Need a Falcon/comet/econoline/ 144cid Holley carb
Discussion in 'The Hokey Ass Message Board' started by Chopperdave, Feb 6, 2006.
  1. Chopperdave
    Chopperdave
    anybody got a decent one???
  2. t-town-track-t
    t-town-track-t
    from Tulsa
    If its the little one barrel holly that you are talking about I have one. No promise of the condition of it. I would ***ume that it needs to be run through. But if you want it, its yours!
  3. My 200CI had a mustang FoMoCo on it, when I got it. Went to Shuck's and bought a brand new Holly for $150
  4. texoutsider
    texoutsider
    from Frisco, Tx
    Have a 66 Comet 202 sedan here with a 6 cylinder...not sure what size, but it has a carb...if you want it...let me know...will ship..
    Mark
    972.712.6558
  5. Chopperdave
    Chopperdave
    heres a picture of the carb
    http://www.chopperdaves.com/****/carb.jpg
  6. Chopperdave
    Chopperdave
  7. DE SOTO
    DE SOTO
    HEY BIG DAVE !!!!!! theres yer problem right there !!!! that aint a Falcon carb!! See how it has the floatbowl like any ol holley ? well inside its just like an 4bbl with the jets in the bottom & when ya turn or come to a quick stop the gas goes away from the jets & POOOF !! yer dead
    You need to get a Falcon carb... the jet is in the bottom of the carb and has no bowl ... per say ... like the one in yer pic...
    If ya need a pic of one, lemme know and ill send ya a pic... i have 2, but one is the ****ed up one off my daughters car & the other has broken & missing parts.. bought it jus as a parts carb at L/B swap.. E-MAIL me for a pic if ya need it.....DESOTO6X2@AOL.COM
  8. texoutsider
    texoutsider
    from Frisco, Tx
    Hey ChopperDave......that single barrel on my 66 Comet is an Autolite..not a Holley like you picture...dam car is just waiting to come in to be made into a Nostalgia Super Stock car with a 427...the engine does not run, but if you want that carb instead of the Holley, let me know
    btw...the engine is blue..not sure what size 6 banger.
    get in touch via email
    texoutsider@aol.com
    or call 972.712.558
    It's a freebie if you want it.
  9. ray
    ray
    from colorado
    uhhh, no. falcons ran a few different carbs, they certainly DID run that style so there is no reason that one won't work. somehow i kinda doubt an econoline is pulling enough Gs to uncover the jet, if it is, then it's pretty simple to raise the float level. that carb can be retrofitted with the gl*** bowl as well. it can be interesting to actually see what is going on in there. it's just kinda hard to find a friend to ride around under the hood while you drive!
  10. Chopperdave
    Chopperdave
    where can i geta gl*** bowl??
  11. ray
    ray
    from colorado
    your local head shop?:D
    i have a few extras, i might be able to part with one if you're in a hurry. or else ebay, just search for gl*** holley and you should find some. you should be able to find one there a little cheaper than what i'll sell my bowls for.
  12. Chopperdave
    Chopperdave
    how much???
  13. That picture is of a 61 carb. 62's used a Holley 1909, which has a flat top, kinda like an AFB.
  14. Chopperdave
    Chopperdave
    for real???
    interesting....
    thanx!
  15. Yeah, its good info to have, the 61 carbs, (like the one pictured), have "backwards" linkage as compared to the 1909 used in 62. What I mean by backwards, is that the throttle lever swings in an opposite direction. It'll hook up, but when you push the pedal, you pin the throttle plate against the idle stop. I swapped a complete 61 engine into my 62 Ranchero, and ran into this problem, so I know first hand..... Now, having said that, with the age of these cars, its likely that someone changed the entire linkage setup at some point, so the 61 style carb may indeed be what you need.......
