photo posting revisted
Discussion in 'Questions & Suggestions' started by 59FORD, Nov 11, 2003.
  1. 59FORD
    59FORD
    Ok. I'm being retarded here. I signed up for starphoto http://photo.starblvd.net/59ford . I've posted pics here before. Now when I go into starphoto and right click, my photos don't show up with a jpg any where in the properities. Usaully you hit the image ****on, then paste your starphoto pic, then delete all the **** up until jpg.(which is not there now)
    Question is, What the hell am I doing wrong here.
    Thanks,
    59ford (eric)
  2. hotrodladycrusr
    hotrodladycrusr
    Your not doing anything wrong, Star changed alittle. Here is the complete URL address of one of my photos from there.
    http://photo.starblvd.net/AdventuresinBigOlds/1-1-1-1064520441?m=1&pg=0&ro=0&co=0
    see this part
    the begining is the name of the album, the first 1 means the first "page" in that album. The second 1 means the first line on that page. And the last 1 means the first photo, in the first line, on the first page.
    So, if you had a photo on the second page, third line, forth photo it would read 2-3-4
    so you see, these three numbers will always varify from photo to photo. Right after this third number is now where you have to put your own .jpg
    and of course delete all the rest. So if I wanted to post the photo from above it would read like this
    http://photo.starblvd.net/AdventuresinBigOlds/1-1-1.jpg
    and then of course add the tags like before [​IMG] at the end
    I know I went into alittle more detail then necessary but I wanted to make sure not only you got it but alot of others that have been asking the same questions. Good luck and if you have any other questions regarding Star don't hesitate to ask.
  3. 59FORD
    59FORD
    Thanks
  4. 59FORD
    59FORD
    Thanks for the reply. Sorry for getting back to you so late.
    I tried doing what you said and all I get on my preview is a box with a red x. I posted the first pic from a cd with the attachment option.
    With the way you described, do I still click on the image ****on and copy and paste the starphoto in there and then just add jpg.
    for example here is the whole URL http://photo.starblvd.net/59ford/1-3-1-1073385652?m=1&pg=0&ro=2&co=0
    So the new one should look like this
    http://photo.starblvd.net/59ford/1-3-1.jpg
    when I do this it comes up with a red x, like this [​IMG]
  5. hotrodladycrusr
    hotrodladycrusr
    Something has changed with Star within the last day and I can't figure out how to post now using them. I'll keep trying, but does anyone has any suggestions?
    I'm really bummed [​IMG] I knew it was only a matter of time before they didn't allow hosting any longer. I sure hope this isn't the case
  6. 59FORD
    59FORD
    Ok, so it is starphoto.
    I might have to look for another host site. I don't have many photo's on their site, that stinks for the other Hamber's who have alot.
    Thanks again for your help. I keep checking back to see if anything has changed.
  7. delaware george
    delaware george
    from camden, de
    is there anyway you can post your little photo straight from the computer,i post all my other ones from there...i just can't figure out how to make them 80x80 ...they always say they are more than 1000 bytes or they are so small you can't tell what it is
  8. hotrodladycrusr
    hotrodladycrusr
    new photo test
    YAHOO!! It works!!!
    VERY simple guys, all you have to do is add a sqigglely in front of the albumn name, and drop everything after the number, and add the .jpg
    look at the two
    http://photo.starblvd.net/~AdventuresinBigOlds/1-1-1.jpg
    Add the tags on each end like before and your good to go.
    So.... if your photo is already in the right spot for your advatar, all you have to do is add this ~ to the right spot. I'm leaving work right now and heading home. I'll be around all nite if you guys have any questions.
    I'm a happy camper once again!!! [​IMG]
  9. 59FORD
    59FORD
  10. 59FORD
    59FORD
    Now it worked. I've tried about 10 times and nothing came up on my preview and now it did. I will try one more.
  11. 59FORD
    59FORD
    Hot damn it works. Here is a toast to Hotrodladycrusr.
    Thanks again. I'm printing all of this out now to keep on file.
    Thanks,
    Eric
  12. poncho
    poncho
    hey thanks denise...YOU ROCK i was tryin' to figure out what happened!!! [​IMG]
  13. test
    ...IT WORKED!!....Denise does ROCK! How did you figure out the "~" thing?
  14. 67Imp.Wagon
    67Imp.Wagon
    Thanks Denise. The "swiggle" ~ worked for me also.
    I'm with Barnett. How did you ever figure that out?
  15. hotrodladycrusr
    hotrodladycrusr
    You guys are all welcome, [​IMG] but if I told you all my secrets, I'd had to kill ya [​IMG]
  16. whodaky
    whodaky
    from Aust
  17. whodaky
    whodaky
    from Aust
    test [image]photo.starblvd.net~whodaky/1-1-1.jpg[/image]
  18. whodaky
    whodaky
    from Aust
    test [image]photo.starblvd.net/~whodaky/1-1-1.jpg[/image]
  19. whodaky
    whodaky
    from Aust
  20. Stovebolt
    Stovebolt
    Good one Geoff - finally got it up onto the board.
    hows the roadster coming along?
  21. HOTRODPRIMER
    HOTRODPRIMER
    I'll try again,,,,
  22. Elrusto
    Elrusto
  23. Elrusto
    Elrusto
    Damnit,that's almost a pain in the ***!!!!
  24. HOTRODPRIMER
    HOTRODPRIMER
    Are you trying to post a picture from you computer or a photo album...like starblvd? HRP
  25. 50Bomber
    50Bomber
    Just wondering what you did to get your shoebox that low. What did you do about the mid-cross member. I step notched mine 6 1/2" and my driveshaft hit. Did you 4-link the rear or build blocks for the leafs...Ben
  26. sodbuster
    sodbuster
    from Kansas
  27. 59FORD
    59FORD
    [ QUOTE ]
    [/ QUOTE ]
    It's my brothers car. He did a 4 link in the rear with air bags. I will have to ask him what else he did in the rear.
  28. mikes51
    mikes51
