Projects 1957 Corvette M/SP Project
Discussion in 'Traditional Hot Rods' started by Baron, Jun 7, 2013.
  1. jimdillon
    jimdillon
    Baron I agree the stance looks perfect. Looks great.
    els and Baron like this.
  2. elgringo71
    elgringo71
    Great work and a mean stance, I can't wait to see it get painted and put back together.
  3. 55chieftain
    55chieftain
    Looks great Baron, can't wait to see it done. Bill
  4. Baron
    Baron
    Thanks for the comments guys. Been thrashing on the car this past week. Friend of mine let me use his spray booth for a few days while he is on vacation. This gave me time to paint the engine compartment and paint the dash. I also was able to get some color on the jams on the top lid cover and get the top in primer. With all this done, now I can bolt on the top lid cover , cut the holes for the roll bar to p*** through, and weld the roll bar in and install the motor. I hope to install the motor this coming week-end . The headers are out to be coated, the 57 Olds housing is out being sandblasted and I have a set of 4.10's / 35 spline spool coming . Plenty to keep me busy, to say the least. :D
    els, enfieldjoe, lawman and 4 others like this.
  5. Love seeing this car coming together.
    els likes this.
  6. elgringo71
    elgringo71
    Fantastic, this car is going to be a knock out. It sits right and is being built like it would have been back in the 60s with the owner finding a car that needed work and building it himself the way he wants it. It's a seldom seen color but it looks good.
    els likes this.
  7. Finn Jensen
    Finn Jensen
    The car is coming together very nicely. I'm envious, and wish that I still had my 57 Corvette.
    els likes this.
  8. Baron
    Baron
  9. enloe
    enloe
    from east , tn.
    WHEN WILL WE GET TO SEE A PIC OF THE FINISHED MOTOR?
    els likes this.
  10. Baron
    Baron
    Hopefully tomorrow night.
    els, RileyRacing, enfieldjoe and 2 others like this.
  11. olcurmdgeon
    olcurmdgeon
    Baron, hopefully see you on Sunday, will throw that old chute pack in the car to bring down.
  12. enloe
    enloe
    from east , tn.
    els likes this.
  13. Steve Norton
    Steve Norton
    Looking great, hope mine turns out as nice. Engine will be a killer on yours will be the old school look with the duals.
  14. Baron
    Baron
    The motor went right in today with no problems. I had left the transmission in the car as they are tuff to get in and out with the x-member being right in the way. Sometimes this method works well and sometimes not so good. Lucked out today. Little bummed out as the scoop I have saved all these years is not tall enough to fit. I can either cut the scoop and make it an inch and a half taller, use a different scoop or buy a new tunnel ram (new ones are 3 inches shorter). Plenty of time to decide while I continue putting this together.
    Corvette motor in 4 17 b rs.jpg Corvette motor in 4 17 d rs.jpg Corvette motor in 4 17 e.jpg
    els, kiwijeff, Rat Sass and 7 others like this.
  15. enloe
    enloe
    from east , tn.
    AWESOMENESS
    els likes this.
  16. Dick Stevens
    Dick Stevens
  17. Fulvia
    Fulvia
    That's incredible. Loss for words.
    els likes this.
  18. bajabob
    bajabob
    from socal
  19. ME.GASSER
    ME.GASSER
    Baron I would like a ride in that when you get it done please.
    Baron likes this.
  20. Steve Norton
    Steve Norton
    Are the new scoops from speedway taller? I ordered one for mine, but I may be sending it back.
  21. Baron
    Baron
    Thanks guys.
    Absolutely Larry. Maybe at the Hot Rod Reunion ...
    Hi Steve. They are the same height. I decided to go with the new Weiand tunnel ram . It is about 3 inches shorter than the TR2 X and I really like the looks of my old scoop on the car. I thought about modifying it to make it taller, but 2 1/2 - 3 inches will really block my vision.
    els likes this.
  22. enloe
    enloe
    from east , tn.
    Are you coming to Bowling Green in June?
    els likes this.
  23. That's a lot of blind spot Baron. I'm thinking that 3 inches lower might keep you out of a bad situation some day.
    Just sayin'
    Baron likes this.
  24. Baron
    Baron
    Unfortunately, I am unable to take that much time off. But I will be going to the Hot Rod Reunion in Epping NH. Less than an hour from my home. :)
    Hi Jim. You got that right. At 6 and a half inches, this scoop just makes it ( no worse than my 55 or my Chevy II). Corvette  4 11 15 007.JPG
    els and ME.GASSER like this.
  25. enloe
    enloe
    from east , tn.
    lucky
    els likes this.
  26. II FUNNY
    II FUNNY
    Just seen this one...twins.
    els, quick85, Rat Sass and 4 others like this.
  27. vetrod62
    vetrod62
    Wow, Baron, you finished your car real quick. Nice touch putting a girl in the shot with a 60s bathing suit. :)
  28. Baron
    Baron
    Thanks. Had not seen this one before. Good looking car, terrible color choice for the flames.
    Hey Jim. Wish I was that quick ! Wonder what the good looking girl in the bathing suit looks like today :rolleyes:
    The new Weiand manifold arrived today. Not quite as ***y as the old Edelbrock, but everything fits under the scoop and it will probably be better mannered on the street. And usually the only time my hood is open is when I checking the fluids.
    els and 62hotcat like this.
  29. Baron
    Baron
    Put on a new set of Firestones today. The whitewall showing on the inside bugged me and although the 205 - 15's look good on my 55 Chevy, they looked too big on the Corvette. These also brought the front end down another inch.
    els and enloe like this.
  30. Baron
    Baron
    Had a couple of productive days . Installed the new intake and carbs. Bolted the fuel pump, water pump, pulleys and fan on the motor. Looks like the fan is in the right location for the stock radiator shroud. Hopefully it will be enough to cool the motor. If not, on to plan B. Also removed the front radiator support , prepped , painted and re-installed it and finished the front frame spreader bar, painted that and that is all bolted in.
    els, Rat Sass, pitman and 1 other person like this.
