Event Coverage Live from Austin, Lonestar Roundup 2015
Discussion in 'The Hokey Ass Message Board' started by Tom davison, Apr 18, 2015.
  1. Tom davison
    Tom davison
    from Phoenix AZ
  2. superprojoe
    superprojoe
    from Illinois
    AWESOME.....i got to hit this show in 2016!!
  3. richie rebel
    richie rebel
    as usual top notch photos,thanks for sharing tom...........p.s. f.... satan
  4. 50Fraud
    50Fraud
    What a beautiful avatar you have!
  5. 29bowtie
    29bowtie
    Well Tom, what can I say, your photos are spot on for what this site is about and the quality is superb as usual. Thank You!
  6. Tom davison
    Tom davison
    from Phoenix AZ
  7. Tom davison
    Tom davison
    from Phoenix AZ
  8. timwhit
    timwhit
    I just never get tired of looking at your pics Tom, thanks for all the work and the expense of going to different events. Tim
  9. 24 Dodge
    24 Dodge
    Tom your photos are awesome, hope to make this show next year.
  10. Tom davison
    Tom davison
    from Phoenix AZ
  11. Tom davison
    Tom davison
    from Phoenix AZ
  12. Tom davison
    Tom davison
    from Phoenix AZ
  13. blowby
    blowby
    from Nicasio Ca
    Beautiful stuff. Can anyone explain why the scoops on the dragsters face forward and all the others backwards? Is there some speed at which forward is better?
  14. Dick Stevens
    Dick Stevens
    I'm not an expert on aerodynamics and how it affects air flow, but I think it has to do with the fact that dragsters don't have windshields and how that affects air flow over a vehicle.
  15. joeycarpunk
    joeycarpunk
    from MN,USA
    Thanks for the great pictures, I really appreciate the time and effort it takes to put these together.
  16. Mazooma1
    Mazooma1
    I've experimented using both directions.
    When driving across country with six carbs I found that having the scoops backwards caused better air flow than having the scoops facing into the wind. My guess as to why this worked better probably has to to with turbulence caused by too much air trying to force itself into a limited area at higher speeds.
    There is also an air flow benefit to have rear facing scoops in that speed creates a small amount of "vacuum" behind the scoop at freeway speed thus encouraging air to travel into the carb more freely.
    Each application may differ due to different sizes of scoops, air flow over the engine based on whether you have a hood or not, firewall proximity and the speed you are traveling at.
    No two cars, engines, spacial differences, speed and air temperature are ever identical, and yes, air temp does play a factor if you are really going to get picky.
    Another simple reason why some are backwards is just keeping "junk" (dirt, bugs, etc.) out of the carb while traveling.
    As said each car and it's unique elements play into how best this works for any given car.
    Some might work better forward and some better facing the rear.
  17. Uncle Bob
    Uncle Bob
    from Salado, Tx
    Man..................that pic says a lot!!! Great eye Tom...........
  18. MUNDSTER
    MUNDSTER
    I LOVE that picture!
  19. Tom davison
    Tom davison
    from Phoenix AZ
  20. Tom davison
    Tom davison
    from Phoenix AZ
  21. Tom davison
    Tom davison
    from Phoenix AZ
  22. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    I may have a bit of info to add here. In the case of Dragsters their throttles are either wide open or closed where as a Hot Rod while driving down the road has the throttle blades just a bit open thus with the scoop facing forward there may be too much air being forced into the carb for the amount of throttle opening.???
  23. 50Fraud
    50Fraud
    Tom, I think you liked that Nash a lot!
  24. Tom davison
    Tom davison
    from Phoenix AZ
    I appreciate it, Tony.
  25. Tom davison
    Tom davison
    from Phoenix AZ
  26. lucas doolin
    lucas doolin
    And I appreciate the nuance. Who woulda ever thought! "Man that car's really something ... it's something else."
  27. MercDeuceMan
    MercDeuceMan
    from Indiana
    That Nash is the coolest new car to come along in a while.
  28. ct1932ford
    ct1932ford
    Nice shots of some nice cars! Thanks
  29. chaos10meter
    chaos10meter
    from PA.
    Great photos.Thanks
  30. OL 55
    OL 55
    Good stuff Tom. As you know, I had to cancel at the last minute attending this show so thanks for giving me a good look around. :)
