Technical Where is the Engine and Trans serial # on 1963 Chrysler 300
Discussion in 'The Hokey Ass Message Board' started by crater, May 27, 2015.
  1. crater
    crater
    Looking for the location of the Engine and Trans serial #'s on 1963 Chrysler 300.
    Thanks
  2. Rusty O'Toole
    Rusty O'Toole
    Top of the engine block just ahead of the right cylinder head.
  3. And the transmission won't have one, it may have a part number..
  4. 270dodge
    270dodge
    from Ohio
  5. Those are part numbers not serial numbers. Theft numbers didn't become popular until the '70s when theft found itself in the spot light.
  6. 270dodge
    270dodge
    from Ohio
    Did the OP ask for VIN numbers? Chrysler started VIN in 69. I'm guessing that he wants to know if the engine and tranny are correct for the car. That is why those pre 69 Mopars were so easy to copy. Oh why do we bother, he does not seem interested nor reply.
  7. 270dodge
    270dodge
    from Ohio
    The engine number will be on a horizontal machined pad, front and center and to the left of the distributer. The 63 300 cars came with a raised block engine. Oh yes the numbers were not serial numbers but PART NUMBERS!
  8. crater
    crater
    Thanks for the info. Will be seeing the car this weekend. It's suppose to be an original owner/drive train California rust free car.
  9. 270dodge
    270dodge
    from Ohio
  10. crater
    crater
    Thanks 270dodge
    Found the block numbers. T 38 on top and 411 below it and there's a Maltese Cross stamped into the block next to each set of numbers
    Do you think this is the original engine?
    T = 1963,
    38 = 383.
    411 = April 11.
    Maltese Cross - .001" undersized bearing shells
    Maltese Cross and an X - .010" undersized crankshaft
    Thanks
  11. 270dodge
    270dodge
    from Ohio
    Yes it looks like an original. It appears to have the 4 bolt valve covers and that would indicate that the cylinder heads were not swapped for 65 and later.
  12. Finsinthemirror
    Finsinthemirror
