Projects 1940 Mercury build.
Discussion in 'Traditional Customs' started by Chris Casny, May 20, 2015.
  1. Late 2013, I get a text from my dear friend Eddie, giving me a heads up, that the 40 Merc project, he had bought just a few years earlier, from Jon Fisher (Burbank Choppers) might become available. Eddie needed space in his garage in Burbank CA. I wasn't looking for a Merc but I always loved them, considering 40 Mercs and 36 Ford 3 window coupes the ultimate customs. But financially I couldn't justify it.
    A few month go by and I just couldn't let this one go. "When are you gonna find another one" I kept thinking. Finally a deal was struck. I was pretty broke, having just built a 2400 square foot shop in Austin TX, so a payment plan was negotiated.
    The car is in pretty good shape for being 75 year old, after all it spent many years in storage, at a aircraft hanger in Van Nuys CA, from 1952 on, until the 80's (correct me if I'm wrong, Jon). Some repair work was done to the body by an old timer later on, revealing some rocker panel and lower door repair. The guy knew his ****, as he gas welded everything, beautifully. I'm stoked.
    In Burbank: Eddie and I had to make it a roller again since the front axle and rear end where no longer attached to the car. I added some temporary front wheels.
    All loaded up in Hollywood CA, the night before leaving for Texas.
    Somewhere in Arizona.
    T-roaster, OahuEli, seatex and 4 others like this.
  2. This should be interesting...
  3. Off loaded in Austin, now i finally get to take a closer look.
    Next to my other project
    T-roaster, OahuEli, kiwijeff and 4 others like this.
  4. A Rodder
    A Rodder
    This will be great!
  5. Devin
    Devin
    from Napa, CA
    This should be good!
  6. belair
    belair
  7. After it sat for about one year (I had a roadster to build first) I pulled the body off.
    The plan is to completely build and finish the frame, including paint, brake lines, exhaust etc etc first, paint the underside of the car, the firewall then, set the body back on the frame and start chopping.
  8. Like others I am going to enjoy watching this build.
  9. Ryan
    Ryan
    ADMINISTRATOR
    No doubt end up being an all time '40 merc...
    OahuEli likes this.
  10. ynottayblock
    ynottayblock
    I'm looking forward to this. What's the plan?
  11. Barn Find
    Barn Find
    from Missouri
    Mercs get prettier very time I see one.
  12. X38
    X38
    You ****. Mostly due to the fact that you have just about every desirable car known to man and they all turn out to be sensational.
    OahuEli, heminh2o, cptn60 and 2 others like this.
  13. James D
    James D
    Looking forward to this. :cool:
  14. i.rant
    i.rant
  15. Roger53
    Roger53
    Niiice! Roger
  16. olcurmdgeon
    olcurmdgeon
    thanks for all the pictures, nice bones to start with! Will watch with interest.
  17. FlatJan
    FlatJan
    love them 40s Mercs..can't wait to see it "grow"
  18. brady1929
    brady1929
    Yes this will be good. You are very talented.
  19. Watching this one C - fill us in on your plan of attack man !!
  20. the-rodster
    the-rodster
    You, sir, have my attention.
    Rich
  21. El Hueso
    El Hueso
    @Chris Casny strikes again! Are you planning on running a flathead???
  22. seatex
    seatex
    It will be spectacular, no doubt! The shop looks righteous too, what are the dimensions?
  23. I decided to install parallel leaves. Any of the "kits" out there don't lower the car enough, so I made my own brackets.
    After mocking up the parallel leafs, I reinstalled the body to see where we stand, stance wise. Lower but not low enough, so I decided to install 3" lowering blocks.
    Without lowering blocks.
    With 3" lowering blocks.
    I'm digging how this one sits, I'm hoping to get that stance.
    Or this one.
  24. X38
    X38
    I mounted mine inboard Chris, but mounted the rear shackles off a rear crossmember (2x3 box fits inside the rear channel x member). Shackles going upwards. It's a 38 Ford frame. No, tank won't fit now:rolleyes:
  25. 55 dude
    55 dude
  26. I installed a dropped axle in front and bent the spindle arms.
    [​IMG][​IMG]
    To lower the front even more, I reversed the main leaf, using my hydraulic press.
    volvobrynk likes this.
  27. Finnrodder
    Finnrodder
    from Finland
    Looks pretty cool project,i will watch this one.
  28. Race City Rodz
    Race City Rodz
    Definitely Following this one!
  29. Muttley
    Muttley
    I'm sure this one, along with everything else you have built, will be awesome. As a side note.............it's hard to believe how ugly the stock roof on those cars is.
  30. Look's like the Loves Truck Stop across the hwy from Firebird Raceway.
