Technical 1955 belair brahe linkage
Discussion in 'The Hokey Ass Message Board' started by lilrobo, May 10, 2015.
  1. lilrobo
    lilrobo
    from ky
    hey guys i am working on my 55 chevy belair brake linkage , i am on my 3rd booster now the problem i was having was that the pedal wasnt coming all the way back up, what i need to do is hook up the booster rod to the lower hole on pedal not the top ( stock ) hole , i need to figure out how i dont want to angle the booster it sits level now here is a pic , can you show me your hook up ?
    thanks
  2. wheeldog57
    wheeldog57
    your set up looks like it wants to be in the upper hole. mine is in the lower but it was done in late 80s. maybe newer parts have evolved to be in upper hole?
  3. 35chevymaster
    35chevymaster
    from indiana
    I had to use a heavy stock style return spring on mine,, from the bottom of dash to pedal
  4. 325w
    325w
    Over the years several kits said to drill a new hole one inch lower. Many many cars have been built with the booster linkage in the stock hole. Have you tried driving and braking using the top hole.
  5. 325w
    325w
  6. odass
    odass
    from se ok
    Almost 100% Positive mine is in the top hole
  7. lilrobo
    lilrobo
    from ky
    yes i have tried it in the top hole , the pedal goes a little low for me, i really need to be lower hole
    i will try to angle the booster a little with washers
    thanks
  8. odass
    odass
    from se ok
    Are you sure it's not just adjusted out far enough? Seems your linkage might be to short, I always adjust mine till the pedal is all the way up without pushing in the rod
  9. Ralphies54
    Ralphies54
    I'm doing the exact same thing right know to my 57 {disc etc} and my directions say do not drill a new hole as that would only come into play if the kit included a angled booster and mine do's not, it has a flat fitting booster.
  10. 55Belairman
    55Belairman
    Mine is in the bottom hole. I have owned this car since 72 and I am sure it hasn't been altered since new.[​IMG]
  11. odass
    odass
    from se ok
    After checking, mine is in bottom hole also, sorry, just could have swore
