Projects 1930 model a coupe build
Discussion in 'The Hokey Ass Message Board' started by icecube, Feb 26, 2015.
  1. volvobrynk
    volvobrynk
    from Denmark
    I've been eyeballing a tractor paint enamel, I would love to use.
    It's a Fordson blue, and looks a little more shiney, but not deep shiney
    If you use a thick layer of shop primer, re spray it three times, and grind in between and with 200-500-600-800grit and give it a last shot that's mixed 1:4 with a clear. Some brand needs to have hardner in the clear, before mixing.
    That would give a coat of paint that's cheap, doable, DYI material and can look like a old paint job. But not something that set you hard back, or you have to scared sh1tless of leaving in a parking lot.
  2. icecube
    icecube
    from Kuwait
    quick update
    a friend of mine told me that flat colors are not allowed in Kuwait any more ?
    so i sprayed the car with FJ cruiser blue metallic, what do you think?
  3. icecube
    icecube
    from Kuwait
    this might a stupid question , but how to start the engine on 30 coupe?
    also there is no accelerator pedal , how can i accelerate ?
  4. To start a stock 4 banger there is a small ****on you press with your foot on the toe board, the ignition switch just sends power to the ignition coil. Theres a pair of levers on the steering column, one is a throttle lock (think early cruise control) and the other is for ignition advance and retard, I think you want to set that lever somewhere in the middle, I can't remember as I've only started a stock Model A once and that was a while ago. Sounds like the throttle linkage is missing but theres a small pedal for that to the right of the brake pedal towards the center of the toe board.
    volvobrynk likes this.
  5. KiwiGlen
    KiwiGlen
    I've never owned or driven a model A so can't help from experience, but this video might help. It doesn't get into the starting sequence until a couple of minutes in…
    The blue you painted your coupe looks great :)
    Glen.
  6. icecube
    icecube
    from Kuwait
    good news i managed to start the engine , runs ok but it leaks water from the the top.
  7. pat59
    pat59
    That realy your ride leaking that water? Dang thats a leak and a half. :eek:
  8. vtwhead
    vtwhead
    looks like the head was frozen at one time without antifreeze in it.????? Wonder what else may have happened?
  9. icecube
    icecube
    from Kuwait
    I have no idea what went wrong.
    The problem is that I was going to toss this engine after p***ing the DMV inspection.
    No I have to repair it first .that's few $$$ down the drain.
  10. mike bowling
    mike bowling
    stock heads are short money- they're just heavy ( to mail). maybe that's all you need? start with the simple (cheap fix) stuff. If you're going to ****-can the banger anyway, patch it together enough to get it on the road and kiss it goodbye. If you need a gas pedal set-up, post it - they're cheap AND light( and I have a spare) Good luck with it
  11. icecube
    icecube
    from Kuwait
    finally i managed to register the model a :)
    since i decided on painting the car blue, i thought of giving it some patina , so i was experimenting a little
    feedback appreciated
    red oxide
    white
    dark blue
    light blue
    final result
    after 1000 sanding and clear coat
  12. icecube
    icecube
    from Kuwait
    more pictures of the project ,
    painting the frame and suspension
    and rebuilding the engine
    IMG-20150324-WA0011.jpg IMG-20150406-WA0021.jpg IMG-20150418-WA0016.jpg IMG-20150418-WA0015.jpg IMG-20150418-WA0014.jpg IMG-20150413-WA0012.jpg IMG-20150413-WA0009.jpg IMG-20150406-WA0022.jpg
    AHotRod likes this.
  13. icecube
    icecube
    from Kuwait
  14. icecube
    icecube
    from Kuwait
  15. Roger53
    Roger53
    Hi lookin good color is a nice blue give it a little ageing and have funwith it. Very good choice of motor. Roger
  16. icecube
    icecube
    from Kuwait
    Thanks Roger53
    paint completed, started the ***embly
    IMG-20150419-WA0006.jpg IMG-20150419-WA0006.jpg IMG-20150419-WA0007.jpg IMG-20150419-WA0008 (1).jpg
  17. icecube
    icecube
    from Kuwait
    frame on the ground , not bad for 1 day :) IMG-20150419-WA0017.jpg IMG-20150419-WA0017.jpg IMG-20150419-WA0018.jpg IMG-20150419-WA0022.jpg IMG-20150419-WA0019.jpg
    Hotrodmyk likes this.
  18. icecube
    icecube
    from Kuwait
  19. icecube
    icecube
    from Kuwait
    Engine is ready.
  20. icecube
    icecube
    from Kuwait
  21. Dino 64
    Dino 64
    from Virginia
    Looks great. Just love those 289's. Was just wondering why you have a clutch pedal if you're using an automatic ****** ? Frame looks really good. It's really coming together. Keep it commin'
  22. icecube
    icecube
    from Kuwait
    Thanks Dino64 .
    I am using a manual t5 ******.
  23. icecube
    icecube
    from Kuwait
    Christmas came early this year...
    air cleaner just arrived .
  24. badshifter
    badshifter
    Looking good. I don't know about that air cleaner though....But you need Residual Pressure Valves in your brake line set-ups while it's easy to get to, you should put a brake light pressure switch in line as well.
  25. icecube
    icecube
    from Kuwait
    badshifter , thanks
    pressure valves and pressure switch already installed.
  26. belair
    belair
    congrats on your car. you are making good progress. have fun.
  27. icecube
    icecube
    from Kuwait
    Belair .thanks.
  28. Dino 64
    Dino 64
    from Virginia
    Looking good. Are you using a hydraulic clutch ? I want to do a manual on mine, but I have not experience with a hydraulic clutch. Great progress, keep it up. .
  29. icecube
    icecube
    from Kuwait
    Dino64
    yes i am using a hydraulic clutch . easy conversion , i usually use http://dazecars.com/
    easy bolt on, done few conversion my self on 65, 67 mustangs and T5.
  30. Dino 64
    Dino 64
    from Virginia
    Ice, thanks for the link. I hope you will show some detail of the clutch install. I like your new avatar. Great thread.
