Projects 33 chevy 3w....time for a cool change
Discussion in 'Traditional Hot Rods' started by tb33anda3rd, Feb 11, 2014.
  1. tb33anda3rd
    tb33anda3rd
    after running over a few cones on the way in, we found some stuff at the swop meet. i picked up a couple air filters to cut up to use in the two four air cleaners, some sanding discs, and a couple lights i may add inside the front fenders for "extra" turn signals.
    once i got home the dust-was-a-flyin'.
  2. tb33anda3rd
    tb33anda3rd
    my new vent window regulators arrived today. thanks to @fastrods here on the ham thanks Bill!
  3. ct1932ford
    ct1932ford
    You must be living right!:cool: Good find, if not imposable. :D
  4. tb33anda3rd
    tb33anda3rd
    he sent them to me before he got my check. nice guy!
    finished sanding the body and running-boards, had a hard time making time with family picnics, mothers day, mowing my dandelions......
  5. Chucky
    Chucky
  6. tb33anda3rd
    tb33anda3rd
    volvobrynk and tomkelly88 like this.
  7. Bowtie Coupe
    Bowtie Coupe
    "A lot of struggle, wrestling."
  8. tb33anda3rd
    tb33anda3rd
    thanks. i like it.
  9. pumpman
    pumpman
    Thanks I too had no clue.
  10. Bowtie Coupe
    Bowtie Coupe
    De nada. (You're welcome.) I've been intently following your rebuild and my big contribution is a simple translation. Go figure!:)
    tb33anda3rd likes this.
  11. tb33anda3rd
    tb33anda3rd
    mucho-uhh-primer-o?
    final coat of primer on the body with a green guide coat. DSCF3960.JPG DSCF3961.JPG
    bct, TFoch, volvobrynk and 1 other person like this.
  12. tb33anda3rd
    tb33anda3rd
    my dad had made a bracket to mount the generator up over the valve cover. it bolted to the header but moved the generator inside the hood. he bent a piece of plate and then had it chrome plated. i had switched over to an alternator and at that time the chrome was rusty and flaking so i painted over it black. i decided to make a new bracket out of stainless and polish it to look like chrome. DSCF3965.JPG
  13. tb33anda3rd
    tb33anda3rd
    to bend the stainless plate i decided to make a tool for bending steel in my hydraulic press. i started with some scrap pieces mallomike took out of his scrap pile at work and an old piece of a international A two way plow. I welded the square tubes together and capped the ends with a thick piece of bar. i then welded a rod to the top of another piece of bar and welded the tractor bar across the bottom. DSCF3962.JPG DSCF3963.JPG DSCF3964.JPG
    TFoch likes this.
  14. tb33anda3rd
    tb33anda3rd
    DSCF3966.JPG test piece. now i just need to polish the stainless plate and cut it to size.
  15. ct1932ford
    ct1932ford
    Looking Good!:cool:
    volvobrynk likes this.
  16. TFoch
    TFoch
  17. pumpman
    pumpman
    Tricky tricky tricky! Neat solution.
  18. tb33anda3rd
    tb33anda3rd
    thanks.
    i always wanted to build one, this project forced me to get it done.
    today i started with the chunk of ss plate, it had a "sanded" looking texture so i sanded it with 180 grit, then 320, then 400 then 600, and finally finished sanding with 800 grit. a quick buff and it looked like a piece of mirror. DSCF3970.JPG DSCF3971.JPG DSCF3974.JPG
    falcongeorge likes this.
  19. tb33anda3rd
    tb33anda3rd
    i then cut the piece to width and covered it with blue tape and packing tape, then stuck it in the new press. it is amazing how easy it bends this 1/4" ss. once the holes are drilled and it is trimmed, it should look like it did in the magazines. DSCF3981.JPG DSCF3982.JPG
  20. tb33anda3rd
    tb33anda3rd
    i also sanded the jambs and edges in preparation of some color.
  21. pumpman
    pumpman
    Man, you are one busy boy! Real nice job on the bracket. You're making me feel guilty on the progress (non progress) on my car. Still working on the yard, honey due list.
    Runnin shine likes this.
  22. tb33anda3rd
    tb33anda3rd
    thanks!
    the problem i am going to have is my wife has not stopped adding to the list.......so when i am done............
  23. tb33anda3rd
    tb33anda3rd
    '55 caddy arlington green! this is the color my dad and uncle painted all their cars; DSCF3983.JPG DSCF3984.JPG
    Runnin shine, falcongeorge and TFoch like this.
  24. ct1932ford
    ct1932ford
    That is the color I remember!:cool: I can't wait to see it all painted. Makes me want to go out and get a 49 rag top!:cool::cool:
    Man I'm all horny:p
  25. tb33anda3rd
    tb33anda3rd
  26. kidcampbell71
    kidcampbell71
    Jamb' good job, man. :)
  27. tb33anda3rd
    tb33anda3rd
    i be jambin mon!
    kidcampbell71 likes this.
  28. Chucky
    Chucky
    Color looks great! Sorry about the mexican wrestler, I just really like your car.:)
  29. TFoch
    TFoch
    Looking forward to the outcome! Love the color choice :)
  30. pumpman
    pumpman
    Not a big green guy, but damn that is really really nice! Now for the shinny firewall. Will be watching.
