Projects Ron's 1957 Belair Project
Discussion in 'The Hokey Ass Message Board' started by Ronald66, Jun 2, 2015.
  1. Ronald66
    Ronald66
    Hi Guys!!
    I'm kinda new on here and just wanted to show my new entry.
    It's going to be a long term project but i'll get there..
    It's gonna be a tough ride!!!
    hendelec likes this.
  2. Ronald66
    Ronald66
  3. Ronald66
    Ronald66
    As you can see we need a full frame off .
    She needs all new floor boards and braces, inner and outer rocker panels also a piece of the trunk floor .
    I started by ording these things and they are on there way,once they get here i'll be ok for a while .
    Btw she will be having a V8 set up..
  4. chevy57dude
    chevy57dude
    Those photos were a trip down memory lane. Your car may indeed be a 210 model.
  5. Ronald66
    Ronald66
    Sorry i don't get it, what do you mean about 210 model?
  6. low budget
    low budget
    from Central Ky
    Trim level 150 is lowest,210 middle, Belair has most trim, yours does appear to be a 210
    (no wide stainless trim around side windows) Look at your vin number, if it starts with A it would be a 150, B=210 or C it would be a belair, If it starts with a V in front of those letters it would be a V8 car but I would say, more than likely it is an original 6
    ...........sierra gold and adobe beige you have is my favorite color 57
    Ronald66 likes this.
  7. chevy57dude
    chevy57dude
    Sorry - As a tri 5 geek, I had to point it out.
    Te 1957 Chevrolet models were:
    150 Base model, short side trim, no stainless under side windows.
    210 Middle trim package, full length side stainless, SHORT quarter crown, small piece of stainless under side windows, small rare dash trim. Like mine in avatar.
    Bel Air Top trim package, crown stainless is long, almost to rear window, Side windows framed in stainless, gold colored grill and fender gills, Stainless inserts in dash and quarter trim.
    Let's see your cowl tag, and we can figure out what you have. The 6 cyl hood has a different sized script, keep that in mind if you plan to add the hood "vee".
  8. chevy57dude
    chevy57dude
    Although a complete body can be had, there are still pieces that cannot be bought. Save everything!! The window fuzzies way down inside the channel have a sheet metal bracket/clip thing the new parts lack. The dash trim is unavailable, very flimsy and hard to find used. I have several and only one is good enough to put on my car.
  9. 1934coupe
    1934coupe
    Good Luck with your project, mine is the same color right now plans are to paint it black w/ flames someday.
    Ciao Pat
    Max Gearhead and Ronald66 like this.
  10. Ronald66
    Ronald66
    Ok i got it !!
    Thanks for the advice to save everything.
  11. Ronald66
    Ronald66
    Vin and Cowl tag coming soon
  12. 57 HEAP
    57 HEAP
    Good luck on your build.
  13. gmstuff
    gmstuff
    Good Luck, with your project ....
  14. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    I say 210 also.
    My 57 is a 210 v8 hardtop car. And mine was WAY worse for rust than yours
  15. belair
    belair
    I love 57s. Will be watching.
  16. Ronald66
    Ronald66
    Alright my vin starts with a B ,i was already pretty sure it was a 210 but now theres no going wrong..
    Thanks!!
  17. Ronald66
    Ronald66
    Here you go!!
  18. Mirko 73
    Mirko 73
    from Roma
    Good luck my brother, you can do. Good work
  19. low budget
    low budget
    from Central Ky
    57-1011=series B model 210= 2 door sedan 55 to 57
    Body no M=body was made in Baltimore, Maryland then number is production number at fisher body plant.
    Trim 654=Ivory vinyl w/charcoal pattern cloth
    Paint=817=india ivory top and Canyon coral lower
    Canyon coral is a pink looking color from pics Ive seen, sierra gold and adobe beige is 818
    someone may have painted it that color or someone may have swaped the cowl tag
    (which is common I think ?) so a guy can get the matching cowl tag paint combo or interior they want for their car, You use to be able to buy the cowl tag on ebay, not sure now, Its the Vin you arent suppose to change. I guess its OK to change the cowl ID???
    Got my info from a old Danchuk catologue.
  20. chevy57dude
    chevy57dude
    Low Budget beat me to it!
    One thing - the M is not for the plant where it was made. The location of the plant code is the 4th digit in the vin plate on the door frame. Baltimore, Maryland was represented with a "B". "M" is not a letter that indicates any plant.
  21. low budget
    low budget
    from Central Ky
    Yes the M on the cowl tag only signifies which fisher body plant produced the body
    M=Baltimore Maryland
  22. 40StudeDude
    40StudeDude
    I have a set of stainless rocker moldings for a '57...$200 and shipping and they are yours...
    R-
  23. Great project! There is no mistaking a 57 Chevy p***ing by....
  24. chevy57dude
    chevy57dude
    Ok, gotcha. Went and found my own cowl tag. "M" also! The car was built in Balto. Always good to learn, thanks!
  25. Ronald66
    Ronald66
    Thanks for the info!!
  26. Ronald66
    Ronald66
    Got the windshields of this weekend the front one was broken the rear is good,made a crate to put it away for who knows how many years.
    the small lets call it gutter on the inside of the shields front and back are partialy rotted do i need to change them or is there any tricks to repair them..
    The windshield frames don't look bad at all.
    This is the front gutter theres about 10" missing
    This is the rear one a few holes here and there.
    The wooden crate is going to store all the gl***.
  27. 40StudeDude
    40StudeDude
    I have two rear windows (not the side gl***) for a '57 two door-$100 each plus shipping...
    R-
