Projects 1950 Ford shoebox speedometer
Discussion in 'Traditional Customs' started by edisonfire, Apr 15, 2015.
  1. edisonfire
    edisonfire
    Does anyone know a Speedometer that will fit in the stock hole? i have moved the oil/volt/temp to the middle of the dash using old clock housings. but now i want a large speedometer to fill the hole. any thoughts? It looks like its a 5.75 opening. most of the ones i find that big are combo gauges.
    Thanks!
    Old Tom 75 and vwdave30 like this.
  2. tedley
    tedley
    from canada
    I just used the stock speedo but eliminated all the other guages in the panel. hardly noticable and looks right to. You also get to keep the hi beam indicator and signal light indicators. 50 ford 418 (Large).jpg
    Ratchet57 and Cooon like this.
  3. vwdave30
    vwdave30
    I dont know what speedometer will work but i really like what you did with your other gauges
  4. dan c
    dan c
    x2
  5. edisonfire
    edisonfire
    Is that a 51 speedometer? I like that the speedometer is on the outside an much bigger than the 49-50.
    Thanks! i need to do one more for fuel and move the airride gauges to the glove box.
  6. tedley
    tedley
    from canada
    Yes i used a 51 dash in my 50 but if you take the speedo out i think they are the same size
  7. Kiwi 4d
    Kiwi 4d
    In our 49 we are using a moon speedometer in the original housing . We simply cut a neat hole in the original cluster so the original speedo is gone the old non functional oil water and fuel are still there. The moon speedo fits perfectly over the old face. This way you can choose to go electronic or cable.Our old gauges are non functional with new ones below the dash.
  8. Tedley's has my vote. You could also paint the grey inner circle black to make it blend in more. Looks great either way.
  9. edisonfire
    edisonfire
    Picked up a 51 speedometer today. Will post pics of the install when i get it done. thanks for the ideas!
  10. zefa46
    zefa46
    from Bolton uk
    Hi Any update on the 51 speedo
  11. Buddy Palumbo
    Buddy Palumbo
    I'm curious about it as well
