Customs 51 Merc -- Body OFF -- Custom Chassis
Discussion in 'The Hokey Ass Message Board' started by enfieldjoe, Aug 13, 2011.
  1. redroaddog
    redroaddog
    try buffing a spot before you clear i think you will find you don't need it for depth. we used clear over metalic colors so you didn't buff thru the coats causing bull's eye's or rings you could see in the metalic. clears fine but just adds more material to the finish and not needed. i also think it shortins the life span of black lacquer from the heat of the sun.sprayed a lot of lacquer in the day. i have done black by color sanding clean it up then mixed thinner and some retarder sprayed a coat on to seal the sand scratches let it set for at least 2 weeks buffs like ****er and looks a mile deep....Dave:cool:
  2. redroaddog
    redroaddog
    forgot to mention just tinner and retarder no color doesn't hurt the paint did a model a for a guy he had it 15 years before he sold it always looked like the day it left the shop:cool:
  3. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Thanks for the advice. Wanted to spray clear only to prevent any scraches from washing.
  4. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Thanks! It is a stroker 347ci, full roller motor, and Trick Flow heads.
  5. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Hope not. Bought the paint from Hawthorne Paint in NJ. Trinity 1945 sells it.
  6. Tnomoldw
    Tnomoldw
    :)Great work , keep it up:cool::D
  7. RR496
    RR496
    Your Merc is shaping up nice! Great job on your build. Keep up the great work!
  8. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Thanks to all for the positive words!
  9. ph8ed4life
    ph8ed4life
    from AZ
    In for some driving pictures!
    It looks way amazing, congrats on the hard work!
  10. GonzoMN
    GonzoMN
    Beautiful looking project.
    Any update?
  11. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Stripped all the paint and bodywork performed last year. In the process of Round #2 with bodywork and paint effort.
    All bodywork is now complete. Merc is now in DP90 & K36 primer. Next step is to final sand. Then going to shoot base coat/clear coat paint system.
  12. outlaw1949
    outlaw1949
  13. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Clear lacquer would not buff out. Stripped all that lacquer.
  14. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Body work just about complete. Spraying K36...again.
  15. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Merc is finally in color, which is Ice Cap Blue. Almost finished with cut n' buff. ImageUploadedByH.A.M.B.1428705291.629985.jpg
  16. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Installed the tail lights & rear window today. Also finished off the rear bumper with the bumper guards over the license plate.
    ImageUploadedByH.A.M.B.1429655032.144346.jpg ImageUploadedByH.A.M.B.1429655047.187870.jpg ImageUploadedByH.A.M.B.1429655063.141866.jpg
