Hot Rods Wyke 32 Sedan
Discussion in 'The Hokey Ass Message Board' started by cornfieldcustoms, May 16, 2015.
  1. cornfieldcustoms
    cornfieldcustoms
    I started another project a while back, The Wyke 32 sedan. the plan is a chopped sedan, slammed high boy. that is the basic idea, and a lot of little trick touches to make it stand apart.
    here is the body as it came in, took the body apart and sent it out to be chem dipped. should be back in the next couple weeks
    while that is being done i started on the ch***is. got the ASC rails set in the JIG. As in most stamped aftermarket rails there are some imperfections from the stamping process
    so i heated hammered and dollied out the rought spots.
    then machined some body bolt blocks, and welded them in the ch***is. after that i applied some weld through primer to the inside of the rails
    decided to pinch the rails inward at the fire wall. wanting the rails to be same wide as the grill shell at the xmember and keep the front horns. also wanted to straighten the front horns. so i clamped on a heavy piece of angle, heated and shrank them to get it straight
    all cleaned up
    made the front spreader bar, slightly curved it for a little style, also pie cut the top and bottom of the rail and tapered them to fit the 1.75 od tube for the spreader bar
    then moved around the rear. The customer and my self really liked the rear of the Steadfast 32 sedan so we borrowed a few ideas and changed them a little bit for our own taste
    did the spreader bar to match the tank lines, made the matching lines on the bar go half way around the tube to make the bar stand out but blend in at the same time.
    also decided to recess the bar into the tank similar to the Steadfast car. pushed the bar forward about 2.5 inches
    then trimmed the rails, tapered the top back to match the tube, and metal finished back out. still need to work on the tank sheet metal but that is for another day
    started working on the custom flat rear cross member as well
  2. timwhit
    timwhit
    Awesome work bro. Wish that was my car.
  3. Texas Webb
    Texas Webb
    Yes,keep updates coming.Like the tank treatment.
  4. hammered30
    hammered30
    from west aus
    That sure is some mighty fine work thanks for posting
    cheers hammered30
  5. A Boner
    A Boner
    You should try using some JW Rod Garage deuce rails.....less fixing to do, Just saying.
  6. clem
    clem
    Neat thread/car. Neatest looking spreader bars that I've seen in a long long time.
  7. brady1929
    brady1929
    Incredible work as always.
  8. Bulletnose26
    Bulletnose26
    Very nice detail.
  9. rusty rocket
    rusty rocket
    Wow beautiful work. I love little touches like your curved spreader. Unless you really sit down and look or the owner tells you about it you would never know it was changed.
  10. deucetruck
    deucetruck
    from Missouri
  11. Pewsplace
    Pewsplace
    I love the concept for the sedan. The Steadfast car set the bar for sedans but I can see you may go even higher. I will be following this one. On a side note, I am doing a lot of work on my 34 ASC rails. They are really not very straight and have lots of waves near the front.
  12. 2deuces64
    2deuces64
    I 'm liking the direction this is heading. Nice work.
  13. 117harv
    117harv
    The word (slammed) should never be used on a traditional site.
    Very nice work, will be watching. The tank and spreader bar, very interesting detail.
    X38 likes this.
  14. DDDenny
    Harv--
    I kinda have an issue with "bagged" too.
    Oh yea, really tired of BAD *** also.
    Rant over.
  15. willysguy
    willysguy
    from Canada
    Cool, looking forward to the updates!
  16. cornfieldcustoms
    cornfieldcustoms
    thanks for the kind words so far. i will keep the updates coming as it progresses.
    i guess i should have used the word hammered, or super low instead of "slammed" for the term sensitive folks lol. no matter what you want to call it the stance will be on point
    Donald A. Smith likes this.
  17. T-DeWitt
    T-DeWitt
    Can't wait to see more on this build.
  18. AV8R
    AV8R
    love the rear bar!!! I saw it on the steadfast car too and was thinking about doing the same thing. I love the rear bar idea to reflect the pattern in the gas tank! What's the trick to making that look so nice? did you cut a piece out and tack it back in at a lower level? or shove a small pipe inside? what's the best way of cleaning up the weld after? sorry ...amateur questions, but I really like that detail. Thanks!
    Chris
  19. cornfieldcustoms
    cornfieldcustoms
    been a busy few weeks. had a job come in that kind of took over the shop for a few weeks. now i am getting back on track.
    got in a ch***is engineering center section kit. did not like how plain it looked. so started cleaning it up and belled the oval holes.
    started cutting and fitting the boxing plates. the customer really likes the look of dimpled boxing plates but doesnt like the idea of stuff getting down in the rails. so i dimpled the plates, then cut and tig welded plates on the back of the dimples. so it has the look, but sealed up from the elements
    test fitting up the center section to boxed rails
    more progress to come soon
  20. clem
    clem
  21. HOTRODPRIMER
    HOTRODPRIMER
    The detail is amazing,I'm subscribed. HRP
  22. Malcolm
    Malcolm
    from Nebraska
    Top notch work as always! I'll definitely follow along.. Thanks for posting!
    Malcolm
  23. AV8R
    AV8R
    Chris
  24. cornfieldcustoms
    cornfieldcustoms
    slid another piece of tube inside the spreader bar after cutting out the shape. then tig welded the seam. took a cartridge cone abrasive and sanded the top of the weld smooth
  25. Pewsplace
    Pewsplace
    Love your work. I like the dimple holes and had not thought of putting a sheet behind them. I think leaving them open would only lead to problems later on a street driven car.
  26. 383deuce
    383deuce
    Signed up for this ride......Great work and can't wait to see more of what you are going to do.
    I like your idea of backing up the openings in the rails to keep the "salt" out. I thought long and hard about airing out the boxing plates on my build, but p***ed due to thinking about all the salt that would be trapped inside the rails at Bonneville. DAM...I never gave it a thought to back it up like this.
    Very cool! Plus a nice look..
  27. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    Your work on this one is amazing as usual. I love the boxing plate idea. You've got my attention, I've subscribed.
  28. cornfieldcustoms
    cornfieldcustoms
    finally back on this one after traveling for the last month. made a front mount fixture to support the engine while i designed and made the motor mounts
    then made the mounts. hand made both the frame side and block side mounts. uses a standard biscuit style rubber cushion
    then moved on to the trans mount. it is made from .250 mild steel
    and made a top plate to help tie together everything
    adjusted the angle of the pedal ***embly to work correctly
    the body and parts also came back from the chem dip shop
    i had to fix a weird hole in the grill shell that was leaded over
    after the repair
    more to come as things progress
  29. ski
    ski
    from San Diego
  30. Burny
    Burny
    Wow...awesome work. Love the little details...subscribed
