Technical Louver Press Build
Discussion in 'The Hokey Ass Message Board' started by '54Caddy, May 12, 2015.
  1. wayne-o
    wayne-o
    An open center valve is just that, all ports (p, t, a, and b) are connected when in the center
    position. This will allow the weight of the upper die/cylinder rod to fall down. You need a tandem center valve to hold the cylinder in a fixed position. Most valve manufacturers make flow controls and relief valves that sandwich between the valve and the manifold making it easy, no plumbing. As already mentioned you must use a relief valve, very dangerous with out.
    Okie Pete and bct like this.
  2. '54Caddy
    '54Caddy
    Thanks Wayne-o, very helpful info. Looks like I have the wrong valve then. I think I found the right valve I need with a tandem center. Hopefully they will let me return the other valve. Also going to pick up a relief valve and flow control valve.
    Thanks for all the help everyone
  3. '54Caddy
    '54Caddy
    Starting to fab up a tank. Used my buddy Steves new electromagnetic brake to bend up some 1/8" image.jpg
    Okie Pete and kidcampbell71 like this.
  4. frazzledsmythy
    frazzledsmythy
    Sweet thread! Yankee ingenuity at its finest keep up the good work! Subscribed.
  5. joburnsjo
    joburnsjo
    I found a frame just like your at an auction and I was going to make an lover press out of it after I won the bid the auctioneer told me the rest of the ban saw was over on the other side of the field and I got the complete ban saw for metal with 20 extra 16 foot blades still want to build a louver press still looking but have the louver dyes waiting
  6. FrozenMerc is bang on(no pun intended).
    When you get to the end of the stroke of your cylinder or die(whichever comes first)either
    up or down you will want to limit the pressure created by your pump,
    hence the need for a relief valve.You will also be able to tune up the pressure needed for different materials or dies also.You should be able to buy a segment to go between your
    DCV and the lower manifold it is bolted to, that will have metering valves(speed controls) built in which will solve that problem.They can come with a byp*** in one direction to speed up your up stroke but limit the down for better control while louvering.
    Maybe a single acting,spring return cylinder would be better for this job,just a suggestion.
    Love the frame by the way.
    kidcampbell71 likes this.
  7. '54Caddy
    '54Caddy
    I thought about a single acting cylinder with spring return but I wanted to be able to jog the upper die down to line it up. Thanks again to all you guys helping out, I really appreciate it!
  8. DDDenny
    Caddy--
    I can't debate the hydraulics(valve) theory here , but you may want to research this a little further before your next valve purchase. One wrong "jog" will ruin your whole day.
    Ask me how I know.
  9. ct1932ford
    ct1932ford
    Great job! I started building one many years back but never finished it. Don't be me!:rolleyes:
  10. '54Caddy
    '54Caddy
    Alright I think I have this figured out. What do you guys think?
    This is what the plumbing should look like, correct?
    This is the new valve Im looking at...
    http://www.northerntool.com/shop/tools/product_200329581_200329581?isSearch=201305
    This is the sub plate...
    http://www.northerntool.com/shop/tools/product_200326790_200326790?isSearch=203231
    This is the flow control...
    http://www.northerntool.com/shop/tools/product_200339399_200339399?isSearch=202512
    And finally a relief valve...
    http://www.northerntool.com/shop/tools/product_200605546_200605546?isSearch=33308
    What do you guys think? I think these are what I need, I just don't want to order the wrong parts again
    Okie Pete likes this.
  11. 1950heavymetal
    1950heavymetal
    I don't know anything about hydraulics so this is very informative for me. Great build idea too!
    Posted from the international space station
  12. FrozenMerc
    FrozenMerc
    Looks like you got the right components now. Use the relief valve to set your system working pressure and the flow control to set the ram speed.
    Good Luck
  13. '54Caddy
    '54Caddy
    Thanks for the help @FrozenMerc
  14. Be careful with the orientation of the valves,you could easily put the flow control valve 180 degree out if they don't come dowelled.You don't want to mix up the P &T ports
    The ports are slightly offset to the 4 bolt holes.
    '54Caddy likes this.
  15. john worden
    john worden
    from iowa
    Your "C" frame throat at 36 inches will not allow the large car hoods unless you rotate the dies and run the panel sideways through the frame. My shop built press is less ***y than your "C" frame but the throat depth was designed at 48" I opted to use shop air connected to an SPX pump with built in foot pedal that operates an 11 ton SPX single action cylinder. A simple setup that uses little air and allows precise die lineup. I also made my 3" and 4" dies by shaping precision ground and hardened steel. I have a set 3" and 4"dies with matching contours and a 3" set of old school or lakes style dies. You may not have to box your frame. I would test it by punching some louvers first. 100_0730.JPG 102_2140.JPG 102_2139.JPG 100_0615.JPG
    The37Kid, Okie Pete and kidcampbell71 like this.
  16. RICH B
    RICH B
    Wondering a little on how you sized your motor hp in relation to the pump.
  17. wheeldog57
    wheeldog57
  18. '54Caddy
    '54Caddy
    Very nice! I am planning to set the dies up so they can be turned 90 degrees. Your louvers look awesome! I also plan to carve some dies out of A-2 tool steel then send them out to be hardened.
    I used the old rule of thumb that an electric motor hp rating is 3 times stronger than a gas engine hp. I have a log splitter with a 5hp gas engine that splits 18" logs with ease. 1/3 of 5hp is 1.67hp. Researching what others have put on louver presses and hydraulic shop presses, 1.5-2hp seems to be pretty standard
  19. seatex
    seatex
    Damn buncha' rocket scientist on here..............BRILLIANT!
  20. wayne-o
    wayne-o
    Your diagram looks correct. Be sure and add a pressure gauge so you can monitor the system pressure and adjust the relief valve. If I were designing this for a customer, we would use a system relief valve and a separate pressure regulator to adjust the cylinder force. You should not need this. As you turn down the flow control, more oil will go across the relief valve. This will generate heat in the system. Should not be enough to worry about. But you might want to check the tank temp if you are using it a lot. Log splitters do not have a problem as the pump is sized to use all of its flow to move the cylinder at one speed, ie no flow control. One thing I was taught long ago about hydraulics, a pump only produces flow, no pressure. Pressure is only built in a system when there is a restriction to the pumps flow by either doing work, being restricted, going over a relief, etc.
    Okie Pete and '54Caddy like this.
  21. One thing I was taught long ago about hydraulics, a pump only produces flow, no pressure. Pressure is only built in a system when there is a restriction to the pumps flow by either doing work, being restricted, going over a relief, etc.
    And flow escaping under pressure without work being done is a heat generator.
  22. plym man
    plym man
    Good work. Love these do it yourself projects. 110 volts will be fine, run my home built press at 110 v. with a 3/4 hp. motor, will punch 16 ga. s/s in smaller sizes. If you are going to do modern hoods you may find that a 3 ft. throat is restrictive. You will make your life a lot easier if you go to a hand controlled mechanical (manual) valve. Best of luck, keep up the good work, have fun.
  23. 383deuce
    383deuce
    This is very cool....Sure wish I had one....
  24. wheeldog57
    wheeldog57
    early ford stuff (hood, trunk, etc) is well within the parameters of this fine machine! It will get plenty of use
  25. tb33anda3rd
    tb33anda3rd
    looking for stuff to louver.....:)
    good idea Josh and i am sure you won't have a problem plumbing it.;)
    The37Kid, kidcampbell71 and '54Caddy like this.
  26. the metalsurgeon
    the metalsurgeon
    from Denver
    great thread with great info/write up.good job
  27. mike bowling
    mike bowling
    Excellent presentation, Dr. Josh. Like Albert Einstein said:" If you can't explain it simply, you don't understand how it works." This is a perfect thread for anyone thinking about building something similar. I'll be in line when the "Auburn Louver Works" has it's grand opening.--- Watch yer fingers!
  28. FrozenMerc
    FrozenMerc
    Not quite. Rockets are easy..... Controlling the explosion at the end of a stick is the hard part, and you need hydraulics for that. :D
    Okie Pete, kidcampbell71 and '54Caddy like this.
  29. zman
    zman
    from Garner, NC
    Man I wish I could have found a frame like that when I built mine.
  30. continentaljohn
    continentaljohn
    Sweet! Great find on the saw frame and love the build. The s****pers in our area have made finds like the frame harder to unearth.
