Need help I.Ding these spindle mount wheels.
Discussion in 'Traditional Hot Rods' started by ratty_aussie, May 3, 2015.
  1. First of all I tried posting this on the hokey *** board but it didn't let me, hope this is ok here?
    Just swapped my 12 spokes to suit anglia for these. I was told they suit early ford spindles. Anyone know what brand they are or how do you tell the difference between magnesium and aluminium? Unfortunately they've been painted black and silver.
    Thanks
    ImageUploadedByH.A.M.B.1430693627.398284.jpg ImageUploadedByH.A.M.B.1430693640.091604.jpg ImageUploadedByH.A.M.B.1430693654.032394.jpg ImageUploadedByH.A.M.B.1430693667.721722.jpg
  2. F&J
    F&J
    Mag tends to turn black or very dark gray when exposed to weather.
    Alum tends to get lighter color corrosion
    ratty_aussie likes this.
  3. This bit kind of looks black right? ImageUploadedByH.A.M.B.1430694200.147071.jpg
    Only bit not ruined by paint.
  4. maneri
    maneri
    from ohio
    americans---mag only--looks like ford bearings
  5. Really don't like the terrible paint in them but don't want to sand blast them either so they look new. Lucky they used **** paint.
    Magnesium you think?
  6. Jakesrocks
    Jakesrocks
    If there is someone in your area that does soda blasting or blasts using crushed walnut shells, that should remove the paint without hurting the mags. Make them look like new too.
    Short of soda blasting, chemical stripping would work, as long as the chemical used doesn't react with magnesium.
  7. earlymopar
    earlymopar
    Those are magnesium and were likely painted because of the ongoing oxidization problem. I would not sand blast them as that will open the surface skin and will enlarge any existing porosity. Bead-blasting would be better (smaller grit and less pressure).
    - EM
  8. Yeah cool, paint striper it is :)
  9. hemiphil
    hemiphil
    from australia
    look like b***ett wheels, made in Adelaide, 1970's, no longer made, were made of aluminium, not magnesium, I knew the guy that made them.
    Spoggie likes this.
  10. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    A little acid like muriatic/vinegar will fizz on mag and not on aluminum.
  11. Do you have any pics? They are pretty black now I'm stripping the paint off. Never seen aluminium do that.
  12. What's muriatic? Do you put it on with vinegar or both work the same for the rest?
  13. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Muriatic acid is commonly known as "pool acid". Either that or vinegar works.
    Just put a couple drops of either on the inside of the rim, but clean it off once done. If it fizzes/reacts, they are mag. If it doesnt, its aluminum. From the pics, they sure look mag.
  14. earlymopar
    earlymopar
    97
    Careful, paint stripper is usually alkali/caustic and will corrode alloys, both magnesium and aluminum. It will not stop eating it even if you wash it off, you need to neutralize it with a weak acid wash ( citric or vinegar) after rinsing in lots of water, and rinse in clean water again afterwards, and dry thoroughly.
    The dark color you see after putting caustic on aluminum is called ****, it should wash off with the acid.
  16. Thanks for the tip. I washed and dried them throughly.
    Can't tell me there still aluminium anymore.
    prewarcars4me likes this.
  18. gwhite
    gwhite
    SUPER MODERATOR
    Do the vinegar test. I've had aluminum parts darken like that after exposure to various -pH cleaners & paint strippers.
  19. hotroddon
    hotroddon
    Throw them in a Fire - If they melt they are Aluminum , if they burn the brightest white you've ever seen they are MAG. ;)
  20. Yep. I got some aluminum rocker covers that everyone swears are magnesium. I cleaned the with eagle brand mag wheel cleaner (some sort of acid) then got in a hurry and doused them with lemon pledge and fired the engine off, turned them a nice old magnesium color. You got to get all the acid off and let engine parts cure overnight before you get them hot. :eek: :D
    Some wheels are made with an aluminum alloy that will turn gray almost like magnesium but will not p*** the vinegar test.
    gwhite likes this.
  21. rooman
    rooman
    Phil,
    did B***ett make any for early Ford spindles ?--I thought that all of his were for Anglia.
    Roo
  22. maneri
    maneri
    from ohio
    db_100_41511.jpg they are the same as mine color and all details ---unless b***ett used the americans molds
  23. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Yea, if the alloy has a good magnesium content.
  24. 28dreyer
    28dreyer
    from Minnesota
    Since Aluminum is roughly 1 1/2 times the weight of magnesium, I would think you could tell simply by the feel or actual weight judging from the diameter, width and m*** of these wheels.
    lurker mick likes this.
  25. Is that the same b***et that makes roundy round wheels?
    Wouldn't you need something to make a comparison?
