Customs 1964 impala is all over the road
Discussion in 'The Hokey Ass Message Board' started by Jahlg, May 9, 2015.
  1. Jahlg
    Jahlg
    from Michigan
    just did a drum to disc conversion, with 2"drop spindles. all new bushings a year ago, air bagged. took it out for initial run after putting back togetther, and its all over thee place. feels like low tire pressure, but they arent low. got all new wheel bearings,spindles, calipers and rotors. im so frustrated with this car at this point, dont have a bottomless checkbook, so i try and do everything myself, with help, but damn, im at wits end... help
    TMSTransport likes this.
  2. tb33anda3rd
    tb33anda3rd
    have you had it aligned?
  3. deto
    deto
    X2
  4. BobMcD
    BobMcD
    If the toe in is way off it will be all over the road. At the very check the toe with a tape measure and get it close before you take it to an alignment shop. 1/8' toe in should get you in the ballpark
  5. stimpy
    stimpy
    sounds like its toed out and like bob said above bring it in . and then make sure to get it aligned at a shop . best $40 bucks you can save besides your life ,neutral ( 0) or 1/16th toe out can cause this problem specially if the caster is off and if you run bias tires will make it more noticable
  6. jcmarz
    jcmarz
    from Chino, Ca
    I hope your 64 doesn't end up like this:
    pat59, lewk, dan c and 1 other person like this.
  7. doinbad
    doinbad
    from celina tn
    Have it lined up when you installed the brake kit it widens the track with about 1/2 so toe is out . Just done one had to do same thing but I always set toe after a brake swap
  8. Jahlg
    Jahlg
    from Michigan
    Ok, how do I check toe? I'm going to get it aligned but I need to be able to make it to the shop safe, so I want it close
  9. 50pontiacguy
    50pontiacguy
    How are the air bags plumbed? If they tee off, one line feeding both fronts/rears it can cause pressure to change between the two when you corner or hit a large bump, IE turning left hard will cause right front to "deflate" pushing air to left front.... Also do you have shocks? Just a thought. Alignment is sound advice too......
  10. doinbad
    doinbad
    from celina tn
    Get a buddy and 2 tape measures I take a couple of 1 foot by 2 foot pice of ply wood cut to slots at each end 1 inch deep and 2 inch off ground place them vertical again the tires one tape in each slot from side to side set it at between a1/4 to 1/8 toe in
  11. doinbad
    doinbad
    from celina tn
    This is a pic of the plates I use they are alum but a plywood one would work the same ImageUploadedByH.A.M.B.1431261694.855762.jpg
  12. theHIGHLANDER
    theHIGHLANDER
    If there's a center tread line (groove) you can use it, or jack up each front and scribe a line down the center with a scratch awl or a piece of chalk. move the car back n forth to be sure each side has settled to where it normally rides. About 3' back and 3' forward should do it. Measure the front distance of the 2 tires then the back. The difference is your toe setting. If you measure say, 58 1/4 in the front and 58 in the rear you're toed out. You need to measure as high on the tire as you can. By the way, that 58 inch number is just an example. Good luck and let us know what you find. What doinbad is showing works too.
  13. Jahlg
    Jahlg
    from Michigan
    i just looked at it as i went out for my morning jog, holy **** its way out!! that explains it, my bags have lines run to each, 8 valves, no tees in system. going to make a jig with some angle aluminum that i have. i will post results, probably today or tomorrow
    50pontiacguy and Frankie47 like this.
  14. Jahlg
    Jahlg
    from Michigan
    69 7/8" rear, 72 5/8 front measurement. Whoops. Just a bit toe out
  15. gimpyshotrods
    gimpyshotrods
    Oooops!
    40fordtudor likes this.
  16. dan c
    dan c
    just like being "just a bit" pregnant. lol
  17. Jahlg
    Jahlg
    from Michigan
    Hahaha I am still learning
  18. mike 51
    mike 51
    from norcal
    An easy fix is always nice...
  19. Jahlg
    Jahlg
    from Michigan
    Got it closer tonight. Pulls left a bit, but going to get proper front alignment next. Now about the brakes
  20. bobss396
    bobss396
    I learned many years ago that if I measured the old tie rods between the grease fittings and wrote down that number, ***emble the new ones to that length and the toe will at least let me get it onto the alignment rack.
  21. Jahlg
    Jahlg
    from Michigan
    My driver side rod was a bear to adjust. P***enger spun freely. Got to try and make it go straight
  22. mrconcdid
    mrconcdid
    from Florida
    I had a similar problem when I replaced tie rod ends, I put a piece of tape on the threads where the old tie rod ended, then screwed on the new tie rod till it touched the tape, I thought I was really doing something, I didn't notice the new tie rod shank was longer than the old ones, ended up having the toe set way out like yours, reset the toe and it drove good again.
    Godspeed
    MrC.
  23. Flatred53
    Flatred53
    from Sweden
    1964 Impala front suspension in action,,
  24. stimpy
    stimpy
    2 3/4 out !! suprised the front tires were not howling from being dragged along , when you go get a alignment they are going to need a good set of tires ( newer or equal wear ) to set it so if you have 2 off tires buy a set of new ones . its not a gimmick its needed to make things even when they set it .
  25. Jahlg
    Jahlg
    from Michigan
    My tires are about 95% so not worried about that. Going to try for next Saturday on alignment.
  26. Jahlg
    Jahlg
    from Michigan
  27. Jahlg
    Jahlg
    from Michigan
    Sorry for double post
