Projects My 49 Plymouth P-18 build
Discussion in 'The Hokey Ass Message Board' started by moe00, Apr 28, 2015.
  1. moe00
    moe00
    Hi guys, I have a 49 Plymouth that I'm working on and I always welcome help and advise from all the knowledge we have here. I'm just getting into cars so even the smallest stuff I'd appreciate.
    I purchased a disc brake kit and shock arm relocation mounts
    Got dual carb header/dual exhaust
    The car has been converted to 12v, I'm putting a new wiring harness kit it
    Got the cool HEI distributor, new chrome alternator, plugs, wires
    Only problem I had before I started working on it was the 1st/reverse gear linkage was gone or broke.
  2. plymouth1952
    plymouth1952
    [​IMG] I kind of like them too
  3. 56 Dodge Pickup
    56 Dodge Pickup
    Welcome its cool to see another Plymouth being built keep us posted and have FUN!! Jim
  4. moe00
    moe00
  5. moe00
    moe00
    Got the motor out, two bad cylinders, need shelves. Got the brake conversion kit and shock are relocator. seats at upholstery. I'm currently putting a new wiring harness in.
  6. 56 Dodge Pickup
    56 Dodge Pickup
    Making progress you will be cruisin before long! Jim
  7. 50desotocoupe
    50desotocoupe
    from Denver
    Right on! Keep up the good work and post more pics!!! Nice to have another old Mopar on the road!
  8. moe00
    moe00
    I'll be picking the block up from the machine shop soon! Bored 60 over
  9. moe00
    moe00
    Full rebuild kit cost me $1,250
  10. moe00
    moe00
    Got my disc conversion brake brackets in. Parts list ordered!
  11. 73RR
    73RR
    ...have your machinist cut about .060 off of the head while you're at it.
  12. moe00
    moe00
    What will it improve with the .06 cut?
  13. 73RR
    73RR
    ...more compression...
  14. moe00
    moe00
    Got the block back. Time to put it together. Its 60 over.
  15. missysdad1
    missysdad1
    The great thing about taking a slice off the head is that the slight boost in compression is FREE horsepower.
  16. moe00
    moe00
    They already cleans and did the work on the head, they were going to charge double to cut it down.
  17. moe00
    moe00
    All the machine work with 2 sleeves cost $830
  18. Before you seal the pan up make sure that the rods are in the correct order, as they do have an offset re the bore/crank journal.......they are normally stamped 1-6 from memory........andyd
  19. moe00
    moe00
    Its coming together!
  20. moe00
    moe00
    Andydodge I made sure they were, thanks! They all were stamped
  21. moe00
    moe00
    Do I thread lock or dip the head bolts in oil? I used some rust cleaner on them, they're bone dry.
  22. CRZNDUCK
    CRZNDUCK
  23. 57Custom300
    57Custom300
    from Arizona
    Kudo's for sticking with the original engine. Sure it costs more but you'll have something different when your done.
  24. moe00
    moe00
    I'm at $3700 in the motor thus far.......
  25. moe00
    moe00
    Question.......on this 217 motor is there a front seal? There's a huge gap that I don't believe should be filled with silicone.
  26. moe00
    moe00
    Never mind its for oil flow for the timing chain.
  27. plym_46
    plym_46
    from central NY
    There should be a small tube and bracket that feeds the chain lube from above the chain. The timing chain cover needs to be centered properly to seal the front of the engine. there is a procedure in the repair manual that deals with this procedure. Several of the bolts for the cover go into a coolant p***age and should have some thread sealer on them to prevent coolant weeping out.
  28. moe00
    moe00
    Had an emergency.....
    Have a 49 Plymouth I was restoring. Original 217, a full resto machine shop. Motor with all the parts has about $3700 in it, new dual Offenhauser intake, Stovebolt mini HEI, dual Cater carbs, Cast iron headers, rebuild kit and more. Motor isn’t complete. New sun visor, headliner, door panels, and front/rear seats upholstered. No rust on body, paint isn’t show quality. Have a front dis brake conversion kit along with the new rotors, calipers, brakes etc not installed. New shock relocation arms, not installed. New wire harness kit, started running wires. New Cragar Chrome Smoothie Wheel 15"x7” 5x4.75. I have both front gl***, clean clear ***le, inspected, with plates. The car was running and driving when I got it.
    How much is it worth?
    Dallas Tx
