Who's used rustoleum?
Discussion in 'The Hokey Ass Message Board' started by tjd420, Jan 8, 2015.
  1. If the puke residue is stuck good, the rustoleum topcoat is too.
    They always look great from the stands zooming around.
  2. manyolcars
    manyolcars
    heres one
  3. lovemuscle1975
    lovemuscle1975
    Rustoleum rust metal brown sanded to a faux patina
  4. oldsman41
    oldsman41
    sounds to me you laid down a good base if you haven't had any luck shooting the car do you have a maaco shop in town? I know ill get hell from some guys for saying this but are local shop has a owner that has been shooting cars for 20 years you choose the paint and he shoots it. he personally does hot rods lets the other workers do the modern stuff.
  5. tjd420
    tjd420
    I do a bunch of electrical work for body shops in St Louis area, I could get a pro to shoot it for me in a booth. Rather do this one myself.
  6. classic gary
    classic gary
    Painted the wife's 57 chevy 3100 with rusto-paint. 1 gallon of white with a quart of yellow mixed in. Sprayed it with the 9.99 harbor freight gun. Thinner 30-40% with, damn I can't remember, but follow instructions on the can, anyway, I'll post pics later. It turned out pretty well. But it does take a while for the paint to dry enough to do any color sanding or even a coat of wax. Turned out as a 10 footer. Not bad for a work truck.
  7. indyjps
    indyjps
    Rustoleum is a good solution for some builds. If you already have good primer, use good paint. Don't forget, southern polyurethane SPI, they have single stage orange, 2 reds, black, white. All of their other products have great reviews, single stage should be the same
    http://www.southernpolyurethanes.com/Pricing Info.htm
  8. Flamed48
    Flamed48
    Painted the truck with rustolems if your looking for a easy to touch up paint job this is the way to go a can costs about 4.00$ vs the traditional paint jobs thatlly cost 500$ an up to touch up defects
  9. Slopok
    Slopok
    Plus you can save even more money....no masking tape necessary.
  10. Rocky72
    Rocky72
    from Pa.
    Why not go to napa and get the commercial coatings they sell , its cheap and it really turns out nice and its way better than the summit paint .
  11. Chip hammer and 60 grit, gives the metal some tooth. ;)
  12. ago
    ago
    from pgh. pa.
    Most of the work in painting a vehicle is in the prep work. If your body work is quality, and you plan to keep the car a while it would be wise to use quality automotive paint.
    Ago
  13. Just Gary
    Just Gary
    I sprayed rattlecan rustoleum on the dash of my cliche' ;) '55 Chevy back in 2005.
    The job was too small to justify borrowing a friend's compressor & gun. By spraying several extra coats, then color-sanding & buffing, I got pretty nice results.
    40fordtudor likes this.
  14. Grahamsc
    Grahamsc
    from Colorado
    My father did a nice resto on a 1929 hudson with rustoleum.
    Just don't spill any gas on it when you fill up, or it will peel.
  15. wagoon78
    wagoon78
    Ran out of time and money so my sedan is rattle canned. I think it came out nice enough so I will be keeping it like this for a while. Have a few extra cans on the shelf for touch up.
  16. blowby
    blowby
    from Nicasio Ca
    BUMP. Going to repaint the blue on my work truck, was going to do it today. Bought some Rustoleum but now wondering if I should run up to Tractor supply and get this implement paint. Rustoleum is supposedly synthetic enamel and this stuff is alkyd enamel, and difference?
  17. JOECOOL
    JOECOOL
    I've told yous guys before,NO ALUMINUM BATS!!!! wood only for body work!!!!
  18. boomosby
    boomosby
    i did!! came out ok, didnt do much prep work though, really surprised at the difference it makes to sand a area and not but i was young ;p came out good though .
  19. Well you got to scuff it before you paint it silly. :D :D :D
    I think the old Rustoleum, the stuff in the little cans was or is oil base, like one shot. It probably isn't compatible with much.
    This interior is entirely shot with Rustoleum rattle can urethane. its not the same as good old rusrtoleum and took for ever to gas out. Note the chip above the gauge panel. But is was scuff and shoot, no buffing and looks so truckish. ;)
    [​IMG] [​IMG]
  20. 283john
    283john
    Rolled-on with white foam roller. Thinned with odorless mineral spirits about 60 paint-40 thinner. 6 coats with 24hour dry time between each. Wet-sanded, buffed with wool wheel and rubbing compound, then foam wheel and hand glaze. Still looks pretty good 7 years later. Scratches kinda easy though. Had every piece of chrome off the car when painted. Grille, door handles, trim luggage rack, etc, etc. Did a lot of prep. It was a lot of work and time but saved me a ton of money I didn't and still don't have.
  21. Dave7
    Dave7
    from Canada
    Rolled on paint for this Triumph Spitfire. Thinned down. Lots of sanding but worked out nice.
  22. tjd420
    tjd420
    Turned out good for me
  23. B Ramsey
    B Ramsey
    I use it on jeeps and buggies. Thin with acetone and add a little hardener. Can't make it run, and goes on smooth.
  24. Blue One
    Blue One
    from Alberta
    I have used it where it was meant to be, on steel patio furniture :D
  25. 4thhorseman
    4thhorseman
    from SW Desert
    Krylon rust tough semi flat black rattle can. Goes on smooth as silk without stripes. Offers some light reflection. Easy touchups. BECAUSE RACE CAR.
  26. 40fordtudor
    40fordtudor
    Like B Ramsay said---"add hardener". I did the rally stripes on my OT early Camaro and in the AM I had one hell of a bug collection. Long, long time to dry with no hardener.
  27. mike bowling
    mike bowling
    Now that's what I call PATINA! Yoiks! ( but an interesting endor*****t for Rustoleum)
  28. Mr cheater
    Mr cheater
    ImageUploadedByH.A.M.B.1433287214.552127.jpg painted this with Rustoleum and a roller not very good prep work so it's a good 20 footer.
  29. drptop70ss
    drptop70ss
    from NY
    Shot this last week with Valspar implement paint that Tractor Supply used to carry, bought a bunch of it last year on clearance. Use the hardener and it works great, no hardener and sand paper turns it to goo. I made this blue by adding black to Ford tractor blue.
    slack likes this.
