Technical identify this engine.
Discussion in 'The Hokey Ass Message Board' started by B67FSTB, Jun 3, 2015.
  1. B67FSTB
    B67FSTB
    from Belgium
    What engine is this and is it worthwhile?
    Thx
  2. Katuna
    Katuna
    from Clovis,Ca.
    Well, it's a Ford flathead. Given that you are in Belgium it could be a French Flathead which could be worth more as they are a more stout motor. Generator doesn't look familiar to me but I'm no expert.
  3. Katuna
    Katuna
    from Clovis,Ca.
    Is that distributor mounted on the rear of the motor or is it just laying there? Didn't see that at first glance. Should be on the front.
  4. mgtstumpy
    mgtstumpy
    Lincoln flattie
  5. Xtrom
    Xtrom
    from Forman, ND
    337 ci Lincoln
  6. Saxman
    Saxman
    According to Johnny Bond and Commander Cody, you could build something cool with that:
    She's got a Lincoln motor
    And it's really souped up
    That Model A body
    Makes it look like a pup
  7. Friend of mine put one of them in a '39 Ford back before time. Ran pretty good.
  8. seb fontana
    seb fontana
    from ct
    Not a lincoln..8BA style with dist in back, I want to say German?? Bruce will know..:D
  9. alchemy
    alchemy
    I'm saying a French flathead due to the distributor in the back and the water pumps with the weird casting shape.
  10. The37Kid
    The37Kid
    Ronnieroadster will know he had a French Flathead up over 170MPH. Bob
  11. Texas Webb
    Texas Webb
    Wasn't hot rod Lincoln v-12?;)
    volvobrynk likes this.
  12. Don't forget the author, Charlie Ryan.
  13. B67FSTB
    B67FSTB
    from Belgium
    I got some more pics today.
    info or links are very welcome.
  14. tubman
    tubman
    Definitely not a big Lincoln; not enought head bolts (24 vs. 27). European for sure; someone from there will know. Probably worthwhile pursueing though (if it's complete and turns).
  15. Bruce Lancaster
    Bruce Lancaster
    German for sure, one of the late versions of the G29.
    That family started life as a '42 merc engine used in Wehrmacht trucks, this is a late one of type built for civilian trucks up into the 1950's...239, moified by factory with the rear distributor and front exit heads I thinkl Solex carb.
    It's a basic 239 merc for rodding purposes. I think it even has the front drive still there, just blocked off by a plate, and it also has a timing pin to set in***ial advance. VERY nice find
    (edit...on Head, G for German Ford, 2 for 1942 design, 9 for 3 3/16 V8, T for truck application. G29T.
    These front exit heads and the vertical distributor are a**** the later mods to this engine series. Date castings on head look like 1952 and 1954...
  16. Roothawg
    Roothawg
  17. So, it's a SortaFord,,,v-e-r-y i-n-t-e-r-e-s-t-i-n-g,,,,,:rolleyes:
  18. dos zetas
    dos zetas
    "Got eight cylinders, uses 'em all,
    Got overdrive and it just won't stall"
    i.rant likes this.
  19. seb fontana
    seb fontana
    from ct
    No I won twice..I guessed German and also said that Bruce would know..
    Roothawg likes this.
  20. d2_willys
    d2_willys
    from Kansas
    Sure looks like a flathead!
  21. stillrunners
    stillrunners
    from dallas
    them telephone poles looked like a picket fence.....
  22. kcblueoval
    kcblueoval
    Yes, the Hot Rod Lincoln was/is a V-12 Lincoln Flat Head. I saw it at Back to the 50's a couple-three of years ago.
  23.
  24. B67FSTB
    B67FSTB
    from Belgium
    Thx guys.
    With the dizzy in the back , it ain't easy to put this in a model A or B.
    Can it be transferred to the front.The distributor I mean.
  25. B67FSTB
    B67FSTB
    from Belgium
    one more question.
    is this engine a " 8BA" style engine ??
  26. alchemy
    alchemy
    Sure you could move the distributor up front. Just buy an American cam, cover, and distributor in either the early pre-48 style or the later upright style.
    The guys building the French motors usually cut the "ugly" off the bell housing for more clearance. You could probably do the same.
  27. Bruce Lancaster
    Bruce Lancaster
    Look at the front of the thing. I'm not 100% sure, but I believe you will find Ford 3-bolt cover (with added timing pin). Don't know if cam retains drive lug, but suspect it does. Ford Germany used the '33-36 distributors until they put in the Bosh rear mount...can easily be converted to '42 distributor and '37-48 pumps and stuff for the shortest flathead configuration.
