My buddy has this 327 short block that he was going to put in his Camaro(opted instead for a 402 SB) I've never heard of this casting before and I'm hoping some X-Spurts here will chime in. The main block casting is 3782870... The date casting code is E 115...or, May 11, 1965 The pour daisy reads, 0900/1000h...poured probably at the end of the morning shift... The front pad is stamped...F0513HA...or, Flint May 13, 1965. On back of block is cast the word SPECIAL This code is cast adjacent to Special...in this manner...H23 872 S 852 Sorry, my phone is not talking to my computer-I'll try later to post a pic.
have seen 870 327 blocks but usually no later than 65 -my little book says HA is 327-4 bbl manual trans Have never seen "special" on a 327
Wow--me either. May be a match to some of them early f/x fueler heads, aka 461x. With the dates being so close; that block must have still been warm when it arrived at the ***embly plant.
I believe '65 was last year of F.I. and my friend says the guy he bought it from kept the top end of the motor cuz it was F.I. So, maybe.....
Correct, but still never heard of a 327 block with "special" cast into them F.I. or otherwise. I sure would like to see a picture of the "special" markings I bet I'm not alone.
In the real world if it p***es a sonic and crack check, decking and align boring it is as special as you need. Build it and be happy.
