Projects The Covered Wagon Deuce Sedan Build Complete With Crummy Cell Phone Pictures
Discussion in 'Traditional Hot Rods' started by gonzo, Nov 30, 2014.
  1. brady1929
    brady1929
    Chop it chop it chop it.........
  2. gonzo
    gonzo
    Man that is great. Thanks a lot for taking the time to do that Geoff @whodaky . I'm going to print these out and hang them on the garage next to my car for inspiration!
  3. 383deuce
    383deuce
    YES! the sedan on the left has 3.5 inch hair cut.
  4. gonzo
    gonzo
    So I did a cost benefit analysis by using a proprietary algorithm that factors in my laziness and concluded I needed to outsource some chassis work, enter @cball of millworks hot rod fame. A little lift here a little tuck there and POW... progress.
  5. onekoolkat1950
    onekoolkat1950
  6. 32fordlover
    32fordlover
    Mine is a 2 1/2 in. Chop. Good looking and still useable.
  7. gonzo
    gonzo
    Motor and tranny mount got fitted and tacked. Also got my pedal assembly tacked in place. Need to get my radiator and verify everything is kosher then I'll finish weld. Plus I ran out of argon towards the end... Thanks Obama.
    mgtstumpy likes this.
  8. Pete
    Pete
    That engines gonna melt the first time you start it......
    cadillacoffin likes this.
  9. gonzo
    gonzo
    Got the steering pretty well situated tonight. I turned down a couple pieces of DD shaft so that it would fit into the original steering tube. This will allow me to run a complete 1939 box and retain a full hood as well as the original column drop. It also gives me cross steer which I like.
    [​IMG] [​IMG]
  10. cball
    cball
    Keep up the good work John!! Thats some real hot rod shit!
  11. general gow
    general gow
    MODERATOR
    Is that motor French? Chev...Chevero...
  12. gonzo
    gonzo
    Haven't updated for a while but I'm still plugging away. Had Andy Kohler drop the big beam axle, replaced king pins and bushings, installed F1 brakes, yadda yadda.
    Played with some headlight options tonight. High versus low.
    rustymetal and mgtstumpy like this.
  13. F&J
    F&J
    High looks old time with those stands
    low looks Y2K
    Just my opinion, though.
    Time will tell what the car wants, right? Some things look right after the car comes along closer to done
    gonzo likes this.
  14. 327Eric
    327Eric
    The high mounted lights look good to me.
    Grumpy ole A likes this.
  15. gonzo
    gonzo
    True. The stands are pretty cool, they're old units with shitty chrome... I'm a sucker for shitty chrome.
  16. gonzo
    gonzo
    Settled on something sort of in between.
  17. gonzo
    gonzo
  18. gonzo
    gonzo
    Bought tires and installed on the rims. Painted the wheels and put on caps and rings just because.
    Finally found a 4.11 posi and I also assembled the rear end which has small bearings, but I wanted 5 on 5.5 axles and 3 inch brakes. Don't ask what it took to make that happen.
    Also sheetrocked and insulated the garage.
  19. gonzo
    gonzo
    Then I decided I couldn't live without these bad ass old chrome exhaust manifolds. You know what that means right? Tear out the whole steering set up.
    mgtstumpy and Runnin shine like this.
  20. The37Kid
    The37Kid
    Looks great! I'm moving stuff around and adding more sheetrock too. Bob
  21. gonzo
    gonzo
  22. gonzo
    gonzo
    That's more or less where I'm at now.
  23. HOTRODPRIMER
    HOTRODPRIMER
    The sedan is really taking shape,did you ever decide to chop ot not? HRP
  24. gonzo
    gonzo
    It'll get chopped eventually but I'm going to get it further along mechanically before hand. In other words I'll eat my vegetables before having desert.
  25. woodbutcher
    woodbutcher
    :D Hi Gonzo.Looking good.Please keep the updates coming.
    Good luck.Have fun.Be safe.
    Leo
  26. Pete
    Pete
    image.png Chop chop.
    kiwijeff and gonzo like this.
  27. gonzo
    gonzo
    This is where the steering is as of last night. It's going to require some more fine tuning but this is the general idea. I ended up moving the box forward a couple inches so that the mast would still work with the stock 32 column drop, although I may have to lower the drop with a one inch spacer to dial it all the way in.
    Runnin shine likes this.
  28. gonzo
    gonzo
  29. dentisaurus
    dentisaurus
    from Boston
    coming along nicely, who are you planning to use to get the body blasted?. I only ask cos I'm about ready to do the same and I'm in your neck of the woods.
  30. gonzo
    gonzo
    @dentisaurus Johnny Roper at Cutters Autobody in Tewksbury does my sandblasting.
