Projects 33 chevy 3w....time for a cool change
Discussion in 'Traditional Hot Rods' started by tb33anda3rd, Feb 11, 2014.
  1. tb33anda3rd
    tb33anda3rd
    both shoulders are fine but for some reason my knees were killing me. maybe from standing in one spot?..... it ****s getting old.
    INVISIBLEKID and hendelec like this.
  2. gwhite
    gwhite
    SUPER MODERATOR
    Wow, Teddy, she's looking fine! Keep at it!
  3. tb33anda3rd
    tb33anda3rd
    Gary, i consider the body work done the crest of the hill.:)
    I am battling a heavy spring work load, and working the car into the schedule.
    thanks everyone for the support!
    gwhite likes this.
  4. tb33anda3rd
    tb33anda3rd
    glued the rubber mats to the backer plates i had made. i scuffed the new paint and mats with scotch brite and cleaned the surfaces with prepsol. i then used 3m contact spray for rubber. once glued i test fitted them again. DSCF3931.JPG DSCF3930.JPG DSCF3932.JPG
    volvobrynk and TFoch like this.
  5. pumpman
    pumpman
    That looks great, I have to do my matts on my 32. How much time did you have to work with them before the glue sets and your screwed?
  6. tb33anda3rd
    tb33anda3rd
    the can said to spray each piece and then wait 4 minutes before joining them. i started at one corner and slowly lowered it along the back edge so only a small piece was touching. i did have to pull the edge off to get it straight and it really was stuck. so to answer your question 0 time and it would be easier with two people.
    when i use contact cement for formica, i put "sticks" in between then slowly pull them out. it would work for this too. although an extra set of hands would be a help.
    volvobrynk and kidcampbell71 like this.
  7. ct1932ford
    ct1932ford
    Should have called me!;)
  8. ronnieroadster
    ronnieroadster
    Ted your energy is incredable getting so much work done on the car is amazing. CSRA Swap Meet is Sunday see you there if you take time off from the car! :)
  9. tb33anda3rd
    tb33anda3rd
    i thought i could do it alone.......but when the block sanding starts......
  10. tb33anda3rd
    tb33anda3rd
    Thanks Ronnie, i am making my list now. never miss that swop.
    couple greasy donuts and a cup of coffee before six, in line creeping into the compound before seven. :):cool:
  11. tb33anda3rd
    tb33anda3rd
    Runnin shine and volvobrynk like this.
  12. ct1932ford
    ct1932ford
    I can smell the primer all the way to Bridgewater!:p
    volvobrynk and tb33anda3rd like this.
  13. TFoch
    TFoch
    Looking good! One step closer :)
  14. blowby
    blowby
    from Nicasio Ca
    I'm either going to have to get off my fat *** and do something or stop watching this thread.
    LOU WELLS likes this.
  15. Road Duster
    Road Duster
    Ted, Looking good.
  16. 29bowtie
    29bowtie
    Go man go! That is one very fine Chevrolet.
  17. tb33anda3rd
    tb33anda3rd
    thanks Tom
    :D
    thanks Frank!
    thanks, i am trying to do something to it everyday.
  18. The37Kid
    The37Kid
    Need a photo of the needed vent window regulator. Bob
  19. ct1932ford
    ct1932ford
    Stopped by today to check out the progress on the Chevy.:) No one home so I broke into the barn and took a couple of pictures.:eek: Sure looks good! :cool:It is amazing how much better the house looks with my coupe parked in front of it!:p MiMi and Coupe 005.JPG MiMi and Coupe 004.JPG MiMi and Coupe 008.JPG
  20. tb33anda3rd
    tb33anda3rd
    Bob, post 698 exploded and complete views. it is the ****er fly shaped regulator, the other one is from a 34 sedan delivery.
  21. clem
    clem
    That house looks good without your old car in front of it !
  22. tb33anda3rd
    tb33anda3rd
    thanks, i knew a someone with a ford stopped by.......i saw the oil drip in the driveway:eek::D MiMi and Coupe 008.JPG
  23. pumpman
    pumpman
    You guys are too funny. How big was the oil puddle?
  24. tb33anda3rd
    tb33anda3rd
    just kidding, that car is perfect. i think Mark even waxes the inside of the exhaust pipes.:D
    volvobrynk likes this.
  25. themoose
    themoose
    The oil puddle isn't so bad ..It's those nuts and bolts that can ruin the tires on the Chevy:)
    TFoch, Bowtie Coupe and tb33anda3rd like this.
  26. tb33anda3rd
    tb33anda3rd
    3.5 hrs of making dust and it is more than half way there. DSCF3935.JPG DSCF3936.JPG DSCF3937.JPG
  27. The37Kid
    The37Kid
    Body looks about ready for coat #2, no window crank at Rhinebeck, hope one turns up tomorrow in Bristol. Bob
  28. tb33anda3rd
    tb33anda3rd
    thanks for looking for me.
    so far ,i found a couple spots that need a little more filler [tiny]. dry blocking with a long board with 180 grit finds little imperfections in the panels. i use a black epoxy under the filler primer so i know when i am getting close to sanding through. so the spots showing would have been a "wave".
  29. ct1932ford
    ct1932ford
    I thought I saw a wave when I was there!:eek:
    tb33anda3rd likes this.
  30. ct1932ford
    ct1932ford
    I think that was from Tater!:rolleyes:
