Technical Home made exhaust cutouts
Discussion in 'The Hokey Ass Message Board' started by Ian hall, May 18, 2015.
  1. Ian hall
    Ian hall
    from Uk
    I'm putting a dual system on my jailbar truck.
    Cheap steel headers to 2 bolt flanges then to a pair of steel pack mufflers. I would like to fit some simple cutouts just towards the back of the front fenders.
    Could I just fit a t piece with s removeable flange(maybe 2 wing nuts) would I need to have a way of then blocking off the gases to the main system? Don't want it to sound like I just have a hole in the exhaust!
    It's just a stock flathead so not real noisy anyway
    Ian
  2. Is this what you are looking to do?
    This would not be to trick.
  3. Ian hall
    Ian hall
    from Uk
    Yep that's the sort of thing, it's just 1 3/4" pipe
    Ian
  4. Uncle Bob
    Uncle Bob
    from Salado, Tx
  5. Ian hall
    Ian hall
    from Uk
    Ha,gate valve on the zorst!!
  6. scrap metal 48
    scrap metal 48
    1929 retake 008.JPG Here some I made for the coupe.. A gas fill bung and gas cap.. Easy off and on.. Been on 4 years now... Click the pic for larger image...
  7. clem
    clem
  8. hotroddon
    hotroddon
    Don't Do IT! If its a stock flatty with 1 3/4" exhaust it going to sound Exactly like a hole in the exhaust - Total poseur city!
  9. seb fontana
    seb fontana
    from ct
  10. arkiehotrods
    arkiehotrods
    California Bill's Ford Speed Manual, 1952 edition, suggests this exact thing.
  11. Ian hall
    Ian hall
    from Uk
    Ok I won't do it, was only asking!
    Ian
  12. Ian hall
    Ian hall
    from Uk
    What's an "rr" forum?
    Ian
  13. chevy57dude
    chevy57dude
    Ian - he is talking about rat rods. Abbreviated because rr's are about the polar opposite of what this forum is about.
  14. Ian hall
    Ian hall
    from Uk
    Better keep my head down then as my truck is a bit ratty to look at!
  15. NashRodMan
    NashRodMan
    No it doesn't. That's a perfect survivor look and great patina! RR is when people do things that can be unsafe or just to get attention like spider webs on the grill and stuff like that.
    volvobrynk and 40fordtudor like this.
  16. Ian hall
    Ian hall
    from Uk
    I'm keeping that look, might have some lettering on the doors for my electrical business. Am lowering it all round, brakes and suspension all standard but reconditioned, has nice period recovered seat. Just fancy a nice old school dual system.
    What else might have been done in the 50,s
    Ian
  17. lothiandon1940
    lothiandon1940
    Nothing at all wrong with that truck.
    40fordtudor and scrap metal 48 like this.
  18. Ian hall
    Ian hall
    from Uk
    I'll post some more pics when I get it back on the ground, can't find any rear leaf pins/bushes
    Ian
  19. indyjps
    indyjps
    So how do the tax laws in the UK work. Can you write off the cost of the truck as advertising for your business? So many of the door lettered trucks are fake for "the look", it will be nice to see a lettered up truck for an actual business.
    Good looking truck, well used, well preserved.
  20. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Yea, because we NEVER do anything to our cars to get attention :rolleyes:
    volvobrynk likes this.
  21. Rusty O'Toole
    Rusty O'Toole
    Cutouts are illegal (the cops can give you a ticket) but it is not illegal to connect your headers with a flange. You can take the bolts out of the flange, move the tail pipe to the side and put one bolt back in (old drag racing trick).
    You can make cutouts using gas tank filler pipes and gas tank caps, but make a new gasket out of asbestos or heat proof material.
    Have also seen headers that terminate in old oil filter housings. Remove the lid to uncork the noise.
    Manual and electric cutouts available from Summit and other places.
  22. Ian hall
    Ian hall
    from Uk
  23. slodat
    slodat
    Here is the cutout on my coupe. There is a flange on the end of the headers, then it wye's into the mufflers and the 35/36 drive shaft as the exhaust that can be seen. I have welded nuts into the inside to screw the caps to.
    [​IMG]IMG_1565 by IVAN810, on Flickr
    [​IMG]IMG_1415 by IVAN810, on Flickr
  24. A Boner
    A Boner
    I would think that the header pipe should have the cap at the end, and the muffled pipe should Y off the header pipe. Then the open race pipe is a straight shot, and the street pipe has the slight restriction and not verse visa.
  25. Yep, they only ran gate valves for cut-outs on rat rods like this one in the late 40's...
    Jivin' Jer's recreation of Jesse Lopez' rat rod...
  26. clem
    clem
    ^^^^^ Ok. Customs also.........
  27. Ian hall
    Ian hall
    from Uk
    They certainly sound good in the pictures!!!
  28. phat rat
    phat rat
    Another old way is black pipe ******s with either OD threads and caps or ID threads and plugs
