Projects Gathering parts for a 32 pickup build
Discussion in 'Traditional Hot Rods' started by Scott Grabowski, May 11, 2015.
  1. Scott Grabowski
    Scott Grabowski
    If I were to carry a spare it is a simple solution to cover both bolt patterns. Problem will be having the same tire "rollout" to accommodate both front and rear tire diameters. That problem would exist even running "matching" wheels front and rear. image.jpg
  2. Never mind my ideas were not what you wanted to hear.
  3. HOTRODPRIMER
    HOTRODPRIMER
    All the years and thousands of miles I have traveled in a hot rod I always ran big and littles and not once had a flat tire.
    Your over thinking it. HRP
  4. Scott Grabowski
    Scott Grabowski
    Keep posting I am listening. I understand that the mix match wheels are not something everyone likes. I was replying to see if there was a safety issue with running them in the front and conventional in the rear as you stated avoid doing it like the plague.
  5. Scott Grabowski
    Scott Grabowski
    Here is a pic of the quick change. Was blasted on the outside and never coated so it is due for a reblast. Inside is all coated with grease so it will need to be completely cleaned and set back up. 4:10 main gear set. image.jpg
    waxhead likes this.
