Projects 33 chevy 3w....time for a cool change
Discussion in 'Traditional Hot Rods' started by tb33anda3rd, Feb 11, 2014.
  1. froghawk
    froghawk
    Excellent! They'll be the crowning touch!
    tb33anda3rd likes this.
  2. YJ4000
    YJ4000
    Great work. Way to stay focused.
    Ryan.
  3. tb33anda3rd
    tb33anda3rd
    thanks, and just to stay focused, despite having to mow a few acres tonight, i was put the windshield in. DSCF4054.JPG
    kiwijeff and kisam like this.
  4. Chucky
    Chucky
    Holly smokes! Last time I looked, you (only:rolleyes:) had it 'jammed'. Now, it's totally jammin'! You must eat Wheaties every day.;)
  5. ct1932ford
    ct1932ford
    Italian Stallion :p
    kiwijeff and tb33anda3rd like this.
  6. kidcampbell71
    kidcampbell71
    ... mow a few acres, throw together an heirloom car, post a few dozen HAMB identifying parts etc posts, crack three or fourteen HAMB jokes posts, as well as save the world or cook dinner. All in a days work. That beat's my week. You sir are an animal. How do you do it ? :cool:
    HOTRODPRIMER and tb33anda3rd like this.
  7. ct1932ford
    ct1932ford
    He is related to me!:cool: I sleep for both of us!:rolleyes:
  8. tb33anda3rd
    tb33anda3rd
    put the vent windows together with the new rubber seals from steele. and painted the oil filter canister. DSCF4056.JPG DSCF4057.JPG DSCF4058.JPG
    rrs440, HOTRODPRIMER, blowby and 2 others like this.
  9. pumpman
    pumpman
    Cool shot, I see you let the cat out and the gr*** is cut! Really like this. If you mentioned it I must of missed it, but do you have a name for the cebby?
  10. ct1932ford
    ct1932ford
    Now that is a great photo!:cool: I stopped by yesterday and the 33 is looking good. Brings back lots of memories.
    kiwijeff, raymay, TFoch and 2 others like this.
  11. tb33anda3rd
    tb33anda3rd
    Cool Change.......
  12. HOTRODPRIMER
    HOTRODPRIMER
    I know you guys have a long history together...
    This is such a great photo..Who knows how many of us have admired our handy work at a similar vantage point,,I also noticed the cat could care less. :D HRP
    Runnin shine likes this.
  13. themoose
    themoose
    Now that's what I call a tall tail!!:D
  14. tb33anda3rd
    tb33anda3rd
    thanks, i like how "alive" the inside looks on a dark night.
    the cat is my shadow and has been involved with the whole project. DSCF4051.JPG
    HOTRODPRIMER and kidcampbell71 like this.
  15. tb33anda3rd
    tb33anda3rd
    was able to get the door windows and doors back together; DSCF4067.JPG DSCF4070.JPG
    HOTRODPRIMER and ct1932ford like this.
  16. tb33anda3rd
    tb33anda3rd
    HOTRODPRIMER likes this.
  17. tb33anda3rd
    tb33anda3rd
    today i started with putting the oil in the motor and priming the engine with a cut down distributor.
    i had a leak at the oil filter and realized i had the wrong base for the filter. i had switched back from a spin on conversion but needed another piece. folkswaggon had given me a 283 and it was at his house, in the driveway, on a hand truck, so i went over and picked it up. it had the correct parts i needed. DSCF4072.JPG
  18. tb33anda3rd
    tb33anda3rd
  19. tb33anda3rd
    tb33anda3rd
    then a few guys stopped by, big Steve, and Mark [ct1932ford], test the clutch parts while little Steve and bradley [BP32] look on; DSCF4073.JPG
    kiwijeff, Paul B and HOTRODPRIMER like this.
  20. tb33anda3rd
    tb33anda3rd
    dad, two days after shoulder replacement surgery, leads the installation of the motor. Big Steve, Mark, Bruce, Mike, and Lenny get the motor into place...........................makes me wonder.............................where were all these guys when i was sanding? DSCF4074.JPG
    kiwijeff likes this.
  21. FolksWaggin
    FolksWaggin
    Glad I could help supply the necessary parts to get the engine in! Bummed that I couldn't be there to help install it...or to drink your beer.
  22. tb33anda3rd
    tb33anda3rd
    burgers and dogs came off the grill, and the mob heads for the cooler, leaving a clear shot of their work; DSCF4075.JPG
    kiwijeff, TFoch and volvobrynk like this.
  23. tb33anda3rd
    tb33anda3rd
    thanks, needed the crank dowel pin also. wish you had showed up.
    dozen guys, sporting '39 chevy, 70 buick convertible, shelby daytona, 32 ford coupe, '67 mustang gt convertible, '69 gto judge, custom yj............it looked like a car show.......
    charleyw and kiwijeff like this.
  24. Rocky
    Rocky
    Classified Editor
    Too cool.
  25. studebaker46
    studebaker46
    is that your handy work on the motor mounts or did your dad and uncle do that in the original build?looks cool plus functional
  26. tb33anda3rd
    tb33anda3rd
    my dad and uncles handy work. they turned the original '55 front mounts then ,made the brackets off the frame. i did have one half of one of the brackets break, so i welded those uprights down to the front crossmember.
  27. ct1932ford
    ct1932ford
    A few of my photos of the event! Motor is in. My work is done here:rolleyes: Last photo just to prove I was there:p
    Cool story about the Trans. Look closely at the photo! I will let Ted tell it.
    volvobrynk and tb33anda3rd like this.
  28. tb33anda3rd
    tb33anda3rd
    did the final adjustment on the steering box and fixed the pitman arm; DSCF4081.JPG
    volvobrynk likes this.
  29. tb33anda3rd
    tb33anda3rd
    i also bolted the engine down using the new mounts. i originally thought i could use the large washers under the mount but it set the motor too high. so i added to the brackets and shaped them DSCF4076.JPG DSCF4080.JPG to the rubber mounts. engine sits perfect now.
    kiwijeff and volvobrynk like this.
  30. tb33anda3rd
    tb33anda3rd
    i also installed the headers. they have no relief for the side plugs in the head so i needed to grind the plugs flush. the headers snake perfectly through and around the frame, steering box, starter and clutch linkage. DSCF4077.JPG DSCF4078.JPG DSCF4079.JPG
    LOU WELLS and kiwijeff like this.
