Technical Flathead/T5 racket – fool me once...
Discussion in 'The Hokey Ass Message Board' started by Kevin Lee, May 2, 2015.
  1. blowby
    blowby
    from Nicasio Ca
    ^^ That sounds like a possibility. Hopefully we get an update when it comes apart.
  2. dirty old man
    dirty old man
    Well Kevin, I don't know what to say now that you relate that you actually did rotate the engine several turns before final installation of engine/trans ***y and detected no hint of interference.
    I'm wondering, do those finger weights on a Long type p. plate swing outboard further when engine is running, even at idle, than when being rotated by hand wuth a wrench on the crank? Been many years since I even held a Long type p. plate in my hands, much less installed it. Details are getting fuzzy, but I do remember that there used to be an adjustment screw on the tip of each of the 3 levers to contact TO brg.
  3. Kevin Lee
    Kevin Lee
    Super Moderator
    Yeah, this is well beyond any adjustment problem. And that was all checked before install. Also, it happens with the clutch out. That's how the weights work – adding pressure by centrifugal force.
  4. dirty old man
    dirty old man
    Yeah, I agree, and that's what made the Auburn clutch so great. It had no centrifugal weights to interfere with high rpm shifting, yet it didn't slip and it was lightweight. Plus it bolted right up to same flywheel holes as stock Long, and it was extremely low profile like a diaphragm clutch of today.Very popular in oval track racing back then.
    Would require a redrilling of the flywheel, but how about a diaphragm p. plate?
  5. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    Unfortunately, I've come to realize that most aftermarket parts almost fit everything, but don't fit anything. Cheap parts are complete junk, expensive parts are much better but usually still need something to make it works right. I usually go for the middle of the road part. Most of the time they will stand up to what I need them to do but I don't mind making them fit as much as I do after spending a lot more for the "Good One".
  6. Slick111
    Slick111
    Avoid Speedway I ordered some threaded bungs and DOM tubing from them the tubing threaded ends were angled 10 degree's a machinist I took them too didn't even know how it could be done with out a taper attachment on a lathe sent them back with a tracking number Speedway first said they never got them after 2 months they sent me a refund less stocking shipping etc.
  7. cadillacoffin
    cadillacoffin
    Maybe a stupid question but why didnt you go with the 9" clutch? i just ordered the same setup except smaller clutch and pussure plate with the same hesitation regarding speedway. i havent got it together yet but from everything i read on here and the ford barn 9" is all you need on the flathead.
  8. I'm just throwin' this out there.... my 5 dollar bet is on the clutch disk being cracked. Friend of mine went through this. Damn thing sounded like the trans was falling out of the car. 1st time he dropped the trans, he saw nothing wrong. 2nd time...... fractured clutch disk.
    Guess I'm with Ozy..... but I'm not covering HIS bet.
  9. Bruce Lancaster
    Bruce Lancaster
    This is the one time you can be thankful for not having a torque tube, as you take the heap of junk apart...
    Also, the noise means that points of interference will be clearly visible.
    You are, if I am following the right links, using an early Ford pressure plate and throwout sleeved to go on late trans. A thought is that the various Long clutches at speedway may not all be early Ford fingered...if your plate has later type fingers, the extra length may be getting into something on the full-sized throwout.
    New Long plates from China do have a reputation of random finger adjustment and warped covers as well. Rebuilds of real ones can still be found.
  10. Kevin Lee
    Kevin Lee
    Super Moderator
    Yeah, early style plate & bearing with a sleeve. I'm currently trying to decide if it might be easier to build some proper cribbing to get the ch***is high enough to just drop the mess out of the bottom? Transmission crossmembers are all removable with a few bolts and this could save me from dis***embling all of my cooling, wiring, and exhaust. I would make a custom block to support the back half of the engine, drop the driveshaft, then slide back and lower the trans by whatever means necessary. Only possible issue might be shift tower interference with the floor not allowing me enough rearward clearance.
    Currently organizing the garage for a coordinated attack.
    And fiddysixF... I'll take that bet!
  11. Bruce Lancaster
    Bruce Lancaster
    This is the F1, right? Job should be about two days easier than on a '48 Ford. Hold up pan with an old phone book (perfect padding) on top of a '32 Ford jack.
    Hnstray likes this.
  12. 55 dude
    55 dude
    hope folks read this and understand that when a company peddles **** parts they don't deserve our dough! After reading about these situations Speedway will always be my last resort for anything!:eek:
    cadillacoffin likes this.
  13. Kevin Lee
    Kevin Lee
    Super Moderator
    Yeah, F1. But man... haven't had a phonebook around in years – you think an iPhone will work?
  14. Petejoe
    Petejoe
    from Zoar, Ohio
    Need to rebuild your pressure plate? I will fix you up. American company great work. Pm me.
  15. Bruce Lancaster
    Bruce Lancaster
    An I-phone with three wraps of duct tape is today's answer. Who let you out of 1952?
    tb33anda3rd likes this.
  16. J & D
    J & D
    On my adapter was not centered with the crank, it was out about .12". I had to use offset dowels to correct it.
  17. Fife's 56
    Fife's 56
    I had this problem with my speedway conversion. The sleeve that goes over the input shaft on the transmission was too big and when clutch disc dust built up the throw out bearing pulled the sleeve forward and rubbed against the clutch disc. Speedway claimed they new of no problems with the kit. I had a machinist turn down the sleeve. I don't remember if it was 5 or 10 thousandths. We reinstalled the sleeve and drilled a hole and pinned it also. That took care of the grinding noise I had. Now I can hear the throw out bearing rattle a little bit on sleeve but I can deal with that. It took over a year for us to figure out this problem.
  18. Bruce Lancaster
    Bruce Lancaster
    So there you have it...get out your yardstick and check concentricity!
  19. Fife's 56
    Fife's 56
    Just to clarify, I was not able to shift my car after I adjusted the clutch and drove it a few miles.
    The first few miles were fine and then I would start hearing a grinding noise and was not able to shift gears. I would go home and adjust the clutch and drive it another couple miles and the same thing would happen. I don't know if you have the same problem but I though I would share my issues with the kit with this thread. The noise I experienced was pretty loud when the sleeve contacted the disc.
  20. NMCarNut
    NMCarNut
    Turns out Speedway is not the only adapter that has an interference problem with the counterweights on certain pressure plates, I had your exact problem with the Cornhusker set up I bought. After pulling the transmission the problem was obvious. A trip to the milling machine and problem solved. Maybe I got a little carried away but I did not want any reoccurring problems as the clutch disc wears . . .
  21. Jimmy2car
    Jimmy2car
    from No. Cal
    Go to your nearest NAPA store and get a 10" diaphram Pressure Plate. Problem solved:
    Part Number CA 30
  22. hotrodA
    hotrodA
    ^^^^ That's good info!
    Does it have the Ford flywheel bolt pattern?
    What throwout bearing works with the early Ford fork?
  23. krylon32
    krylon32
    from Nebraska
    I'm gonna chime in here. The adaptors haven't changed, it's the pps. I sold hundreds of 10 inch pp's over the years and never had a problem. The problem started about 4 years ago when my US supplier stopped making the 10" Long style PP because he got so expensive no one would buy theirs. I ***ume my supplier along with Speedway started buying the foreign made pp's. I have a paragraph in my instructions warning of this problem. It doesn't occur with every pp just a few. There's pps out there that will work but most guys don't want to spend the money. I would have to get 200 + to make them worth carrying. For my business it may be a better option to just quit selling PPs. Fort Wayne Clutch is a good option and that may be where I start sending my customers? Lastly the problem I have encountered with the diaphragm pp is the center hole being to small to work with the early Ford Brg and hub. There may be a diaphragm pp that I'm unaware of? Gary at Cornhusker
  24. NMCarNut
    NMCarNut
    @krylon32:
    There was at least one problem, mine.
    You said: Should have followed the instructions and checked PP clearance.
    I said: Saw the warning but since I paid extra money to buy the PP from you figured it would be OK.
    Score: Draw.
    Bottom line: After an unplanned teardown and machining everything has since been fine.
  25. krylon32
    krylon32
    from Nebraska
    I am working on sourcing a new pp supplier but cost is an issue. As I said I may just refer everyone to Fort Wayne and be done with it but that is not the way I've done things for 30+ years. Gary at Cornhusker
  26. blowby
    blowby
    from Nicasio Ca
    Why not just clearance the housings as above? Looks like a pretty quick job.
  27. krylon32
    krylon32
    from Nebraska
    I called Nebraska's largest clutch house and they had a 10 inch CA30 diaphragm on the shelf along with rebuilt 10 inch original Long 3 finger PP. Both will be at the shop tomorrow. I'll compare all the dimensions and report back. Gary at Cornhusker
  28. Tim
    Tim
    from KCMO
    You the only house in America that doesn't get 5 telephone books thrown in the driveway in the spring?
    kidcampbell71 likes this.
  29. hot rod pro
    hot rod pro
    from spring tx.
    Kevin it is the weights hitting inside the adaptor. I machine every adapter I use. Offy adapters have the same problem.
  30. hot rod pro
    hot rod pro
    from spring tx.
    Kevin. Here is what I do. ImageUploadedByH.A.M.B.1430858800.824280.jpg ImageUploadedByH.A.M.B.1430858811.562092.jpg ImageUploadedByH.A.M.B.1430858822.083376.jpg
