209-298-5570 1942-1948 head light covers SOLD.... have other sets 1948 lower hood emblem SOLD lots of other parts available
48 rolling ch***is (minus the rear pumpkin) still has E brake set up, OG master cylinder, brake pedal, brake & fuel lines etc $450
48 pontiac gravel guards model 25 ..as is.. 1 set left $50 pair 4 DOOR TRUNK MOLDING... $60 TAIL LIGHT BEZELS (BULB HOUSINGS NOT SHOWN BUT GO WITH THEM) NO LENSES.. $60 PR. REAR LICENSE PLATE MOLDING... $50
radio (not tested) no knobs ..SOLD ...lower hood emblem ...$50..... rear license plate emblem $50.... hood script emblems sold...
41-48 inner windhield trim (3 pcs.) $60 ....mirror $20 48 pontiac garnish moldings (3 pcs. driver side. 1 pc rear p***enger side) $35 ea p***enger door moldings sold 41-48 4 door headliner bows $50
PACKAGE DEAL ON CH***IS & NEW BRAKE , FUEL LINES $500 48 rolling ch***is (minus the rear pumpkin) still has E brake set up, master cylinder, brake pedal etc 1946-1948 main fuel line ((NEW)) oem steel 119" wheel base $75 1946-1948 model 25 & 27 brake line set ((NEW)) oem steel 5 pc set $145 1941-1948 brake line clips 6 pcs ((NEW)) $12.00
ttt I can take any of the parts listed to the Turlock Ca swap meet coming up on jan 24, please let me know in advance, thanks!
(1) 16 in pontiac rim clips in good condition $60 plus shipping will remove tire once its ready to go bare frame $200 no rust no rot upper shock towers $100 ea.. not included with frame, been removed.. diver side drum and spindle ***embly $150 lower A arm $125 front springs $80 set p*** side drum and spindle ***emby $150 lower A arm $125 can do a pkg deal if you buy both sides.... original rear leaf springs $100 set original rear end with the U bolts brackets etc. $100
