Projects Long time no post
Discussion in 'The Hokey Ass Message Board' started by Toddjg, Apr 24, 2015.
  1. Toddjg
    Toddjg
    from florida
    I have my 1950 Tudor I pulled the flathead and trans I put in a 302 ford c4 trans crown Vic police drive shaft getting ready to start next is radiator belts pulleys hoses shifter throttle has 650 carb edelbrock intake I change the 1984 serpentine to v belt and had to install clock wise water pump stock rear is hooked up now till I can get 9 in put together 9 in from a 80's Lincoln
  2. Ok then looks like you are movin right along.
  3. HOTRODPRIMER
    HOTRODPRIMER
    The only problem I encountered with my 84 serpentine swap is finding pulleys that would work after I replaced the water pump,,I ended up having to use March billet (ugh) pulleys but they fit and do the job. HRP
  4. Toddjg
    Toddjg
    from florida
    The sepentine did not look right on a old car I'm planning on aluminum radiator flex fan
  5. Toddjg
    Toddjg
    from florida
  6. raidmagic
    raidmagic
    Very cool. Keep plugging away
  7. 270dodge
    270dodge
    from Ohio
    Keep us posted.
