Customs 1953 Ford Mainline engine swap questions
Discussion in 'The Hokey Ass Message Board' started by squigy, May 23, 2015.
  1. squigy
    squigy
    from SO.FLO.
    I just aquired a 1953 Ford Mainlne.
    The original 215 is tired 25psi on #4 cylinder, has been checked with leak down. To rebuild it would cost a fortune.
    I have a friend with a Ford 200 engine and transmission which are about half the price to rebuild and speed parts are available.
    So my question is, what is involved in swapping out the motor and transmission for the Ford 200?
    A link to or a thread on this would be very helpful...
    This is the car.
  2. 302GMC
    302GMC
    from Idaho
    Keep the 215 ... rings & bearings, freshen the head, cam regrind & dual intake & exhaust will really surprise you in both power & mileage.
  3. town sedan
    town sedan
    The Falcon six has the intake and exhaust on the opposite side of the engine. Don't know how this would affect the swap. I would look for another 215/223 that someone is pulling to swap in a SBC (that's a joke son). Either that or consider a 289/302/351w. Dare I say maybe even a Y-Block, if you don't want to overhaul the OE six. -Dave
  4. squigy
    squigy
    from SO.FLO.
    Looks like i will be rebuilding the 215.
    It still runs and drives but has an awful miss due to the dead 4-5 cylinders
    4 has 25psi
    5 has 50psi
    The rest are 90!
  5. JeffB2
    JeffB2
    from Phoenix,AZ
    If you just got it and it sat you may have some stuck rings,try the "H.A.M.B. friendly" cure one bottle of Marvel Mystery Oil in the gas tank with a fill up and one more in the oil,rob about 4 oz out of one bottle and pull the plugs on the two low cylinders and divide it up between the two and let it sit overnight before you fire it up.Don't be surprised if it smokes a bit at first.
  6. squigy
    squigy
    from SO.FLO.
    Bought it running and i can still drive it, just has a bad miss.. No engine noises.
  7. sunbeam
    sunbeam
    Pull the head I'll bet you have a bad valve do a valve job and go.
  8. town sedan
    town sedan
    Just a thought, but have you checked the valve adjustment? maybe the lash is too tight on the bad cylinders. Still, if it's been going on long enough there might be a burnt valve or two. Getting by with a valve job would sure be cheaper than a full overhaul.
    But when you get the top to seal, any problems with the lower end could then show up. Like blow by past the rings. -Dave
    Atwater Mike likes this.
  9. 57 Fargo
    57 Fargo
    I would do a leak down on those two cylinders, then you will know exactly where to look for the problem instead of guessing....
  10. Moldy1956
    Moldy1956
    I just acquired a '50 Tudor with a flat 8. Had compression issues in 2 cylinders also. Ended up being the valves weren't closing all the way.
  11. biscaynes
    biscaynes
    #4/5? could possibly be a blown head gasket between those 2 cylinders
  12. dirty old man
    dirty old man
    That 215 is a damn fine engine, when right it will outrun a stock flathead. Build it and you won't be sorry. Or do a little research on the 300cid I6, I'm pretty sure it's the same basic engine with a bore and stroke job from factory.
    I bought a '53 w/215 in '59, and beat the hell outta it for years. Finally wrapped the car around a tree and totaled it. Sold the engine and it was installed in a plumber's truck and ran till the rest of truck was junk.
    As a parting shot, I don't know why anyone would go to the trouble of an engine swap to install a Y-block, always a problem engine in my experience.
  13. steinauge
    steinauge
    from 1960
    I would certainly pull the head on the 215 and see what you can do.Even if you have to replace some valves you still wont be out much at all.as the other guys said,those are really good engines! DOM I have many years with Y blocks and generally they work pretty well.I will say the six will take more abuse for longer than damn near anything.
