Projects 1957 Corvette M/SP Project
Discussion in 'Traditional Hot Rods' started by Baron, Jun 7, 2013.
  1. Baron
    Baron
    A good day when everything goes together/fits like it supposed to Headers from underneath.JPG Headers left side pic.JPG Headers looking down.JPG Headers rt side pic.JPG Headers side shot.JPG .
    els, kiwijeff, D-Russ and 4 others like this.
  2. loudbang
    Wow from this view it looks like it's getting ready to eat the competition. Like a mako shark or something.
    els, Baron and D-Russ like this.
  3. Wow, that looks good.
    els and Rat Sass like this.
  4. enloe
    enloe
    from east , tn.
    What did you do with your old tunnel ram?
    els likes this.
  5. Baron
    Baron
    Only thing it's currently eating is the money out of my wallet ...lol
    Thank you
    I still have it and no plans for it really.
    els likes this.
  6. Chuck some doors on it and consider it done.
  7. enloe
    enloe
    from east , tn.
    are you going to get rid of it or hold on to it for a future project?
    els likes this.
  8. Baron
    Baron
    I would be let it go providing it was going to a good home. PM me if interested.
    Hi Jim. I wish it were that simple. I still have a long list of stuff that needs to be done. Thinking maybe this coming week-end I'll install the radiator, finish the fuel lines from the tank to the pump, and bend up the lines from the pump to the fuel pressure regulator( after making a mount for that) and connect that to the carbs. Maybe the following week find and install the radiator hoses, fan belt, install the gauges (mechanical oil pressure & water temp) and than it is almost ready to start (well , almost.... still need to mount and wire up the MSD box, install the distributor, ignition wires, etc, ) And the list ( and the fun) goes on.
  9. elgringo71
    elgringo71
    Baron your Corvette is looking better every day. I love the stance and the style of the build. How does it compare to the 57 Corvette that you used to have and what did you improve on this one. Do you have any pictures of the 57 that you used to have?
    els, Baron and Rat Sass like this.
  10. Baron
    Baron
    Thanks. It was very similar in a lot of ways. At 20 years old, I did not have the skills or money to build a real nice car. The car was a lot rougher to begin with than this one was (not that this was any gem). My first one had sat for years in a back yard, and the weather and abuse had taken it toll. And the $750.00 I paid for the car was all the money. The stance was the same with the 4 inch I-beams I made (like I had in this). It had the same Tubular Automotive fenderwell exit headers as this one does ( although small block powered). The first one I ran Cragar SS mags on it, and it looked much like this one as it never got beyond the primer stage on the body. It had a Muncie 4 spd and 4.88 gears, Lakewood bars, and the car went real good. Never made it to the drags with it, so no time slips. My son was born in 1971, and that was the end of the Corvette. Fortunately I do have pictures of a lot of my early cars, but unfortunately, none of the Corvette. The friend of mine whom I traded with ( the owner of the 55 T-Bird gasser above) does not have any pictures of it either (and he sold the Corvette in 72 to buy a living room set for his new wife ...). So, this one is just a continuation of the car I started so many years ago, with a few up-grades and a far more experienced builder.
  11. brut4s
    brut4s
    Baron, where did you get the scoop? Love the Corvette! Truly Bad Ass!!
  12. jimdillon
    jimdillon
    Baron looks great. Cool that you can relive the old 57 a bit in the not too distant future. I know I am guilty of reliving some of the times past myself. The memories still put a smile on my face when I take em for a ride.
  13. Baron: really nice and finesse job. I read every new post. I've got it as a "watched thread".
    Question, hope not premature but hood pins? What are your plans?
    I really don't want to drill my hood for the conventional pins and was brainstorming a under hood slide latch hold down system. Kind of like the gate latches that slide into a barrel then the rod turns 1/4 turn. Thinking of using 1/4 stainless rod into a brass barrel that will be a precise fit. Front and rear latches will be connected. Handle inside and behind the grille on each side.
    Baron likes this.
  14. This has become your most intense build ever I'm thinking. It's going to be a grand day when it moves down the streets of Gloucester & Essex under it's own power.
    I want to be there that day.
    Baron likes this.
  15. Baron
    Baron
    The scoop was made in Seekonk, Massachusetts. He sells them (and a number of other styles, plus other fiberglass products/bodies, etc. on eBay. His eBay name is SC604
    Started glassing it to the hood this past week-end.
    els, D-Russ and Rat Sass like this.
  16. Baron
    Baron
    I am hoping to run the stock latches and I have a set of after-market hinges that work much better than the OEM ones did. If I can not make the stock latches work, than I will run hood pins just on the rear of the hood.
    I have always loved the sound of the chambered exhaust /side pipes of the 65-67 Corvettes. For me, nothing sounds any better. So I bought a couple chambered mufflers that just fit in the space between the frame and rocker panel and was able to tuck them up high enough so you only see the very bottom of them (other than headers, exhaust should be heard and not seen). Welded a couple of down spouts in front of the rear tires, and the exhaust if finished.
    Going to be noisy, but it will be "music to my ears".
  17. elgringo71
    elgringo71
    That is a great idea on the side pipes, I never would have thought of it but it gives you the best of both worlds.
  18. Jalopy Joker
    Jalopy Joker
    Cool - Wild
    els likes this.
  19. vetrod62
    vetrod62
    Great progress on your car !! You might want to re think the turn downs on the exhaust while you are still in the building mode. I have them on my red car's side exhaust. I hate them. They throw dirt, grass and stones on any car parked within 20 feet of my car when not parked on any thing other than a clean paved surface. Not cool. ( besides it gets my car dirty)
    I had to make up " slip on turn ups " to the turn downs to route the exhaust up and away from other cars . I would make the exhaust blow straight out to the side. Jim
    els likes this.
  20. Chucky
    Chucky
    Really loving your vette! I haven't posted yet on your thread, but I'd have to agree with vetrod62. Your turn-down's are borderline / you might hate them. Here's a shot of my A gasser exhaust, pointing nearly straight out, for exactly the reason's mentioned. image.jpg
    D-Russ likes this.
  21. Baron
    Baron
    Both you guys are 100% correct. I cut and changed the angle of the outlets on my Cobra sidepipes for just the same reason(how quickly I forget...). The ones on there now were just left over mandrel bent 2 1/2" pipe I had hanging around the shop. I just orderd a couple of nice 2 3/4" stainless tips that should work out perfect.
    Thanks for keeping me in check. :)
  22. enloe
    enloe
    from east , tn.
    Hey how long till this beast is moving under its own power?
    els likes this.
  23. Baron
    Baron
    Still a ways off. Lots of little ,time consuming jobs that eat up a lot of time, and when done, don't look like I've accomplished much. But all part of the building process. Here are the new exhaust tips.
    els, volvobrynk, D-Russ and 4 others like this.
  24. elgringo71
    elgringo71
    Keep up the good work Baron, before long you will be making the maiden voyage of a car that hasn't moved under its own power in probably 30 years or more and looks better than it ever did. ( I prefer a gasser to a stocker)
  25. Baron
    Baron
    Thanks. With the shop as busy as it is right now, and the nice weather finally here, I have been slacking on my days off and driving my other “hot rods” while the weather is good. Gives me time to go see some of my friends / shops to see what they are building, and catch up, etc. Nice to have the free time to do things such as this. Still hoping to drive it before fall and than get it ready for paint.
  26. Baron
    Baron
    September is just about upon us and it is time to get back on this car. This is what happens when it gets neglected for 2 months !!!
    Heading up to the Hot Rod Reunion this weekend , but than right back to work on this next week-end. Corvette storage bench.jpg
    els, volvobrynk and Rat Sass like this.
  27. Chucky
    Chucky
    Herbalife! OMG! My eyes are burning!....:rolleyes::D
    Just kiddin' - looking forward to some updates.
  28. Baron
    Baron
    Back to work on the 57. May the fun and games begin. Tomorrow I will start fitting the door posts to the windshield. Once that is behind me I'll mount the stainless trim on the frt fenders. 57 Corvette 10 15 15 a rs.jpg 57 Corvette 10 15 15 b rs.jpg
    els, kiwijeff, RileyRacing and 12 others like this.
  29. jimdillon
    jimdillon
    Looks really good Baron. Stance is great.
    els and Baron like this.
  30. Rat Sass
    Rat Sass
    Perfect!
