Hot Rods Chevy II 4 banger & new 3.0L engine?
Discussion in 'The Hokey Ass Message Board' started by steve hackel, Mar 8, 2011.
  1. steve hackel
    steve hackel
    Running through all the threads about the 4 cylinder engines, there was a mention of "Michiganmotorz" and the availablilty of a new 3.0L engine. After calling them I still have a few questions for someone out there to clairify; does/did anyone ever make a cross flow head for this engine (intake & exhaust on opposit sides of head)... would this engine work in a car, even though it is a marine application...are there any aluminum dress up items such as valve cover, side plates, water pump... is there a rear sump oil pan that would fit this block in order to install it into a model A' coupe? Any help or possible direction would be appreciated. Regards, Steve
  2. Steve,
    Do they have a web site we could look at? Can you post some of their advertising? My guess is that it is the 3 liter industrial engine from GM but without a picture that is really going out on a limb. Marine cams are different than car cams (or so I was told per a car person I trust). I think I have a marine cam in my car and am not really happy with it. There is probably a good chance the cross flow Ansen head made in the sixties and a new racing head from Austrailia would fit but again, let's see some more information. What head gaskets does it use, that might be a clue.
    Charlie Stephens
  3. saucerhead
    saucerhead
    There is a guy in the HAMB cl***ifieds that has a crossflow head made by Ansen.
  4. shmoozo
    shmoozo
    from Media, PA
  5. That sure looks like the 181 inch Mercruiser Marine engine in my '32 Ford, right down to the "HECHO EN MEXICO" on the side of the block. You might also ask your local Chevrolet parts department about their 181 inch industrial engine. I think the newer industrial engine is fuel injected. Check the posts as there has been a ton of posts on these engines. The main thing I like about these engines is that a standard speed shop adapter (they used the same bell housing as a V8) will mate them to a '39 Ford trans and installing one in a Model A is easy after that. You should double check what I say as there may have been changes to these engines that happened when I wasn't looking.
    Charlie Stephens
  6. That would be Charlie S!!!!
  7. Tricknology
    Tricknology
    from DETROIT
  8. Tricknology
    Tricknology
    from DETROIT
    Specifications​
    Vortec 3.0L​
    Industrial Engine​
    © 2010 General Motors​
    GM Powertrain​
    Type: ​
    3.0L I4
    Displacement: ​
    181 cid (2966.59 cc)
    Engine Orientation: ​
    Longitudinal
    Compression Ratio: ​
    10.5:1 (LW6), 9.2:1 (LMX, High CR)
    8.25:1 (LMX, Low CR)
    Valve Configuration: ​
    Pushrod Actuated
    Overhead Valves
    (2 valves per cylinder)
    ***embly Site: ​
    Toluca, Mexico
    Valve Lifters: ​
    Hydraulic Flat Tappet
    Firing Order: ​
    1 - 3 - 4 - 2
    Bore x Stroke: ​
    101.60 x 91.44 mm
    Bore Center: ​
    112.26 mm
    Bore Area: ​
    324.29 cm²
    Fuel System: ​
    MPFI Fuel Rail and Injectors (LMX)
    N/A (LW6)
    Fuel Type: ​
    LMX: Gasoline (MPFI)
    LW6: Propane, Natural Gas
    Horsepower:​
    94 hp (70 kW) @ 3200 rpm (MPFI: Gasoline (LMX))
    Low CR
    93 hp (69 kW) @ 3.0L rpm (MPFI: Gasoline (LMX))
    High CR
    73 hp (54 kW) @ 2200 rpm (Natural Gas: (LW6))
    64 hp (48 kW) @ 1800 rpm (Propane: (LW6))​
    Torque:​
    188 lb-ft (255 Nm) @ 1800 rpm (Propane: (LW6))
    178 lb-ft (241 Nm) @ 1600 rpm (Nat. Gas: (LW6))
    172 lb-ft (233 Nm) @ 1800 rpm (MPFI: Gasoline (LMX))
    High CR
    168 lb-ft (228 Nm) @ 2300 rpm (MPFI: Gasoline (LMX))
    Low CR​
    Fuel Shutoff: ​
    OEM defined
    Shipping Weight: ​
    363 lb (165 kg)
    Materials:​
    Block: Cast Iron
    Cylinder Head: Cast Iron with exhaust valve seat inserts
    Intake Manifold: Customer Supplied
    Exhaust Manifold: Customer Supplied
    Main Bearing Caps: 2 -Bolt Cast Iron
    Crankshaft: Nodular Cast Iron
    Camshaft: Indus. Profile Low Speed, High Torque (8-port)
    Connecting Rods: Powdered Metal​
    Information may vary with application. All specifications listed are
  9. Tricknology
    Tricknology
    from DETROIT
    marine
    Specifications​
    GM Powertrain​
    432.0
    (17.00)
    188.0
    (7.40)
    210.0
    (8.3)
    643.0
    (25.3)
    595.0
    (23.4)
    624.0
    (24.5)​
    Type: ​
    3.0L I-4
    Displacement: ​
    Longitudinal
    9.2:1
    Pushrod Actuated
    Overhead Valves
    ***embly Site: ​
    Toluca, Mexico
    Valve Lifters: ​
    Firing Order: ​
    1 - 3 - 4 - 2
    Bore x Stroke: ​
    101.60 x 91.44 mm
    Bore Center: ​
    112.26 mm
    Bore Area: ​
    324.29 cm²
    Fuel System: ​
    N/A (LW6)
    Fuel Type: ​
    Regular Unleaded
    Horsepower:​
    143 hp (107 kW) @ 4800 rpm (LMX)
    140 hp (104 kW) @ 4800 rpm (LW6)​
    Torque:​
    178 lb-ft (241 Nm) @ 3600 rpm (LMX)
    177 lb-ft (240 Nm) @ 3600 rpm (LW6)​
    Actual power levels may vary depending on OEM calibration
    and application.​
    Fuel Shutoff: ​
    OEM Defined
    Shipping Weight: ​
    363 lb (165 kg)
    Materials:​
    Block: Cast Iron
    Cylinder head: Cast Iron with exhaust
    valve seat inserts
    Intake manifold: Customer Supplied
    Exhaust manifold: Customer Supplied
    Main bearing caps: 2 -Bolt Cast Iron
    Camshaft: Marine Profile
    Connecting rods: Powdered Metal​
    are based on the latest product information available at the time​
    of publication. The right is reserved to make changes at any time
  10. Tricknology
    Tricknology
    from DETROIT
    Vortec 3.0L I-4​
    A proven history of
    performance and durability​
    Features & Benefits​
    MPFI Version:​
    ¶Multi-port electronic fuel injection (MPFI) version
    that uses gasoline only
    ¶Capable of meeting current and future emissions
    regulations
    ¶Cylinder head targets fuel injectors to back of intake
    valves for quick response to changing conditions
    ¶Stainless steel MPFI fuel rail resists corrosion
    ¶Shipped with HVS coil and 58X crank sensor​
    Carb Version:​
    ¶High Energy Ignition (HEI) distributor and coil are
    shipped on the engine as standard equipment​
    All Versions​
    ¶A high-flow cylinder head with straighter intake
    ports and a higher compression ratio delivers
    impressive horsepower
    ¶Cylinder heads feature sintered powder metal
    exhaust valve seat inserts for improved durability
    ¶State-of-the-art coolant pump seal uses a
    combination of advanced materials to provide
    superb sealing action under extreme conditions
    ¶Nodular iron crankshaft for increased strength and
    engine life
    ¶Camshaft is specifically designed for marine duty
    cycles and optimized for maximum performance
    ¶High-silicon cast aluminum pistons ensure optimum
    performance for the life of the engine
    ¶Cylinder case has br*** water jacket core support
    plugs for resistance to corrosion
    ¶14” diameter flywheel provides common size with
    most GM engines​
    Marine Engine​
    ¶An electronic control module (ECM) and related
    hardware are available in kit form. The ECM uses
    state-of-the-art technology to optimize fuel and
    spark requirements.​
    Available Options​
    MEFI-5 (Marine Electronic
    Fuel Injection - Fifth-
    Generation), is an advanced
    engine controller capable of
    meeting all the emissions,
    OBD-M and driveability
    requirements of marine
    applications. ​
    2011
    Sequential Fuel
  11. Tricknology
    Tricknology
    from DETROIT
    with the stock PORT fuel injection head you could just makre some fake hilborn injetors,,,make it look like early hilborn mechanical injection
  12. Tricknology
    Tricknology
    from DETROIT
    they have individual ports and siameesed ports,,take your pic,,,
  13. Tricknology
    Tricknology
    from DETROIT
  14. Tricknology
    Tricknology
    from DETROIT
    fontana chevy II
    • Compression ratio 13.8 • Light weight 220 lbs.
    • Displacement 200 cubes
    • 7800 RPM Rev Limiter
    Sealed Engine Configuration:
    • Block: Traditional Fontana Aluminum
    • Head: Fontana REAP
    • Injector: Fontana Aluminum
    • Valves: Stainless Steel
    • Rocker Arms: Needle Bearing
    • Timing Gears: Fontana Vernier
    • Water Pump: Fontana
    • Fuel Pump: Hilborn
    • Rods: Steel H Beam
    • Oil pump: Barnes 3 Stage
    • Oil Pan: Olson Aluminum
    • Camshaft: 5 journal 55 mm
    • Ignition: MSD Crank Trigger
    [​IMG]Block features include:
    • Tough A356-T6 alloy
    • Lightweight (63.5 lbs.)
    • 9.15" deck height
    • Bores from 3.875" to 4.040"
    • Strokes from 3.00" to 4.00"
    • Displacements from 142 to 200 cubic inches
    • Beefy 1.00"- thick main webs
    • 7075-T6 main caps
    • 1/2" head studs penetrate block a full 1.75 threaded inches
    • Ductile-iron, wet liners
    • Receiver grooves for copper head gasket
    • Wet or dry-sump oiling
    • Large main oil galley
    • 55mm 5 journal cam
    • Roller cam bearings
    [​IMG]Head features include:
    • Bare weight just 23 lbs.
    • 2.150” intake valves
    • 1.625” exhaust valves
    • Intake and exhaust ports on same side
    • Shaft-mounted rocker arms rollerized
    • CNC-machined ports and chambers
    • High-port intake runners
    • 37 cc combustion
    • Ideal temperature gradient
    • O-ring wire for copper head gasket
    • 14mm spark plugs
    • Down Nozzles
    • Reverse Cooling
  15. Hnstray
    Hnstray
    from Quincy, IL
    Great info.........thanks for posting !
    Ray
  16. 28hiboy
    28hiboy
    from Milton, Fl
  17. Tricknology
    Tricknology
    from DETROIT
    the fontana is the engine of choice at the oklahoma indoor midget race,,,real tight track,,,fontanas have lots of low end grunt.
    the fontana can be made milder via less cam timing and lowering the compression.
    blown up race engines are cheeap,,, damaged heads can be weld repaired, even used race ready engines are cheap when compared to new.
    the cheap way to go is just get the the high compresion GM cast iron Vortec 3.0, with the 8 port head with factory port fuel injection and install fake old timey machanical injector bases and stacks. put in a better cam,,
  18. climer97007
    climer97007
  19. Heimbig
    Heimbig
    I know this is an old post, but can anyone tell me if a rear sump pan from a 153 will fit the pre 1989 2 piece 181 bottom end?
    Thanks
  20. Rusty O'Toole
    Rusty O'Toole
    Expect to pay through the nose for anything that says Marine Engine on it. You can probably buy a 350 crate motor for less money.
    If you want the Chev 4 cyl industrial engine, a lot of them were used in fork lifts. They typically ran on propane which meant they stay clean inside and don't wear fast except maybe the valves. There is a fork lift in a local junk yard right now I bet you could buy the engine for $100 bucks.
