COE 38-47 Ford front marker lenses
Discussion in 'Off Topic Hot Rods & Customs' started by wetskier2000, May 22, 2015.
  1. wetskier2000
    wetskier2000
    from NH
    Anyone got one of these lenses and the metal bezel/retainer?
  2. verde742
    verde742
    Cab -over-only,,, tuff to find 25 years ago, when I was looking..
    good luck, and good lookin'
  3. wetskier2000
    wetskier2000
    from NH
    What he meant to say, guys, was they're plentiful, send me one of your spares. :D
  4. X Aero Painter
    X Aero Painter
    They pop up on ebay all most every month.
  5. verde742
    verde742
  6. shopdawg
    shopdawg
    from alberta
    36-41 ford commercial trucks and 40-47 ford c.o.e.'s some ford cars with stanchions. Bob Drake? PM me your mailing address and we'll see what Santa can send you.
  7. kscarguy
    kscarguy
    Lenses are easy to find...rust free housings are not. Contact Mike Woodard in Washington state for the gaskets that mount between the housing and the headlight base.
  8. wetskier2000
    wetskier2000
    from NH
    Yeah, I wondered about the housing/bezel.... Oh wait, are you talking about the cup the gl*** sits "in" or the bezel that holds the gl*** in?? The cups, I have 2 serviceable units, but the gl*** and bezel that holds it in I only have 1 of each. Although, it's rumored a second lense may show up here! :) I was wondering if I could make bezels with 2 simple hammerforms.
  9. I was amazed when I went for some hammerforming. It really works well and is simple enough so that if it doesn't turn out on the first try, you can make some changes and try again. No big deal!
  10. wetskier2000
    wetskier2000
    from NH
    I think the hard part might be some sort of punch for the inner and outer oval shapes.... I don't think I have the tools to cut those shapes very well... I guess I might be able to cut the outer shape with the air nibbler. The inner oval shaped hole, not so much... Hmmmmmm wait a minute... If the hammerform allowed the indent for the inner oval to push in beyond the location of the finished edge, I could just cut off the "extra" from the side with a cutoff wheel.... Hmmmmmmm... Now that I think about it, the same method could work for the outer oval too....
  11. I went to the garage and looked at mine. The back side can be trimmed on a belt sander. The front I would make a template from your original, use that to scribe a trim line, then carefully rough out the center and file or Dremel to the line. I'm not sure I would put the extra little revel line in the part, that might become a PIA.
  12. shopdawg
    shopdawg
    from alberta
    Package ready and will post when I go to town. Lens,bezel, bulb cup.
  13. shopdawg
    shopdawg
    from alberta
    Have you received the package yet or should I look into a trace?
  14. wetskier2000
    wetskier2000
    from NH
    Just pulled it from the mailbox.... It's perfect!!! Thanks very much!
  15. b-bop
    b-bop
    Santa Dawg strikes again :)
