  1. lowcoe
    lowcoe
    Thanks Moose. Can you take a little more of the bulge out of the top rear roof area on the one with the extended catwalk. Al a Drivin fords 37 ImageUploadedByH.A.M.B.1429629971.356336.jpg
  2. themoose
    themoose
    madfish likes this.
  3. lowcoe
    lowcoe
    Thanks moose!!
  4. bubblesbacon
    bubblesbacon
    from wisconsin
    lowered, chopped and shortened..... :) Econoline_Sectioned.jpg
  5. CHARLIE_HUSTLE
    CHARLIE_HUSTLE
    from CHICO CA.
    Thank you so much fellas! Now that I see it I'm thinking 14" steel wheels in Orange with beauty rings & spider caps.. Thanks again.
  6. atomickustom
    atomickustom
    I hate to be a jerk, but maybe you should work on the contour of the door some more before you try matching the roof to it? It seems a bit wonky in the photos.
  7. lowcoe
    lowcoe
    Thanks. Not a jerk. The shape kinda just happened when I was doing the sedan to coupe transformation and I thought it was ok. Now I'm not so sure. I lengthened the doors about 5 inches which throws things off a bit. Maybe Moose (pretty please) could photoshop the good 3 window coupe window in from the pic I supplied. It would need to be stretched a bit. I like going back more on the catwalk. Then make the roof to match. ??
    Heck while your at it skirt white walls and caddy hubcaps lol..
  8. paul55
    paul55
    from michigan
    If you switched the window openings side to side, I think the profile would be close to what you're looking for. Of course it would require more work to the roof line in order to match new door opening. Just a thought.
  9. lowcoe
    lowcoe
    It's only metal right?
  10. deuce1932
    deuce1932
    from Australia
    rotate door tops a little bit will help your roofline a lot... not a big job. extended roofline.jpg
  11. themoose
    themoose
    Low resolution but you should be able to get some idea of how it would look
    madfish likes this.
  12. themoose
    themoose
  13. madfish
    madfish
  14. Chaz
    Chaz
    Thank you so much.....! You guys are amazing! How about a black vinyl top? That's another thing we are pretty sure we want.
  15. Toymont
    Toymont
    from Montana
  16. lowcoe
    lowcoe
    Thanks Moose and Deuce. The last two are posted on my thread and people are sounding off. You all are providing a noble service de uglifying cars. Many thanks.
  17. paul55
    paul55
    from michigan
    A good friend wants to change his car a bit and we're wondering if someone could do painted 06-14-09_0914[1].jpg steel wheels with '48 caps/rings. Wheels painted body color and one with wheels painted black. Black-wall tires. Thank you very much in advance!!
  18. DeadGuy2
    DeadGuy2
    WOW! Nice car..... That's one of my dream cars there. (powered by a flat head though)
    Nice ride indeed.
  19. themoose
    themoose
  20. paul55
    paul55
    from michigan
    Thanks Moose! And I haven't forgot about ya. Paul
  21. Flamed48
    Flamed48
    What would the chevelle look like with this stance and wheels ?
  22. KiwiGlen
    KiwiGlen
    Centurion9 likes this.
  23. atomickustom
    atomickustom
    Holy cow, that car started out as a sedan?! Nice work so far!! Definitely work the door some more - you've come so far, might as well make it perfect.
    Is there a build thread on it?
  24. paul55
    paul55
    from michigan
    Moose, how about trying silver wheels w/rings&caps on the gold model A above, and maybe these? Thanks,Paul images (9).jpg images (8).jpg
  25. themoose
    themoose
    madfish likes this.
  26. lowcoe
    lowcoe
    Thanks Type "screw it" into the search box on the HAMB and it should pop up.
    Edit. That didn't work. Try "screw it, I'm gonna go for it! 36 ford coupe to be". And that should work. Or just look me up...
  27. paul55
    paul55
    from michigan
    Thanks Moose! I think the painted body color is the way to go. Paul
  28. lowcoe
    lowcoe
    Ok I made all the changes except moving the roof back onto the catwalk... Can someone dress this up in bare metal and extend the rear of the roof back about 5 inches again. Add rear fender that is a bit longer than stock. Big and swoopy. Skirt www,s. Sombreros. Thanks in advance. ImageUploadedByH.A.M.B.1429993739.087558.jpg
    Sorry door won't close just yet.
  29. madfish
    madfish
  30. themoose
    themoose
    Sanded off the rust:)
    madfish likes this.
