Technical *** June 2015 Banger Meet - Cruising Time ***
Discussion in 'Traditional Hot Rods' started by Jiminy, Jun 1, 2015.
  1. Jiminy
    Jiminy
    Here is the banger link list .
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Flat Ernie maintains the monthly link list. Every month is listed:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    Post #105 of link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=6
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://www.centuryperformance.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    http://www.scribd.com/doc/22469332/The-High-Speed-Internal-Combustion-Engine-Ricardo-1931
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
  2. Bluto
    Bluto
    Schools out FOREVER
    even in Poland!
    dos zetas likes this.
  3. Crazydaddyo
    Crazydaddyo
    Thanks for the link.
    Nothing new from me. Car still broken. Placed in storage until time allows repair.
  4. orangeamcs
    orangeamcs
    Daddy o. Anymore pictures or details of that car. I have a 27 touring body that wants that look. Hopefully picking up a running a ch***is to put it on soon. Your car has the look from the front
  5. Know the feeling! Have broken 2 rears now, this was the last...
    Too bad, #TheOleHenry was starting to run really well, outran Craig's coupe (mine with fenders!) at this years Trackdays:
    Last race, up against en german in a '31 coupe with sbc, it leaped off the starting line, and then no more... But the never-backing-down-no-matter-the-odds-at***ude gave me the golden special pick... should have bought that damn trophy instead! ;)
    Entlebucher likes this.
  6. Bluto
    Bluto
    simca5van.jpd-2 copy.jpg Everything we have is stored. Anyone have a good brake master for a 1947 Simca?
    Elmo Rodge and Crazydaddyo like this.
  7. Crazydaddyo
    Crazydaddyo
  8. Binger
    Binger
    from wyoming
    Checking in!
    I was able to get the tins installed above the doors on my coupe project this weekend. Not too much left until I should be able to drive this thing. Still looking for a clutch to work with my T-5 and a stock A bell housing. This clutch is the last piece of this puzzle. Been talking to some fellow banger guys and hope to have one built before the Hotrod Hill Climb in August.
    Please check out my build thread.
  9. blgitn
    blgitn
    Happy summer to all!
  10. denis4x4
    denis4x4
    from Colorado
    Getting the Zipper ready for the dirt drags at Monte Vista on the 12th.
  11. Stick Shift
    Stick Shift
    from LENA IL
    Picked this up at an auction a couple weeks ago. Hopefully get it tore down soon.
    Kjell Elias likes this.
  12. ROCKER77
    ROCKER77
    Anybody else really stoked about this month? Hell we have El Mirage in a couple weeks followed up by LARS and then the best of all we have the Antique Nats at the end of the month. Anyways here is to kicking off the summer
  13. V4F
    V4F
    from middle ca.
    jimski , I love your ca
  14. V4F
    V4F
    from middle ca.
    Simca 1000 - Brake Master Cylinder
    Item# FL-613239
    Regular price: $134.95
    Sale price: $98.96
    Availability:
    Usually ships the same business day
    jimski , is this the mc you need ......
  15. Bluto
    Bluto
    1947 Simca 1 inch bore.
    It's actually Zofia's
  16. Sorry Jim, I think the last Simca car I SAW was in 1956! I guess you've already asked our friends in France?
  17. 97
    97
    New cylinders are available from France, along with many other parts for Simca 5 and others.
    Société 4A - Z.A. RN89 - Sortie 7 - 33750 BEYCHAC ET CAILLAU - FRANCE
    Tel : +33 (0)5.56.72.47.11 - Fax : +33 (0)5.56.72.46.61 - RCS B324 832 963
    I see in another post you mentioned 1" bore, that was the size for Simca 6, I think your Simca 5 originally had a 19mm ( 3/4 ) bore master cylinder . Both are available , 19mm= 105 Euros 25.4mm bore 130 Euros.
    F230 MAITRE CYLINDRE DE FREIN O 19 mm RACCORD O 10 pas 125 P 105,00 E
    F319 MAITRE CYLINDRE DE FREIN O 25.4 mm RACCORD O 12.5 pas 125 bride desaxée P 130,00 E
    How is THAT for Banger Tech??
  18. 97
    97
    OOps forgot to list their website
    http://www.auto4a.com
    to see thecatalog, pricing and exploded diagrams you must view the French Language website...
  19. V4F
    V4F
    from middle ca.
    jimski , you have a good friend there . awesome info ........ "97" you are a good guy !
  20. Hope the Tortoise doesn't leave another puddle at ElMo this month, week n a 1/2 to go!
    J
  21. Bluto
    Bluto
    Thank you for the info. I have a factory parts book and manual. I mentioned 1 inch because I have modified/upgraded the front brakes to Fiat Topolino C ....... these are larger than Simca and have a 1 inch wheel cylinders. I didn't want the peddle go to the floor before working
    The pins and bushings were worn-out and it wouldn't p*** inspection. Plus the plan is to build a C engine for this and the stock brakes are a bad joke
    I've looked at this website before, They are a bit more expensive than I like
    I'm going for a 1 inch Peugeot ...... this has a straight up bolt where the Topo is offset. I still need a Topo for the Fiat NSU roadster
    This gets a warmed over C engine most of the stuff you guys here do but with itty-bitty speed parts
  22. 29 Speedster
    29 Speedster
    from Colorado
    So.......What's the deal the Overhead they ask? Tech Director approved, we are ready to start the Three-Day Sugar Valley Rally in SW Nebrasks-SE Wyoming. (OHV, pre-1948 Carbs, Electronic Ignition, and Overdrive allowed.)
    Great people and a load of fun!!
  23. Bluto
    Bluto
    5422514652_1.jpeg 5422514652_3.jpeg 5422514652.jpeg 5422514652.jpeg Today I found a Pre War OHV Conversion head for a flat head Topolino A
    This is the size of a shoe box The combustion chambers measure a little over 2 inches across.
    I'm a happy old man.
    Cris, flyin-t, dos zetas and 2 others like this.
  24. Very cool find, Jim!!!
  25. Hot Rod 50
    Hot Rod 50
    Hey guys. Got the pan off my 30 model a motor. Cleaned all the sludge out and I'm ready to go back together. I thought I'd ask if I should take this screen off and clean it first.
  26. V4F
    V4F
    from middle ca.
    yes !!!!!!!!!!!! also if you haven't , take the dipper tray out & clean under it . usually they come out by turning the pan upside down & slam it against a hard flat surface ..........
  27. jim1932
    jim1932
    so what is my easy to do best set up for a transmission to a Diamond B block? everything from flywheel and bell housing back and where to I get the stuff ?
  28. winduptoy
    winduptoy
    I'd pull the pump and work on it on the bench.
    I am guessing that you just want a good performing stock Model A oil pump.
    You can take the bottom plate off and pull the screen to clean
    Check the gear to plate clearance. The closer the clearance and the flatter the plate, the less oil byp*** and 'higher' the oil pressure.
    I have a flat metal bench and lap the bottom plate back flat again using 360 grit wet/dry sand paper that I oil up like a 'wet stone' to keep the abrasive from filling up with metal. You can flip the plate over and use the back side if it hasn't been done before. The lapping process takes some time but pays dividends.
    I usually forget the paper gasket and use Loc***e 5699 grey high performance gasket maker.
    If you pull the sheet metal outer housing make sure that you get it sealed back up. If it leaks air past where it fastens to the pump body the pump won't pump. If you study it you can see the oil enters through the bottom of the housing and is pulled into the screen to the pump inlet. The pump won't have the suction to lift the oil to the pump inlet if the housing isn't sealed. Again, I use the 5699.
    Good luck
    Larry
  29. winduptoy
    winduptoy
    Is it going in an A?
    If you have all the A stuff all you have to do is trim the B pan, all the stuff off the back.
  30. Hot Rod 50
    Hot Rod 50
    Great thanks guys. Yea I pulled the tray out. Cleaned it up and the bottom of the pan. I'll pull the pump apart tomorrow and clean it up as well.
