Projects Almost ready for paint.
Discussion in 'Traditional Hot Rods' started by AeroCraftsman, May 16, 2015.
  1. AeroCraftsman
    AeroCraftsman
    Almost ready to dis***emble and start getting some paint on the ch***is. ImageUploadedByH.A.M.B.1431801183.625571.jpg ImageUploadedByH.A.M.B.1431801205.559532.jpg ImageUploadedByH.A.M.B.1431801228.144445.jpg ImageUploadedByH.A.M.B.1431801252.592759.jpg ImageUploadedByH.A.M.B.1431801277.349079.jpg ImageUploadedByH.A.M.B.1431801303.818686.jpg
  2. 56 Dodge Pickup
    56 Dodge Pickup
    very nice what color are you planning on
  3. AeroCraftsman
    AeroCraftsman
    It's a Forest Green.
    charleyw, lothiandon1940 and Model T1 like this.
  4. 56 Dodge Pickup
    56 Dodge Pickup
    That is a really nice color I like it with black trim like the factory used on the model A
  5. AeroCraftsman
    AeroCraftsman
  6. revkev6
    revkev6
    from ma
    nice, what are you planning for a motor?? no boxing plates?? flathead??
  7. AeroCraftsman
    AeroCraftsman
    Yeah a flathead and T5.
  8. AeroCraftsman
    AeroCraftsman
  9. 3wLarry
    3wLarry
    from Owasso, Ok
    stock 46-48 front wishbone?
    kidcampbell71 likes this.
  10. AeroCraftsman
    AeroCraftsman
    Not sure what year the wishbone is, but it's uncut. ImageUploadedByH.A.M.B.1432062238.896236.jpg ImageUploadedByH.A.M.B.1432062266.144733.jpg
    Model T1 and Kiwi 4d like this.
  11. Kiwi 4d
    Kiwi 4d
    Love the colour. Any pics of how the 46/48 wishbone works to clear the T5. Heck if this works so easy , we will have to the same in our upcoming32 build.
  12. AeroCraftsman
    AeroCraftsman
    Original K member modified to clear the T5.
    ImageUploadedByH.A.M.B.1432065052.473212.jpg ImageUploadedByH.A.M.B.1432065094.756959.jpg
  13. Kiwi 4d
    Kiwi 4d
    Easy as. Have you compensated for the caster change , does the front spring still slide into the front x member easily. Does it all work because the 46/48 wishbone has a built in drop?
  14. AeroCraftsman
    AeroCraftsman
    The front spring slides right into place, but the x members where installed to fit this wishbone. The caster angle is fine, although I don't remember the figure. I drove the car for over a year and if anything it could use a little less caster. It's very stable, no wobbles, just takes some muscle especially stopped or at low speed. A lot of that is probably the stock '32 steering box.
  15. Baumi
    Baumi
    Looking great! I love the color!
  16. AeroCraftsman
    AeroCraftsman
    Hey guys, I apologize. The wishbone was modified slightly. The ball was extended back about an inch to get everything to line up correctly.
    It's been several years and I forgot about that.
    Model T1 likes this.
  17. AeroCraftsman
    AeroCraftsman
    Frame out, everything else in.
    ImageUploadedByH.A.M.B.1432328443.859419.jpg ImageUploadedByH.A.M.B.1432328491.362850.jpg ImageUploadedByH.A.M.B.1432328543.651323.jpg
  18. Ryan
    Ryan
    ADMINISTRATOR
    love the color.
    lothiandon1940 and dana barlow like this.
  19. This should look great all back together.
    What's the story on the front spreader bar wing thing?
  20. AeroCraftsman
    AeroCraftsman
    Thanks, I've used the color combination before. Seems like a waste to throw away perfectly good leftover paint.
    The spreader bar is some leftover streamlined tubing. Just something to be different.
    charleyw, Pat, snopeks garage and 8 others like this.
  21. AeroCraftsman
    AeroCraftsman
  22. 3wLarry
    3wLarry
    from Owasso, Ok
    Is that superbell axle 47" or 48" wide?
    How is the front lower shock mount mounted to the axle...pics please.
    inquirin' minds...:)
    kidcampbell71 and lothiandon1940 like this.
  23. AeroCraftsman
    AeroCraftsman
    The axle is 48". The shock mounts are attached to the end of the wishbone. The flat nose on the wishbone was drilled and tapped to accept the shock mount, then welded around the perimeter to keep it from spinning out.
    dana barlow likes this.
  24. waxhead
    waxhead
    from West Oz
    Loving this build and the colour you have chosen. Keep the updates coming.
  25. rusty rocket
    rusty rocket
    Go man go!!!! looks great.
  26. AeroCraftsman
    AeroCraftsman
    Got the black parts out of the booth yesterday. I wanted to get them organized and stored until they fully cure, but I couldn't resist starting to re***emble. ImageUploadedByH.A.M.B.1432610562.775682.jpg
    Model T1 and kiwijeff like this.
  27. I like the color, its almost like Model A banger factory engine paint, which my wheels, dash and engine are painted, yours is just a few shades lighter.
    Looking forward to seeing how it turns out ***embled.
  28. motorntv
    motorntv
    from Kansas
  29. hotrodA
    hotrodA
    WOW!!
    Looks like you excel in several areas.
    What's the story on the biplane and the scoot?
  30. HOTRODPRIMER
    HOTRODPRIMER
    Love the color.
    What type of bike and year is it? HRP
    lothiandon1940 likes this.
