Projects 1957 Corvette M/SP Project
Discussion in 'Traditional Hot Rods' started by Baron, Jun 7, 2013.
  1. enloe
    enloe
    from east , tn.
    At least someone is having a productive couple of days
    els likes this.
  2. Baron
    Baron
    Still gathering parts. Time to order the axles, brakes, wheel cylinders,drums, etc. 57 Olds rear end  2rs.jpg
    els likes this.
  3. frankenfords
    frankenfords
    from SoCal
    Have you considered sectioning the plenum on the Edelbrock tunnel ram? I have an old Car Craft mag from '72 or so with an article detailing the build on the 327 in Grumpy's pro stock Vega, and it shows that he cut the top off his Edelbrock tunnel ram and reduced the plenum size to make it work better. So that mod could be considered appropriate for this style build...and the Edelbrock tunnel rams are soooo much ***ier than the modern Weiands...
    Just a thought
    Baron likes this.
  4. Baron
    Baron
    I did think about doing that. I have so much more work to do on this car I didn't want to take the time to do it. This was a quick and easy fix. The TR2X is in the box down cellar, and maybe a project for later, after the car is up and running.
    els likes this.
  5. Baron
    Baron
    First time I've driven the 55 Chevy this year and it needed a little maintenance. You can tell they have common DNA. ;)
    els, rumblegutz, Rat Sass and 6 others like this.
  6. Dick Stevens
    Dick Stevens
    Now that is a pair to draw to!!!;):cool::D:)
    Baron likes this.
  7. seatex
    seatex
    YEAH BABY.................................That's a stable full of race horses!
    Baron likes this.
  8. Baron
    Baron
    Cut the holes in the rear lid today and doing the final fitting of the rear tubes for the roll bar. Tomorrow I will clearance the holes in the top lid, install the weather strip and bolt the panel in place for the final time before I weld the bars . Tight fit, but everything fits and there is still room for me Roll bar 5 15 15  b.jpg Roll bar 5 15 15  c.jpg Roll bar 5 15 15 a.jpg .
    els, Rat Sass, loudbang and 1 other person like this.
  9. 1934coupe
    1934coupe
    Looks good Baron! I like the way the stock seat fits, the hardtop and I haven't seen you in it but I'll take your word:D
    Pat
    Baron likes this.
  10. ME.GASSER
    ME.GASSER
    Baron this picture is way cool. Will we see you at Epping on the 24th?
  11. Baron
    Baron
    Thanks. Look forward to seeing you two next week. Should be a great day.
    els likes this.
  12. Baron
    Baron
    Thanks Pat. The stock seats just make it. Today I got the roll bar half welded in . Painted the sections that will be hard to get at now that the lid is on for the final time. The elongated slots in the rear cover gives me a little leeway to lift the lid up should I have to get under there for anything. Making progress.
    els and Rat Sass like this.
  13. Baron
    Baron
    I finally finished the roll bar today. Finished welding the down tubes to the ch***is, welded on the harness tabs, than prepped, primed and painted it.
    Corvette Roll bar finished 5 22 15 a.jpg Corvette Roll bar finished 5 22 15 b.jpg Now how cool is this. This is the friend of mine I traded my last 57 Corvette for his 57 Chevy G***er (the original Quick Trip), back in 1971.
    els, RileyRacing, enloe and 2 others like this.
  14. Rat Sass
    Rat Sass
    That is too cool! Love to see you & the 'Bird lined up side-by-side on the dragstrip one day.
    Baron the roll bar looks great. Are you gonna put side bars in or just the hoop & back braces?
    els and Baron like this.
  15. noboD
    noboD
    The 'bird needs Mercury tail lights.
    els likes this.
  16. glrbird
    glrbird
    What is the motivation in the bird, any more pic's
  17. Baron
    Baron
    472 Caddy. Stock specs are 375 HP @4400 / 525 TQ @3000
  18. ME.GASSER
    ME.GASSER
    Baron are you going to be at Epping tomorrow??
  19. Baron
    Baron
    I am. Bringing the 49 Olds tomorrow. Just swapped out the 4.11s with 3.42s. Be interesting to see if it winds up faster or slower (not that it really matters...). You two going tomorrow ?
    els likes this.
  20. ME.GASSER
    ME.GASSER
    See you there
  21. Rat Sass
    Rat Sass
    Wow, that thing should totally annihilate the tires at low RPM. Torquing Bird...aptly named
    els likes this.
  22. Baron
    Baron
    Well tonight I brought the doors home tonight to see how well the new repro side cove moldings were going to fit. Much to my surprise, they bolted right on and the fit is very good. One more piece to the puzzle. door cove moldings right.JPG door cove molding left.JPG
  23. Dick Stevens
    Dick Stevens
    Nice to have things go right once in awhile, isn't it?
    Baron and loudbang like this.
  24. Baron
    Baron
    It sure is. Saturday I bolted the grille surround in and not that it is any big deal, but who ever cut the grille opening in the nose had it too low by 3/8 of an inch. So needless to say, the surround is back out, and I will re-cut the top and probably have to gl*** up a few spots on the lower side to get it mounted where it belongs. All minor details in the grand scheme of things.
    els likes this.
  25. Baron
    Baron
    I installed the grill surround today. The contour of the grill opening was a terrible match on the left side of the body, leaving a 3/8 gap with the grill bolted in place. Little gl*** work , bondo and it fits pretty good now.
    I just had this scoop made. As much as I like the other scoop, it is almost 6 inches wider than this one, and it really blocks your vision. I'll leave this on the car for a few weeks and see if it grows on me. Proportion wise, it does fit the car better. 57 Corvette 5 29 15 c.JPG 57 Corvette 5 29 15 e.JPG
    els, OahuEli, ME.GASSER and 2 others like this.
  26. Baron
    Baron
    Saturday's job will be to remove the steering shaft and column, paint the shaft and get the column ready for paint. And while the paint is drying, it should be a good time to install the headers. Just got them back from Central Connecticut Coatings this week and they did a great job. First they do them inside and out in silver, than they do the outside in white. Tubular Automotive headers 1.JPG Tubular Automotive headers 2.JPG
    els likes this.
  27. 1934coupe
    1934coupe
    Looking good Baron. In the early 70's I made a set of headers for my 36 Willys PU and had them, what they called ceramic coating by a place on LI or Brooklyn I don't exactly recall. They looked very much like yours, mine where white and rough like sand paint after running for awhile they took on a silvery white tone. It was bullet proof but did stain I think the roughness held the dirt and oil. But this was before Jet Hot and other coatings. I liked it a lot. Yours look very good also.
    Pat
  28. theman440
    theman440
    from Las Vegas
    That looks like a Grump Hump scoop...
  29. ME.GASSER
    ME.GASSER
    Baron the car is looking great. Keep up the good work.
  30. Baron
    Baron
    I always used VHT paint in the old days. Six or seven years ago when I had the headers coated for my 55 Chevy, the place I had them done said they would not do them in white as it would not stand up to the temperature, so I did them in silver. Unfortunately the silver did not stand up very well either. This company has had good like with the white. Time will tell.
    It is. Because the low hood clearance , and the carburetors sit so high, the scoop had to be widened two inches to clear the linkage.
    Thanks Larry. As you well know, these things always take longer than we think they will.
    els likes this.
