Projects The Newbee Slow Banger Build
Discussion in 'Traditional Hot Rods' started by jim1932, May 18, 2015.
  1. jim1932
    jim1932
    OK due to lask of space and time, it is the BUILD that will be slow.... hopefully not the motor. I had a bone stock 32 Tudor that I sold to get the kid Edumacated. It was too nice to hotrod anyway. An acquaintance Model A guy had been sitting on this B motor. I asked him about it at the right time and he sold it to me.
    Diamond block B that was out of an AA farm truck in Kansas (he was there when the took it out. Been stored inside ever since. Head is a diamond cast too. Looks low mileage to me. First step is dis***embly, get it dipped and checked out.
    My plan at this point is to run Babbits, 7:1 crowsfoot iron Winfield (Tod's), Brierley cam, FSI ignition, Cast Iron header (also Tod). Leaning towards a weber for carb. Not sure on the fuel pump but leaning towards mechanical (are there good repops out there?
  2. slv63
    slv63
    Let's see more!
  3. jim1932
    jim1932
    More what? Like I said sloooow build. This is as far as I got so far....
  4. kidcampbell71
    kidcampbell71
    Lol, no worries. Whatever you do, definitely interested. Not enough of what you're about to do ... and two thumbs up on the link in your signature. What a cool car. Enough said. Onward, at your leisure. Thanks !
    volvobrynk likes this.
  5. Jim,
    What do yo plan to put the engine in?
    Charlie Stephens
  6. jim1932
    jim1932
    Due to my current lack of a garage, but desire to stay in the hobby, I do not have a ch***is to put it in yet. I am trusting the car gods to provide at the appropriate time. Not being overly trusting, I have a line on two late model A pickups that due to owners age will be available soon (friends, not trying to screw anyone). Thinking a fender-less pickup. The main target was in a Farm equipment dealership with my Dad. fortunately the pickup says "****x.. equipment" and not ****...Farm Equipment on the side.
  7. waxhead
    waxhead
    from West Oz
    Another banger pickup build................. I'm in. Good luck with the build.
  8. jim1932
    jim1932
    First question. What's the best source for the ***orted bolts and studs for the motor? I plan on replacing them all.
  9. Jakesrocks
    Jakesrocks
    Bangers rule. Ya got me watching.
  10. winduptoy
    winduptoy
    Bangers rule so I like your thinking. You have a diamond block and it looks like it has potential.
    I buy most all my ***orted fasteners from Snyder's. Use the moly head studs
    If you run an A head (Winfield) on a B block you will likely need to plug the two steam holes next to the # 1 stud (center or #1 in the tightening sequence) so you don't get a coolant leak into a cylinder.
    Look the valve area over real good to make sure that there are no cracks.
    As for a fuel pump, verify that you can use a stock one with the headers. I don't know of a stock re-pop fuel pump. I run electric on my 'B' powered A as it has headers.
    If you get to that point on your 'slow build' I can dig through some stuff and see if I have a spare manual one
    Larry
  11. jim1932
    jim1932
    Are the "B" bolts and studs the same as the "A"?
  12. If I remember correctly there is one slightly longer stud on the Model A that holds the clamp for the ignition cable. The Model A also has two longer studs for the water inlet.
    Charlie Stephens
  13. jim1932
    jim1932
    Well, drop the motor at the machinist tomorrow. So far have ordered two 81's from uncle max, a B distributor with modern internals from Renner and am on the list for Tod's Winfield cast iron and his cast headers. Will post the results from someone smarter than me looking at motor.
    -Brent- and volvobrynk like this.
  14. jim1932
    jim1932
    Charlie, this one seems to have two longer studs in the back on the p***enger side?? I can't thing of any reason for them.
    Motor is at the builders for dis***embly and inspection. Looks like cylinders are original bore. A good sign. Need to decide a transmission set up so I can get the bell housing and fly wheel set up. I know the B and A are different flywheels but am I correct in that a lightened A flywheel will fit a B motor? Can I use an Aa bellhousing?
  15. I don't know of any reason for the two longer studs, probably just something they had laying around. The A and B flywheels are interchangeable on the engines. The problem is if you try to run an A flywheel with a B transmission the flywheel will hit the transmission case. The B flywheel will fit fine in the A transmission case. Depending on how they lightened the flywheel you should be able to use an A flywheel with a Model B transmission case. I ***ume you are going with a V8 clutch while you are at it? I don't understand your question about the "Aa" (did you mean "AA"?) bellhousing (but I don't know much about them and probably couldn't answer anyway)?
    Charlie Stephens
  16. jim1932
    jim1932
    I read enough to be dangerous. This is the sort of thing I have seen around "AA bellhousing is desirable for T5 Transmission swaps". I ***ume that is what this is referring too? I have access to a couple of these.(not the exact one in the photo though) aa bell.JPG
  17. jerseyboy
    jerseyboy
    Jim,
    Nice to see you starting a build thread. I always hesitate to start my own since it's taking me sooooo damn long:oops:
    At least I can learn from you.:D
    I'm subscribed.
  18. jim1932
    jim1932
    Ahh but you are cursed like I was with the Tudor (which was sold by the way). Car was too valuable and original to screw up. I got my first new part this week. Rebuilt B distributor from Renners.
  19. jerseyboy
    jerseyboy
    Well,
    I have done some soul searching. I am in the midst of doing a highboy woodie:D I have a reversed spring up front, reversed spring in the rear with 41 shackles, warmed over 4, 16" rims without fenders and redoing the front doors to be more like the pickup. I'm keeping the mechanicals and adding sliding windows. I'm also thinking Kawanee green.
  20. jim1932
    jim1932
    Sounds, pretty awesome!
  21. jim1932
    jim1932
    Slow but sure..... 2 81's from Uncle Max.
    volvobrynk, waxhead and Hotrodmyk like this.
  22. jim1932
    jim1932
    IMG_1551.JPG Another piece of the puzzle. plus Cam on it's way to Brierley and the following ordered form Piranio:
    1# A 6502-ss-hp 1pc valve & guide conversion-1.700 intake
    Includes 4-1.700 intake valves,4- 1.530 exh valves , 8- 1 piece valve guides, 8- modern retainers, 1- modern keeper set
    1#6513- Valve spring set
    4#6509-s - Valve seats for 1.70 valve
    4# 6507- Valve seat
    winduptoy, volvobrynk and waxhead like this.
  23. chopnchaneled
    chopnchaneled
    from Buford Ga.
    Subbed,
    Just got the bad news from the machine shop on my diamond block, "junk" Cracks in the
    valve seats that can't be stiched.
    Good luck on yours.
  24. 30ccpu
    30ccpu
    We're did u source the 81's from IDE like some for my project
  25. jim1932
    jim1932
    81's from Uncle Max... 97-express.com Just call him
  26. 30ccpu
    30ccpu
    Ok thanks will do
  27. Bader2
    Bader2
    Hang onto it,you may wanna build a cragar overhead someday.
  28. jim1932
    jim1932
    A couple more parts for the pile. Cam should get here next week.... like I said, Sloooooow build. IMG_1668.JPG IMG_1666.JPG
  29. winduptoy
    winduptoy
    Agree to that statement.
    from the photo above it looks like you have the upper half of the bell housing for the B engine. the bottom half is the back of the oil pan on a B.
    You would need to cut that part off the B oil pan if you use the AA housing with the B engine. The AA housing can be used for a T-5 transmission set up.
    V8 clutch is a good idea on the engine you are building. I wish I had and now I'm going to when I fix the transmission.
    Hope that helps
    Larry
  30. jim1932
    jim1932
    At this point the AA is a spare. I plan on a b transmission. I can do a v8 clutch with that and a lightened flywheel, right?
