Cleaning aluminum tranny, screwed up...
Discussion in 'The Hokey Ass Message Board' started by Stevie Nash, Apr 26, 2015.
  1. 27sedan
    27sedan
    from courtenay
    It's zinc chromate primer. It's usually yellow or green. I use endura aluminum cleaner them endura alodine wash, and zinc chromate primer. Never peels
  2. stimpy
    stimpy
    the guy didn't bake them to remove the residue used a can of spray ( product called hogwash was High volume Perc and no longer around ( thanks EPA ) and washed them off then ***embled the motor ,they fractured like a hydrogen embrittled bolt , I kind of have the feeling that the rods had a alloy contamination as they were cheap $$ , but when we were in school we were told never to clean ***anium with anything chlorine as it can spontanious combust while drying and it also had special handling characterisitics ( oil all threads or you will never get them apart ) . I never played with the stuff other than school and the one shop I worked at , I prefer poor mans metals like aluminum and steel .
  3. pitman
    pitman
    Certain combinations of electrons...much prefer the way you tell it Stimpy.
    Let's see...Ponds, Fleishman...Pitman and Stimpy! :eek: Rogue chemists are we!
    (now back to my Cold-fusion...er Con-fusion experiments.)
  4. stimpy
    stimpy
    I am more of a practical ( testing , risk ****yses and ***essment* ) hands on guy ,not the chemist guys we had in cl*** who knew chemical bonds and what not to wash some parts with or what to wash parts with to age them and make them stronger , as our professor said your only going to learn enough here to be Dangerous ( to do your Job and recognise what might have caused the Failure ) . not to be Metallurgical chemists .
    * the guy who tells you you put the wrong size bolt in the wrong size hole or are using the wrong type of bolt for the job ( not everything uses a grade 8 bolt ) , or the hole wasn't finished properly . or you ruined a spring with weld spatter and thats why it cracked in half , ect , ect ...
  5. Roger O'Dell
    Roger O'Dell
    In the industry, clean it, then Alodine it, then zinc chromate prime it, then paint it
