Technical Ignition coil ballast resistors - question
Discussion in 'The Hokey Ass Message Board' started by Dave Downs, May 31, 2015.
  1. Dave Downs
    Dave Downs
    from S.E. Penna
    Putting 12V points ignition in my '49 Chevy (235)]
    Had a 12V coil laying around clearly marked 'use with external resistor'
    Bought a NAPA (Eichlin) resistor rated for 1.6 ohms - normal-looking ceramic thing with a coiled wire
    Wired it up - - - 12.82 volts in - 12.82 volts out of resistor
    Car starts and runs fine......but coil gets hot (gee - I wonder why....?)
    Why no voltage drop? Bad resistor? 1.6 ohms not right?
  2. waldo53
    waldo53
    from ID
    If your points were open when you checked your voltage - the voltage out will be the same as the voltage in. Make sure your points are closed, then check voltages.
  3. Dave Downs
    Dave Downs
    from S.E. Penna
    Waldo - what about when it is running?
  4. waldo53
    waldo53
    from ID
    Still won't tell you the real story of what your resistor is doing. I think the best way to check this would be to pop your distributor cap off, turn the engine over by hand until the points are closed, then slip a thin piece of plastic or other insulation between the points - then hook your meter up to the coil side of the resistor, turn the key on, pull the insulator out and read the voltage (quickly or things will tend to get hot) then slip the insulator back between the points, and then walk around and turn the key off.
  5. Andy
    Andy
    You could just jumper the distributer lead to ground and check the voltage at the coil on the other side.
  6. Grahamsc
    Grahamsc
    from Colorado
    What the others are trying to tell you is there has to be a load on a circuit before you will read a voltage drop.
    With no load( current) , the voltage will always be the same on both sides of a resistor.
  7. Dave Downs
    Dave Downs
    from S.E. Penna
    Thanks guys - thought that might be the case but wasn't sure
