead
    from West Oz
  28. ebtm3
    ebtm3
    It's not the color that makes more horses-----
    Herb
  29. RichFox
    RichFox
    Cris, Jet96, CrazyUncleHarry and 2 others like this.
  30. colinsmithson
    colinsmithson
    Thanks for the info Rich
    Now I know how to get that last few HP
    (paint it yellow)
