Technical Flatty build
Discussion in 'Traditional Hot Rods' started by Scott Grabowski, May 15, 2015.
  1. Scott Grabowski
    Scott Grabowski
    Looking at a couple options on a flathead build for the 32 pickup project.
    Simple 2x2 or 3x2 intake aluminum head build?
    Over the top 4x2 intake twin plug head build?
    4-71 blower motor.
    I have always liked a cool looking and sounding motor. What are thoughts on the Max over bore you would feel comfortable running. Not building a cross country traveler so keep in mind it will be a local hopper.
  2. Saxon
    Saxon
    from MN
    What year block you building off.
  3. Scott Grabowski
    Scott Grabowski
    None selected as of yet. I have an early (49-50) Merc but needs to be checked out. Has narrow pulleys.
  4. Saxon
    Saxon
    from MN
    Depending on what block you choose will effect your bore and stroke options.
  5. Bandit Billy
    Bandit Billy
    Hey Scott, if you supercharge it, 2 words...Joe Abbin. Buy the book from Roadrunner Engineering and call Mike at H&H flatheads for your parts or have him build it. My 49 8BA is bored .125, 471 Navarro blower, intake and heads. Henry put lots of metal in there to play with. Relieved, ported, merc crank, CNC steel mains...I don't know anything about anything on flatheads, I just stand on the shoulders of giants and do what they have proven works. $aves money in the long run. Just sayin.
  6. Texas Webb
    Texas Webb
    True words there^^^^^^.
  7. Atwater Mike
    Atwater Mike
    Great surname, Scott...
    The '49-'50 Merc will safely bore .125" (1/8") over standard, but do read up on practical builds. Mild is the best bet, but do some research.
  8. 19Fordy
    19Fordy
  9. Scott Grabowski
    Scott Grabowski
    I guess I am not good enough to purchase a twin plug setup so we shall go with a blower build or keep it simple with a twin carb setup. I see why guys stick SBC's in everything! Lol
  10. RICK R 44
    RICK R 44
    If you want a good reliable engine without costing a fortune, this is my take on the subject. Use the Merc engine that you have, it will have the 4 inch crank. Bore it .040 and use stock type 4 ring pistons and rings. Clean up the crank and use new bearings. I used an Isky max1 cam and Isky valve springs. Either stock valves or 1.6 in. dia. Chev valves with adjustable lifters. Fined aluminium heads( I prefer Edelbrock because the combustion chambers are cnc machined) A 390 Holly 4 barrel or a 2 or 3 pot 2 barrel set up. Most importantly get rid of the stock distributor. There are several options for a distributor, I converted a Chryco electronic unit, or talk to Buba on the Ford Barn page. He converts chev dissys for use in flatheads. This is only my idea of a flatty. It basicly the same specs as my engine that I have put 75000 miles on. There are probably thousands of combinations that will work great. Check out the Ford Barn page. There are many flatty gerues there that are far more knowledgable than am..
    Scott Grabowski likes this.
  11. Mike51Merc
    Mike51Merc
    Two fours sounds like an awful lot of carburetor for a Flattie.
  12. Scott Grabowski
    Scott Grabowski
    Good catch! I am use to a 2x4 setup so the mind typed it! Lol should be a 2x2
  13. Scott Grabowski
    Scott Grabowski
    Well I am on the lookout for a pair of Twin Plug heads. Picked up an ignition system so heads are now needed! Lol! image.jpg
  14. roseville carl
    roseville carl
    been running this for 15 years.............5/16 x 4 in a 36P/U 9" w 3.0 gears cruises all day 75-80 at 26-2700 rpm Roadrunner setup that has been trouble free, can't say enough good things about Joe and his company, first cl*** guy.
    Oh and I use it to tow this.....
    Roger53 and Texas Webb like this.
