Technical Oil literally everywhere.
Discussion in 'The Hokey Ass Message Board' started by D-man313, May 7, 2015.
  1. D-man313
    D-man313
    Recently put a new motor (sbc 350) in my truck. Had a oil leak at high rpm. I run under 2500rpm all day long an see not a drop of oil, get on it and oil blows all over the truck.
    Looked like timing chain cover gasket was breaking, so this afternoon I put new timing chain gasket, balancer seal, water pump gaskets on. Just got back from test drive and its leaking more then it ever did before I changed gaskets.
    I've been tracking this for well over a week now. Any other things I should look at? And again from idle to 2000-2500 rpm not a drop of oil. Get on it and oil blows.
    Thanks
    David.
  2. D-man313
    D-man313
    Also running a fuel pump block off plate but just put a new gasket on it a few days ago.
  3. D-man313
    D-man313
    Great oil pressure, and runs like a new motor should. Just leaks.
  4. olscrounger
    olscrounger
    ck for the bolt hole on front of block near fuel pump-one of these goes thru to the fuel pump rod cavity
    Model T1 and loudbang like this.
  5. scrap metal 48
    scrap metal 48
    What he^^^ said...
  6. vtx1800
    vtx1800
    For what it's worth (and to show how dumb I was) the last engine I built didn't get installed for several years, finally got it up and running last year, had (and still have) some issues but the big one was when I came back from a drive and oil is running out on the ground. I thought maybe the pan gasket wasn't sealed correctly and I couldn't (seem) find the leak, and it had to be a big one. I pulled the engine to put a new pan gasket in (no there wasn't enough clearance to do it any other way), had the engine back in place and was about to put the radiator grille ***embly back on (1938 Chevy) and spied a hole in the p***enger side head that looked oily. I pulled out my trusty knife, shoved it in the hole, yep, it went right into the valve/rocker arm area, put a bolt in it and solved the problem. I'd never used those heads before so had no idea they needed a bolt to hold the oil back. Dumb me:)
  7. D-man313
    D-man313
    Ya I'm callin myself dumb right now. Went and looked at my old motor and there's a bolt in the top hole on the face of the fuel pump mounting boss. Put a bolt in it and I'll try it tomorrow
    Model T1 and Tim like this.
  8. olscrounger
    olscrounger
    Glad you found it--not the 1st time this has happened and I'm sure not the last-easy to overlook
  9. tb33anda3rd
    tb33anda3rd
    make sure the bolt is very short, too long and it will hit the fuel pump rod . use the one from the old motor to be safe.
    brokenspoke likes this.
  10. Leadsled51
    Leadsled51
    Sounds like you found it, but just in case, if it is an older set of heads that didn't have the accessory holes in it for brackets, etc, make sure someone in the past didn't drill holes in them to mount brackets. They are usually drilled right into the rocker arm cavity. If you don't plug them with a short bolt, you will have oil out of the hole. Ask me how I know.
    vtx1800 likes this.
  11. JOECOOL
    JOECOOL
    Make sure your pvc stuff is working ,if it builds up any pressure it will leak a lot.
  12. D-man313
    D-man313
    Well it looks like the bolt I put in last night is staying dry. But now the front of the pan is leaking, which I just put a seal on yesterday. Motors coming out tomorrow morning.
  13. 40fordtudor
    40fordtudor
    Before I knew about the bolt hole in the front of the fuel pump mounting boss, I concocted gobs of different sticky substances to hold the rod up whilst I put the new pump on. Thanks to Frank Loomer, who educated me.
  14. Garage night at the Stewarts!!!
  15. 57JoeFoMoPar
    57JoeFoMoPar
    How are the rings? I'm ***uming when you say you put a new engine in you mean "new to you" and not new as in out of the crate. The engine in my '57 does something similar to what yours is doing. It doesn't really smoke noticeably until you stomp it, in which case there is a lot of smoke out of the exhaust. The PCV can't begin to keep up with the blow-by, and there is noticeable pressure vented out of the breather. I used to have a set of vintage Cal-Custom valve covers with no breather, just the PCV, and it blew out my valve cover gasket and was leaking like a sieve. I put a regular set of chrome valve covers on with a breather, and it definitely vents blow-by, but stopped the gaskets from blowing out. The issue I have now is the blow-by fills the engine compartment with oil vapor, and then I get oil drips more generally. I figured the best way to combat the issue I have, short of pulling the engine and rebuilding it, is putting in a crankcase evacuation system as opposed to a PCV. I might try that soon.
  16. D-man313
    D-man313
    You know you're more than welcome any time. Just not tonight lol
  17. Date night?
  18. D-man313
    D-man313
    no, just not home. Don't feel like messing with it anyway right now. Start fresh in the morning.
  19. Model T1
    Model T1
    I think at one time or two we've all had the missing bolt in the head leak.
  20. ClayMart
    ClayMart
    What he said! ^^^
    Is the crankcase properly vented? :confused:
  21. squirrel
    When you change the pan gasket, make sure the front seal on the gasket matches the timing cover. They used two different styles, the 1955-73 design uses a thin seal, 1974-up uses a thick seal. If you use the thin seal instead of the thick one, it will leak pretty well. But there could be other issues too.
    I really like the modern one piece oil pan gaskets. Kind of expensive, but worth it.
    pat59 likes this.
  22. D-man313
    D-man313
    Have the pcv system hooked up the same way as the old motor, and actually have another breather equalling 2, so it should work better no?
    Squirrel, are you referring to the one piece pan gasket that fits in the bottom of the timing cover. I checked the old vs new before installing yesterday and they matched.
    To me it looks like oil is running between the front edge of oil pan, and the backside of timing cover(backside of where the bottom "u" shaped seal sits on the timing cover)
  23. D-man313
    D-man313
    This is the kit I installed yesterday. ImageUploadedByH.A.M.B.1431135519.030455.jpg
  24. squirrel
    Yes, that's the one I mean. Just make sure that the seal that goes between the pan and timing cover is the correct thickness.
    What do you have for a timing cover? I've had trouble getting the chrome ones to seal...I much prefer an old original painted cover.
  25. pdq67
    pdq67
    It's probably been said here before, but...
    The (4) bolt holes in the front of the block are for mounting the old Tri-5 front "mushroom" pedestal mounts.
    And the one hole by the fuel pump pushrod location can be used to pinch the p/r back to help when changing fuel pumps. Just make sure to use some good old Indianhead and a short bolt in that location or she will weep oil..
    pdq67
  26. D-man313
    D-man313
    I have an original. Painted. No paint on gasket surface, not all tweaked either.
    And use a gasket like this that replaces the black seal correct?
  27. pat59
    pat59
    That's what I used when I redid my pan and timing cover the blue one piece pan gasket. Worked out real nice. (no leaks)
  28. D-man313
    D-man313
    I have a feeling that's what I used on the 1st motor that was in the truck but I can't remember that far back. Going to try and do as much without pulling the motor, I really don't want to do that. If I need to do the pan, hopefully there's enough room above my crossmember.
  29. squirrel
    Make sure the front of the pan gasket is the correct thickness for the specific timing cover you have. Thin gasket for the older one, thicker for the newer ones. you didn't post any pictures of your engine, so we are guessing what you have.
  30. Imwalkin
    Imwalkin
    from Tucson, Az
    What is the part number on that one piece gasket?
